IDT skin#2 v3.0 12/30/10 (download link updated)
By ill.die.trying · Oct 25, 2009in Completed Mods/Themes💬 442 posts👁️ 72,478 views
Page 11 of 18
Posted Feb 21, 2010 · 00:31 UTC#251
abb1,
How did you zoom in like that in the image? Did you turn off smartzoom?
Posted Feb 21, 2010 · 01:29 UTC#252
Coreplayer should work. I extracted it from leetlauncher. What's the name of the script that you modified and where is it located?
1) create a script,
run 'START_APPLICATION "\My Flash Disk\APL2\iGO\name_of_the_exefile.exe" ""'
2) change the onrelease command on the off button to the name of your new script
3)put the exe file in \My Flash Disk\APL2\iGO\ and change the file location in the script you created
I appreciate your help. I have another question. How do I zoom in to make the car fit perfectly on the road as shown on the image on the first page? I tried adjusting the smart zoom settings but I can't zoom in close enough, the car image is alot bigger than the road.
i always have smart zoom turned off and use the knob (pressing up or down) to set the zoom setting
Posted Feb 21, 2010 · 01:30 UTC#253
IDT,
Just wondering, Can the off button be change for a zoom in/zoom out button?
yes
Could you please consider it for future releases?
not sure why you don't want to use the knob to adjust the zoom?
Posted Feb 21, 2010 · 01:31 UTC#254
abb1,
yes, use the volume knob up or down to get the zoom that you want after you turn autozoom off.
Posted Feb 21, 2010 · 03:09 UTC#255
abb or idt,
hope this isn't 2 lame but i want a different sky for night like abbs big moon, in your instructions you say to replace sky.bmp in data file but i thought you could change schemes from one to another, like abb said he had fifty he could change on the fly (which i hope to learn to do) so which should i o to get different skies for day and night? change sky.bmp or change schemes and just load lots of them like abb? am i missing something? i have read and read?
Posted Feb 21, 2010 · 07:18 UTC#256
IDT,
I didn't know about the volume knob. That is why I suggested the zoom in/out feature. Well, since I learn something new today, please disregard my suggestion.
Sorry!!
Posted Feb 21, 2010 · 10:15 UTC#257
abb or idt,
An easier way is to add DPHursts Schemes. He has the best schemes out there ranging from weather conditions to seasons AND he has my Big moon incorporated in two or three of hisw schemes. You have to adjust IDT's Data.zip by adding an 'Igo8' folder that is in his Data.zip and add it to IDT's Data.zip for them to work. It is a little work, but it is well worth it as he has the best sky's and night skys out there.
Posted Feb 21, 2010 · 10:15 UTC#258
abb or idt,
An easier way is to add DPHursts Schemes. He has the best schemes out there ranging from weather conditions to seasons AND he has my Big moon incorporated in two or three of hisw schemes. You have to adjust IDT's Data.zip by adding an 'Igo8' folder that is in his Data.zip, and add it to IDT's Data.zip (or Diaftias Data.zip, whichever you use) for them to work. It is a little work, but it is well worth it as he has the best sky's and night skys out there, as ytou can see by some of my screenies.
Posted Feb 21, 2010 · 14:50 UTC#259
very cool. i will start on this now. then i must learn how to make the shortcut button and scroll thru schemes on the fly. i looked through a lot of the code last night for the button functions but will work on it when i can give it my full attention.
Should i start a thread on this? Maybe get a "how to" thread going.
Posted Feb 21, 2010 · 17:53 UTC#260
Abb, I got this going, almost,
i moved DPHursts 'Igo8' folder but i also had to copy some of the contents of his gfx folder because i was getting errors on the schemes due to missing LeSScro & Xerses72 folders. I have had these files downloaded for awhile but did not know how to use with other mods (thanks). Once i copied those folders over most of the schemes work,
problem is that i still do not get the big moon or hardly any moon. most of the skies look the same for night schemes, just black with dark clouds. Some do have a small moon. It looks like i have the sky image in place but not the moon image. i downloaded your schemes from your "Abb's 'Insane Red' Theme *UPDATED- DARKER - 11/10/09" and read where you give the name of the scheme but the moon is not there for me in any scheme, not the big moon.
Did I miss something or do you think i may need to re-download DPHursts stuff? I searched for it but all i finde under "DPHurst" are posts by you...
