Is it possible to replace arrow with car bmp??? I tried to replace on data.zip daycarand daycarghost but system dosen´t started. I saw gurjon skin has that.???
IDT skin#1 v5.5 03/02/10 9download link to be updated)
IDTI put on my IDTv1.0 cruise dials and everything works ok, but I`m not getting compass nor speedo
what is did was is navigatemap_800_400 put this code:
and in navigatemap (common) this code:
any idea why?
thanks
for the compass i think you're missing the vpr file,
and for the speedo i think you forgot to attach it on your navigatemap.ui
ok seem I got it working now I`ll test this in the car .
thanks
just change the names of the bmps's in the common folder
Is it possible to make buttons more fading to transparant (e.g. the red round button), and is it possible to make the "Blankscreen" button fade to transparant.
Can anyone tell me how to do that?
regards,
Navigarie.
Look for these lines of code in common/navigatemap.ui:
Then, change this string to a lower numerical number:
btnNMB_Cursor.alpha 10
from 10 to 7 or so and then try it.
That is the cursor (bullseye-looking) button.
All of the dimmable buttons are listed in this code string.
The alpha_down is the amount of transparency it has once it "dims". The "32" number is the number of transparency when it un-dims.
Good luck!
Is it possible to make buttons more fading to transparant (e.g. the red round button), and is it possible to make the "Blankscreen" button fade to transparant.Can anyone tell me how to do that?
regards,
Navigarie.
i'm currently working on the setting for it,
I don`t get it
I tried to change bmp files still I have arrows. I need really guidness to replace car bmp`s when you have time.
Thanks!!!
I don`t get itI tried to change bmp files still I have arrows. I need really guidness to replace car bmp`s when you have time.
Thanks!!!
in common folder there's a bmp named daycar.bmp, daycar1.bmp, nightcar.bmp, and nightcar1.bmp, hwat you have to do is changes the names of the following, daycar1 to daycar, nightcar1 to nightcar, that would change the arrow to a red car, though this is just for 2D and 2D north up, not for 3D
IDT...I have 3.0 and your 4.3 version. I have changed nothing. I remember reading a while back something about the day/night auto change not working correctly. Mine hasn't worked correctly in a few months...through various versions of your mod. Has this been corrected and something is wrong with my unit settings? I can't find a solution in the forums so far. Thanks. Other than that...I wouldn't change a thing. You do excellent work.
Doc
Doc
the latest one has the most current update regarding it, though i still have to poslish something regarding the color changer on the date and time but aside from that everything is a-ok
Ok thank you. I'll keep playing with settings then. I set it to auto but it just doesn't change. No biggee...it's just a quick button push.
I hope everyone requesting changes send this guy some paypal. ![]()
beer money on your way bro, v4.3 is awesome, hope you don't get tired of modding as this is the only reason most of us are sticking to the f-series
+1 on that
Thanks!!!
Ok. I tried to change 3D car. Is it still not possible to change 3D car. What I saw (I gues) was 3D map with car.
Just finished updating my 700BT EU version to firmware 3 then to IDT 3.0 v4.3 EU. Everything updated perfectly and I want to add my thanks to IDT for his superb work and input to the forum. I have sent you a paypal contribution as a thank you.
I have only been using it for a couple of hours, so am still playing around with all of the settings and options to get it exactly as I want. The only thing I haven't been able to get to work so far is the speed cam warning beeps. No matter what setting I try (on approach or over limit) I get no beep. I have tried with or without spoken warnings and visual warnings and still nothing. Is there something obvious I should check - maybe I am missing the relevent sound file altogether? The visual warnings work OK as does the spoken warning. I have tried searching through this thread in case you have already answered a similar question, but couldn't find anything.
I don`t have sky anymore. Replaced all files again still no sky. ![]()
one thing i noticed about the warning for approaching and over limit is that they are too soft, other that that they should work, try it again and let me know how it goes, i'll also take a look at it,
thanks for the donation bro
did you copy the schemes attached to the download?
I see, so as of right now there is no fix for manually changing the clock colors right?
pushing the day scheme would easily fix it, the problem here is on the initial start up, after the first boot it would work
Yes I did. before I got it but suddenly gone.
well that is weird, what scheme are you using?
JohnCougar1 day
Monopoly nite
but I tried other schemes too.
JohnCougar1 dayMonopoly nite
could you post one of the schemes that you're using and i'll take a look at it
