Stan/Andr2000 v3.0 main screen by dpdurst - update 3/15/10
By dpdurst · Oct 13, 2009in Completed Mods/Themes💬 155 posts👁️ 38,999 views
Page 6 of 7
Posted Dec 15, 2009 · 21:29 UTC#126
I gots a question though...can anyone tell me what the icons in the middle-left of the screen that pop up are?
Here is a pic of one below, I also get like a "no left turn" or "no right turn" icon randomly, but i know they don't apply to the streets i am on, because they don't necessarily come up at any intersection or turn off and when it does you can def tell it doesn't apply to that intersection (ie: you CAN turn left or right).
Also is trip computer supposed to store data between power cycles? When I turn my vehicle off and back on, it seems trip data starts over, but it seems it would be possible to make it preserve the data as speed logs are preserved between power cycles. does anyone know? or maybe mine is messed up and its supposed to?
thanks!
I'm sure the arrows etc are turn restrictions and i think they are provided by the map provider ie Teleatlas or Navteq.Try turning them off in visual settings to see if they go away..
Posted Dec 15, 2009 · 21:56 UTC#127
They are turn restrictions, and map data is (usually) correct. This particular build of iGO, however, displays them pretty much randomly (there must be some system to it, but we haven't discovered it so far).
Posted Dec 16, 2009 · 22:33 UTC#128
I added an option to turn it off on mine and defaulted it to that. You might want to do the same if you haven't.
Posted Feb 03, 2010 · 12:24 UTC#129
Just wondering what the white circle is for, next to the mph. Is this where the speed limit will display. If so, it does not show up, maybe because I'm using Navteq maps.
Posted Feb 03, 2010 · 14:23 UTC#130
Yep its for the speed limit and if not showing up its due to the maps.
Posted Mar 15, 2010 · 13:59 UTC#131
Updated the data.zip with the Dec 02, 2009 changes from Andr2000.
This pretty much is the end of the mods I am doing for the unit. Enjoy.
Posted Mar 15, 2010 · 15:18 UTC#132
Hi
I apologize for my language .... I'm from Polish.
Will you help me change the cursor (arrow) to cursor (car VOLVO S80 (BLACK))
THANK YOU FOR HELP
Posted Mar 15, 2010 · 16:14 UTC#133
Hi
THANK YOU FOR HELP
In IDT's mod, on the first page, there are exact instructions.
Posted Mar 15, 2010 · 17:11 UTC#134
THANK YOU FOR HELP
You can insert a link?
thank you
Posted Mar 15, 2010 · 20:26 UTC#135
THANK YOU FOR HELP
thank you
-currently this has the subaru impreza rally car as the default 3D car
to change the 3D arrow to a car model
download the 3DCars.rar file on the download link provided and extract it
and you have to edit the sys.txt
change the current values of this
Code: Select all
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
to this
Code: Select all
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
and add this part to the [3D] section
Code: Select all
car_day=hot_rod_red.mdl
car_night=hot_rod_red.mdl
ghost_day=hot_rod_red.mdl
ghost_night=hot_rod_red.mdl
you now have to transfer the desired carmodel and tex file to the gfx folder in the data.zip and change the names of the above code to your selected car model name, i haven't tested every car model out as i already like the hot_rod car, but it's just a trial and error thing
Posted Mar 16, 2010 · 10:49 UTC#136
Here is the awesome Stanislov/Andr2000 v3.0 setup with a new front end to it. I love the new changes they have done for 3.0, but never liked having the big screen on the left of the main screen when not navigating so as you can see below in the screen shots I have done some modifications. Current screen shots below show non-navigate and navigate mode of operation.
Not sure where its going next... gonna play some XBOX with the wife for a bit.
I'll update the newest Andr2000 as soon as I see if some more updates come out.
Currently uses the Dec 2, 2009 Andr2000 change
3/15/10 update
1. Click and hold the bottom street sign causes screen to black out
2. Click and hold Time during non-navigation toggles date and time
3. Other fixes by Andr2000 for this version
10/29/09 update
1. Next and Current street backgrounds match with transparency
2. Clock moved under speed, new cockpit background
3. Satellite icon upper right corner (sat dish shows status sat dish shows status) when no navigation,
And 2 vertical bars when navigating
4. GPS screen has globe with satellites around it now color of sat wings show status
5. Fixed MPH readout so when using Kilometers it will change to KM/H instead
6. Return to Cockpit button is on the map plan screen left side
A. New ezrider.exe that should now show correct altitude in feet up to 21120 feet
10/21/09 update
1. Added route progress bar when in navigation mode and also will show up same place during simulation mode. Upper right of screen white/black bar and orange icon moves from left to right. To enable go into visual settings and advanced settings toggle on or off
10/19/09 update
1. New icons added for street and next waypoint and also GPS on the screen
2. Top and Bottom for street and next street show more details
3. Street on bottom if to much is on the line it will animate and scroll
4. Added new speedwarn icon that is bigger
5. Freeway signs are now smaller and don't take up so much room. Don't overlap icons on right
10/14/09 update
1. Fixed the issue in navigation mode, clicking on the clock or time under the speed will toggle through 3 settings, current time, eta to destination and ete to destination
2. More alignment fixes in the cockpit detail screen
10/13/09
1. Time format when not navigating moved to top right with new background. This hides when speed cam warning fires off and shows distance instead and also hides when you have a route running.