Posted Feb 21, 2010 · 17:59 UTC#261
To I.D.T.
Love your mod my friend. Up to now I have only used Diaftias
I am sending you some coin out of next paycheck, just like Diaftia, i wish it could be more but i want you to know your work is appreciated by me.
Thanks..
Posted Feb 22, 2010 · 00:26 UTC#262
I believe the theme is called GJ2N NIGHTSKY, or something like that. There is also some in his new schemes folder labled new moon or one of them. I will have to see what the name of them is. Are you using his latest schemes? Do you have the rain, pollution, fog themes?
**OK, I just checked and those themes were DPHursts older schemes, not his newer ones. I will see if I can get them for you.
Posted Feb 22, 2010 · 01:00 UTC#263
yeah, i found the correct name and downloaded everything he had under "Stan/Andr2000 v3.0 main screen by dpdurst" thread. I have been working with it all day and only some will work. i could compile a list but basically the large majority do not show sky at all. the ones that do work are in the "night scheme folder" none of the pollution, winter cloudy, etc.. even show up when i copy them over.
i really want to get this so anything you could help with would be great. i was wondering also if you could point me to the file to edit the code for the off button change to schemes on the fly?
Posted Feb 22, 2010 · 01:03 UTC#264
....just got your P.M. on the button, thanks
Posted Feb 22, 2010 · 03:00 UTC#265
The seperate GFX folder has to be installed in the APL2\igo folder by itself and NOT in the Data.zip which has the same folder but is different. I am sure that is your problem. Sorry, I put that folder in my APL2 months ago and I even forgot that it was there. Basically to have the schemes function properly, you must have the igo8 folder installed in your Data.zip file and the GFX folder in your APL2\igo folder along side the Data.zip file
Posted Feb 22, 2010 · 04:21 UTC#266
it has to be my igo8 folder or the older schemes then because i have it structured that way and i dont get sky on a lot of the schemes, i basically have three folders download from "Stan/Andr2000 v3.0 main screen by dpdurst" thread
1. schemes
2. scheme 2
3. night scheme
nothing in schemes works, they have blank skies
i think most everything in the other two folders works.
Posted Feb 22, 2010 · 05:21 UTC#267
oh.. and none of the john cougar, monopoly,etc... works
Posted Feb 22, 2010 · 08:49 UTC#268
You have something messed up, I will see if I can send you my schemes and DATA.zip when I get done work. That should work providing that you hgave the GFX folder proerly installed
Posted Feb 22, 2010 · 14:19 UTC#269
I actually copied everything from Hurst GFX file and put it in IDT's GFX file. I did this to clean up the Igo folder.
I was having the problem with the blank skys when I would switch to IDT's schemes so I also change the Igo/GFX/night sky to a sky of my prefrence. I modfied the moon with an image editor to make it larger.
I put the Igo8 folder into IDT's data zip as well.
The only thing I cannot figure out is where the GL2 schemes are coming from in the GFX file.
Any advice would be great.
Oh and all the schemes are functional, I don't have all of Hurst schemes, because I don't change schemes very often
and if you download all the schemes it seems to slow down the scheme changing file on the Avic.
Posted Feb 22, 2010 · 14:45 UTC#270
That should work providing that you have the GFX folder proerly installed
I think I do, if having it installed correctly means copying it to the APL2/igo folder. I have that. I may just revert back to my last backup and start over with your img.res, data file, igo8, etcc...
let me know when you get of work, rainin g here so i will be in most of day repairing laptops...oh joy, joy..
yes, the more you had the longer it takes to render the list. Glad you are having more luck than me. I think i will try starting over with a different igo8 folder and see if it helps, until i can get some verified working files.
Posted Feb 22, 2010 · 20:15 UTC#271
How do u just install the fuel calculation ?
Posted Feb 22, 2010 · 20:22 UTC#272
what mod are you using?
Posted Feb 22, 2010 · 20:40 UTC#273
dpdurst 3.0 mod v1.5 Final
Posted Feb 22, 2010 · 20:43 UTC#274
i will try to create a how to regarding this for those who want to add the fuelcalc on their own mod, no ETA's as i'm busy right now but i 'll do it when i get a chance
Posted Feb 22, 2010 · 23:15 UTC#275
Page 11 of 18
