faceman32
thanks for the donation bro
faceman32
IDTon one of your updates you put TMC shorcuts onmap, is TMC works for F700bt how turn this on?
try using the EU version
all my TMC files are from IDT v1 so pretty much stock - so what're saying is to replace all TMC.ui files with the ones from last EU version? Anything else?
no,
add this code on your navigatemap_800_480.ui,
;TMC
be sure that you also add the IDT_onmap_TMC.bmp on your 800_480 folder
no,
;TMC
ok got ya, thanks
so how this TMC work - asking coz I never used before, it activated itself everytime it will pick signal up?
not sure bro,
Great mod,
Looks very good.
this weekend tested your mod the EU version and i Like it.
There are 2 things wich doesn't match the EU standard :
-The elevation value is given in FT and not in meters because the value seems to be 3 times to high.
-The NEEDLE in the DASHBOARD gives MPH and not KPH while the center image will show KPH.
IS this easy to fix ?
Regards,
Navigarie.
i will take a look at it
I think i found it in the navigatemap_800_480.ui
must be
Navigarie. ![]()
i made a mistake and did this on a non 3.0 system. didnt back up files. its a f700bt. can someone upload files?
what i would suggest is to proceed with the 3.0 update,
do i have to buy it?
no follow this at your own risk
id much rather just replace the files back with what they should be on a 2.0 f700bt. is that possible?
yes, search the forum for F700 backup and then load it to your unit, BTW didn't you back up before doing transferring the mod?
no i didnt. and if anyone happens to just have the data and sys file, that would be great. if not ill just wait for the whole backup to download. thanks!
here you go next time dont forget to backup
Hi IDT.There is so much new stuff on your latest masterpiece!Is there a guide to what does what?I am discovering new screens every time I turn it on! ![]()
i just exam diffed all your files. the only file i noticed that was different and could possibly mean something was the template file. could this be causing the problem. i noticed you had added this lineany help would be great even willing to paypal some more. please help
send me your last working data.zip without the mods prior to this and i'll take a look t it
you are probably real busy with work and modding but just wondering if you had a chance to look at my data file.
thanks you are a great asset to the avic forum
IDT,
Loving 4.3
I had been away for a couple of weeks and did not see anything on possible voice changes for the speed warning cam. Any input on that. Also to all, any known way to get orid of the new annoying "Pay attention to me!" from the TTS?
Ceger
i'll start working on it later
IDT,
Loving 4.3
Ceger
i haven't had a chance to work on it, for sure i'll have it on the next one
i haven't had a chance bro, it's real busy at work so i haven't really spent some time on doing mods,
me too just checking thanks
IDT
I put on my IDTv1.0 cruise dials and everything works ok, but I`m not getting compass nor speedo
In navigatemap_800_400 I put this code:
and in navigatemap (common) this code:
any idea why?
thanks
IDTI put on my IDTv1.0 cruise dials and everything works ok, but I`m not getting compass nor speedo
what is did was is navigatemap_800_400 put this code:
any idea why?
thanks
for the compass i think you're missing the vpr file,
and for the speedo i think you forgot to attach it on your navigatemap.ui