2. Added GPS screen access by clicking on top right of screen where GPS icon is. This works only when GPS icon is present.
3. Removed big Cockpit on left of screen during non-navigation modes and added small speed and speed limit screen that matches and lines up with main cockpit during navigation mode
4. Added my shortcut icons across top of screen with new icons.
5. Changed icons on right of screen to new picturs
6. Added delete route and new mute speaker icon when route is present
7. Added shortcut to access day and night mode schemes easier.
8. All icons fade out after a few seconds. Compass does not.
9. Clicking on the speed icon still brings up the cockpit mode display and I have positioned the readouts vertically to be more inline with each other.
All schemes and other stuff you can find at the bottom of this post
Download the data.zip here - update 10/29/09 http://www.gpssoftware.us/avic/stan/data.zip
Download the data.zip here that has front end US flag theme - update 10/30/09
Rename the file to data.zip - http://www.gpssoftware.us/avic/stan/data_flag.zip
Download the data.zip here that has front end Cross of St George theme - update 10/30/09
Rename the file to data.zip - http://www.gpssoftware.us/avic/stan/data_cross_st_george.zip
Unzip the sys.zip file and copy to the apl2/igo folder and then copy the new font to the apl2/igo folder
If you running the new Andr2000 3.0 mod then you don't need the below files you already have them. However it won't hurt if you copy over the ones you have or just want to replace them.
Download the sys.txt file - http://www.gpssoftware.us/avic/30/sys.zip
Download font needed with this mod as well - http://www.gpssoftware.us/avic/stan/digital.ttf
To get the sky and such going you need to get the files listed below and have the sys.txt listed above. All the schemes are modified to show solid 3d color buildings if you have the appropriate building files:
Testmode files needed to get into the unit. Unzip and copy the testmode folder to SD card
http://www.gpssoftware.us/avic/30/testmode.zip
1. Hacked EZrider.exe for the 3.0 - update 10/29/09 - Should now show ALT above 1 mile as feet
Unzip and copy the ezrider.exe to the APL2\igo folder
http://www.gpssoftware.us/avic/30/ezrider_alt_mod.zip
2. New GFX folder - 9/30/09, unzip and copy the folder into the main APL2\igo folder -
http://www.gpssoftware.us/avic/30/gfx.zip
3. Tons of new Schemes unzip and select what you want and move to the APL2\igo\content\scheme folder
Updated on 9/17/09 5:50pm, now show textured buildings. Removed 2 that didn't belong, small size now.
http://www.gpssoftware.us/avic/30/scheme.zip
Updated Schemes II and Night Schemes available now 9/29/09 - Download, unzip and copy to your existing scheme folder. Download the new GFX folder update above #3, new schemes II are for all 4 seasons and should have the textured buildings, the new night schemes have new and more clear backgrounds for the following skies: clear, rainy, cloudy, fog
1. Schemes II
http://www.gpssoftware.us/avic/30/scheme2.zip
2. Night Schemes
http://www.gpssoftware.us/avic/30/night_scheme.zip
Do you have the link for December for your latest update?
Jimbo
Posted Mar 16, 2010 · 11:44 UTC#137
succeeded!!!
ovalball - thank for help
Posted Mar 16, 2010 · 19:29 UTC#138
THANK YOU FOR HELP
thank you
Code: Select all
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
to this
Code: Select all
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
Code: Select all
ovalball, I haven't put this theme in yet (but I will be in the next 48 hours!) and am still running on the unofficial 3.0 FW but would like to change the arrow to 3d cars. I couldn't find this code in the sys.txt file but I did find it in the pioneer.ini file. Is that where the settings need to be changed? Mine currently looks like this...
3d_scale_carmodel=1
3dcarsizemin=2150
3dcarsizemax=2150
3dcarsizemul=40000
...and of course there is no [3D] section as you mentioned. Should I just wait until after I install this theme or is it easy to explain how to install 3D cars on the stock 3.0 FW?
