Looks nice David.
What's with all the greenery? All I saw in AZ last week was desert tan and a few golf courses scattered about. And even those weren't that great with the fall grass.
Pretending! ![]()
Looks nice David.
Pretending! ![]()
For those having trouble with getting the sky to show up, I'm almost sure that without the 3D zoom controls for tilt you may not get this to work.
Here is what I would do, it should be a one time deal. Copy my sys.txt into the apl/igo folder using your original 3.0 data.zip, this will turn off smart zoom and you should be able to use the on screen tilt controls to pan up and down on the map and get the tilt set to where you see the sky.
Shut the unit down, copy over the new data.zip file and the tilt setting should stay and you should now be able to see the sky and have it stay there.
I don't have a picture for this, but its pretty cool. Messing around last night and did a new front end theme in red. This has the US Flag in the cockpit screen area and top and bottom bars are in red. link is in the first post under the original data.zip. Enjoy
How about a union jack for your British followers!!! ![]()
Get me a good picture and what colors and I'll do it up real quick..
Forget the British bit,how about the cross of St.George for the English!!
What color do you want the top and bottom bars, red?
Yes,I think the red looks great.Thank You.
On the front page download and let me know if you want any changes..
How did you get the street sign icon on the bottom left to show?
Thanks,
Bryan
How did you get the street sign icon on the bottom left to show?Thanks,
Bryan
replaced the .bmp with one of my own.
David thank you very much for that.I can't try it out because I think there must be a problem with the download site(can't download any file from it at the moment)Will try again later.Thanks again,much appreciated.
Hi David.The only thing that I would like to change is the progress bar.I have managed to reposition it to where i want,but can you tell me how to change the colours please?I want the bar to be sometning like vivid blue or green,with the marker bright yellow or orange.TIA.
You will need to edit the colors using a paint program and then create the alpha layers for them
Hi Dpdurst,
your mod looks really great! Would love to test it, but I am overwelmed by the pletora of themes. So I have a couple of questions, but first my data - you must be frustrated looking at other threads
Firmware 3.02 regular update
Right now IDTs new Mod is installed
AVIC -F900BT European
1. Do I need to unzip the GFX-Folder?
2. Does the huge amount of data you serve reduce the reagibility of the system? Does stuff get slower?
3. Can I copy all teh themes, or should I delete some, befor I install?
Last not least, the stuff with the flag looks really good.
thanks and greetings
jojool
Bryan
Do you rememeber where on navigatemap the bmp is?
Bryan
The sprites are the key
;route name and housenumber(next and the third road name)
;navigation.has_route map.follow x=20 y=8 z=10 w=600
Hi Dpdurst,
jojool
1. GFX folder gets unzipped and then the folder is moved to the Unit
2. I don't know, I don't notice much. I think the unit is slow most of the time due to the BT stack from what I pay attention to. Turning off the BT phone seems to make it even faster.
3. You may be able to copy all the themes, but it will take some space. I removed all the poi, maps, building etc that I'm not using and then removed all Dem files but NA. The themes themselves stay zipped up and moved the scheme folder as you may already know.
Thanks, will give it a try as soon as my wife lets me
Have to go out to eat tonight...
Was just uncertain about the GFX folder, the rest is clear to me. Which theme is on your pictures in the first post? Like that alot.
Hi dpdurst ,I really like your mode but I have a problem when pass 10 mph gives me this message(system detected improper connection of parking brake)already changes the speed in pioneer .ini to 256 but still receiving the message what can I do to fix it .I was using IDT mode and have no problem.Thank You
Thanks, will give it a try as soon as my wife lets meHave to go out to eat tonight...
autumn day bright
Tengo un problema con el USB, después de instalar el mod.
El mod no es 100% de mí, pero funciona, el problema es que no reconoce el USB y también bloquea la unidad cuando puse mi USB.
Cualquier solución?
Tengo un problema con el USB, después de instalar el mod.El mod no es 100% de mí, pero funciona, el problema es que no reconoce el USB y también bloquea la unidad cuando puse mi USB.
Cualquier solución?
Use the Sd card slot. I don't speak espanol, but I think he is trying to install a mod with USB???
David.Good morning.Just wanted to get this back onto the front page so others can see it.Are you still working on it or do you think it is about perfect?
