This stuff is flipping brilliant, I went from being really ****** off at the whole thing since it knackered up during the official update, right now its all running and its allllll good
Anyway, a quick question regarding the overlay trip computer in the latest EU update (thanks Merten
) - I press the time and it pops up and looks great, but how exactly do you switch it off? I would have thought pressing the clock again would do this but it doesn't - it is switched off another way?
Secondly, the display mode seems to keep flicking back to 2D - once again is this me doing something wrong or is there a setting I can change?
Cheers guys! top mod!
Each of the boxes in the trip computer are shortcuts. The very last one on the right hides it again. The second to the last one resets it.
As far as the map goes (if I recall correctly) it saves your position when you are navigating and not navigating. Just switch it in both places and you should be fine. Let me know if this is not what you are seeing and I will look into it.
Alex
Great thanks
Gonna add a couple more foibles to the mix...
1) When in the speedo view or the dash view (and probably more), I don't get a number in the blue island circle, so don't actually know which exit I need to take, is there a setting in the files I can change to put the little number back in because as it stands your cant actually navigate in these cool modes (well I can't since I don't have any voices working)
2) Is there any way to keep the user voice muted? mine isn't working right now but still mutes the music for a second while it would be saying something, and i click that little speaker and it puts a line through it, but this setting doesn't stick... any way to keep it on (or off as the case may be?)
Thanks guys
Oh and by the way, each trip info box being a shortcut? brilliant!