Thanks for your help!
Posted Mar 17, 2010 · 14:53 UTC#139
Jimbo
Yep its right on the first page under the pictures?
Posted Jun 01, 2010 · 22:54 UTC#140
hi
i have a avic f500BT US version..
when i put the new data.zip my gps locks when appear this box : GPS system in progress..plz wait!!
anyone can help me? or have any suggestion? i really want to use this mod..
the problem is with the data.zip..when i put the sys.txt..gfx folder..etc..my gps works properly...
plz help,,,
thanks,
Adriano
Posted Dec 11, 2011 · 16:53 UTC#141
This is an outstanding interface upgrade... and my favorite!
it's very clean and usable, plus it's fast.
just make sure you only load the maps you need for overall system performance.
Posted Dec 11, 2011 · 20:50 UTC#142
This is one of my favourite mods.If only we could incorporate it into Avicnet.I would be one happy 411er!
Posted Dec 17, 2011 · 18:13 UTC#143
I have to disagree with putting Avicnet into it. I tried running the Igo Primo and was VERY dissapointed. The Avicnet seems to be close to the same ordeal. What this does is incorporate all the old crappy nav systems that are on sub $99 systems and puts them on the Avic. All these old nav systems do not compare to the updated modded Systems that we have running here. I had a buddy in my car for the first time and he said that my Avic (with my Abb 5.0) was the best looking NAV system he has ever seen in a vehicle. If I would have been running the Primo that I was before, he would not even have noticed as it looks and operates the same as any sub $99 external Nav system out there. I was initially going to put TomTom in with my 5.0. I tried it for a week and was depressed at how Generic the TomTom system looked that I deleted the file and thought, why would I be going backwards by putting a 10 yr old program into my Avic, with few, if any changes graphically.
Posted Dec 17, 2011 · 20:19 UTC#144
Hello abb1 I agree with you has strength to play the sorcerer's apprentice they are going to break them
Posted Dec 18, 2011 · 11:26 UTC#145
Youre probably right Abb.However after all the fantastic efforts by Ryar(still ongoing?)I am happy to stay with it until things are at thier optimum.If not we have all the fantastic mods which yourself,Chuck,IDT,Diafita,DPDurst, and many others to rely on.I am just happy that this forum is still going and welcome any new ideas.Some may work and some wont,but that is better than a dead forum IMHO.
Edited Dec 18, 2011 by ovalball
Posted Dec 18, 2011 · 18:13 UTC#146
I agree with you totally! Ryar has done an excellent job keeping the interest in this forum going with the Primo and Avicnet (it is just not for me), as it has sparked interest into this forum and kept it rolling. Unfortunately, I think that these mods are at their limit now. I may however, get back into modifying the Avic graphically again, once I get really bored with my V5,0 :)
Posted Dec 19, 2011 · 08:58 UTC#147
Edit: Comments removed. Ovalball is right, as he usually is. It is the holidays and there is no reason to bicker.
Edited Dec 21, 2011 by ryar
Posted Dec 19, 2011 · 09:24 UTC#148
As a user,rather than a modder,I love the Avicnet interface.I accept that there was ,and in certain aspects,still are teething troubles with it.This is the reason why I will always be more than happy to try things out on my european unit which will hopefully be of some assistance to the real stars of this forum,the modders.Unfortunately some stars see thier status as more important than others....but thats life!I hope we can all carry on together and continue to make Avic411 a great site to visit,and contribute.They may well be other potential stars out there itching to put thier ideas forward.Lets not put them off by letting this forum develop into a war of words.It is Christmas after all,good will to all men and all that.
Posted Dec 19, 2011 · 14:13 UTC#149
Got to completely disagree with the sentiments expressed here. Ryar's work with Primo and then Avicnet are the only developments keeping this subforum alive. They also happen to be by far the most professional looking mods dragging our units somewhere up-to-date in terms of graphics, UI and general usability. The old Pioneer interface and map display is verging on embarrassingly dated if you have anything approaching a modern car. Unfortunately most mods just add layers of visual and functional confusion.
Edited Dec 19, 2011 by palexr
Posted Jan 14, 2012 · 08:54 UTC#150
Stanislavovichs' Mod is almost certainly the best that has been done for the Avic. These other mods have no visual finesse - a mix of fonts, some garish, some at times unreadable, and icons/symbols that have been culled from various sources and have no common theme or fluidity. And way too many toys/gimmicks that, if played with whilst driving, would cause even more unneccessary accidents.They each have certainly taken up lots of time but I see the end results and think even the stock version is better.
Edited Jan 14, 2012 by dumpystig
Page 6 of 7
