When you hit record, it does not seem to do anything! I was hoping that when recording, it would log a .csv file that I can register in AVIC Feeds to log the drive report. What does hitting the record button do? and where does it record the info? Also, in the settings, you have the option to hit RUN button which has several links such as 'File Explorer', 'Opera', etc. How do you get 'File Explorer to work? I tried having testmode on the SD card inserted, but it does not pick it up
That has been an ongoing problem. I still, and many others on these forums, have yet to figure what it is. The problem, I have narrowed down, is directly related to the same reason the trip computer is not working. When the trip computer is working the saving of the log files will work. It saves a trip that you can go back and play it back like a simulation. Its pretty cool. I have had it work once which tells me the code is good. I am thinking it might be a problem in the ezrider.exe at this point but I am not sure. Even with IDT's mods he has had people pop up saying the trip computer is not working. I have tried messing with the logging paths in the sys.txt, deleting save files, changing the order which the ui files load and have come up with nothing. Just not sure where to go from here.
As far as the run command goes here is a quote from Stanislavovich:
Stanislavovich wrote:
TMC button must be in the Destination screen. it is unhided if vBeta equal 1 or 2 (EW or AU), Please check that you do not switch on TestMode in the Regional Settings. it must be OFF.
To run any application you must copy it in any next folder
\Storage Card\Programs\
\Usb Disk\Programs\
\My Flash Disk\Programs\
and rename it into "application.exe"
