I am going to play dumb here. Did you have to actually add files to get my mods to work with those schemes? Or did you just have to modify some of the config. Can you let me know what you did? If something needs to be done to the source I will be happy to accommodate so that others can use them as well.
The only file I had to add was the 'ui_igo8 folder'from DPHursts mod in order to get his schemes to work in your mod. He truly has the best schemes ANYWHERES. You have choices of all seasons and all weather conditions. Your mod by itself would work perfectly with my 'Insane Red Theme' but the mod nor any of the settings would not be matching red, just plain ugly default black. So, what I did, was take all the corresponding bmp's in your 'DATA.zip' file and colored them to match my theme. The only coding that was changed was in the SYS.txt file to accept my 3D car.
Wow! You went through all those images fast. Nice work man. Good to know all of those images are a folder away. Do they change seasons automatically or is that done via that theme changer thing I have heard about?
Alex
