Diaftia's Hybrid mods V2.3 - UPDATED: 01/14/10
By diaftia · Dec 01, 2009in Completed Mods/Themes💬 1,194 posts👁️ 195,795 views
Page 26 of 48
Posted Feb 12, 2010 · 03:40 UTC#626
Upload Links no good :(
Posted Feb 12, 2010 · 09:26 UTC#628
Hi there!
First of all, thanks for putting together this great mod pack! I love almost everything in it!
The only thing I liked better from the original (european) avic were the sounds made when touching the screen. Could anyone tell me which files in Diaftia's mod pack should be replaced by the originals to get all the mods but keep the original touch screen sounds?
Regards,
Kees.
Posted Feb 12, 2010 · 20:07 UTC#629
Here's an interesting find:
Can somebody else confirm this?
Thanx!
Bud
Bud,
can't say I can confirm, but did some interesting find myself: this morning, voice guidance was mute only (happens often when it was cold outside). The only solution to remedy this is to reboot. Unfortunately, rebooting means I have to turn the ignition off. But after I did this, the trip computer worked!
Now I was wondering: would it be possible to issue a soft-reset from within the application? Perhaps another shortcut on the menu, but I do not know which command to use to issue this reboot command.
In the Testmenu there is this reboot button, but that one calls Restart.exe in the testmode utils.
Anyone has a clue on how to add this to this mod?
Weo
Behind on my own thread but this is in the next version.
Posted Feb 12, 2010 · 20:09 UTC#630
Is there a thread that talks about how to edit the locations of the speed cameras. There are several indicated in the gps that don't exist on the actual street. I tried the delete button but that does not seem to work.
Put the cursor on the map screen on the icon for the speedcam. Then go into the quick menu, then to route then to info. On that screen you will see edit cam. Select that and hit delete.
Posted Feb 12, 2010 · 20:14 UTC#631
Thanks for all of the hard work, Alex!
I did notice one thing peculiar, however maybe it's me but when I go into the visual screen and I get to the point where it says switch on/off transparent (opaque in the previous rev.) background images they still look transparent regardless of this setting. Also, just for my own preference, I am removing the "zoom=1000" from the signboards. I like to see them big. That's my pref. though otherwise I am looking forward to your latest rev!
Posted Feb 14, 2010 · 14:35 UTC#632
Hi Alex, I noticed a fuel calculator in IDT's mod. Is there any chance of adding something like this in your mod?
Posted Feb 15, 2010 · 06:18 UTC#633
hi all, I'm having a problem and hoping someone has a simple solution. I can now access the gps address features, but the gps and system settings are greyed out... I currently have the 3.01 with Diaftia's mods installed. I had troubles with the hardware bypass screwing with the software, so I currently don't have the e-brake wire connected, do I need to ground it or something? Should Diaftia's mods have given me access to the gps and system settings???
Posted Feb 15, 2010 · 08:13 UTC#634
you should read the bypass thread before doing any mods as you're just getting yourself in trouble jumping ahead with mods
Posted Feb 17, 2010 · 19:43 UTC#635
Sounds like you have a problem with your save files. The setting definitely works. Tried it on the way in this morning and also just now in an emulator. Clean out your save files and it should work again. FYI- You will be able to delete save files from the GUI in the upcoming version.
FYI if you make the signposts any larger they will overlap on the right and left signs and nav info.
Posted Feb 17, 2010 · 19:45 UTC#636
Yes that will be in there. Working with 34by151 on a bunch of stuff since he had some things that he had been doing with my mods. The fuel calc and autokarta stuff is all going to be in there. He has also been working really hard to make it so that we will no longer need to have 3 different versions. All of the MSN/TMC and EU/US stuff will be settings that are configurable now.
Posted Feb 18, 2010 · 02:37 UTC#637
Hey, Alex,
I noticed another **glitch**
All of my speedcams default to 70MPH and displays 66 (I've had this before as this is normal when importing the .txt files into the TA maps) but when I click on then speedcam to change it when underway, I change the number and press "done" and even though the slider registers the number I changed it to it will still display and announce the previous "70miles Per Hour" and display the "66" in the box.
Just an FYI.
Thanx!
Bud
Posted Feb 18, 2010 · 06:43 UTC#638
When I installed the official Pioneer update it showed 3.0020 for my EU device, I'm now running the free update from the EU page which takes it to 3.00202.
I have never seen official versions below 3.002 here in Europe.
I think this might be one of the problems people are having with hacked updates: there are 3.001 and some people say they even have 3.003 which can definately not be a Pioneer update as it was around before the official one. In some "hacked" or "free" update packages people seem to mix pioneer data with CE updates which do not really belong to our devices, just becouse it has a higher release no. it must not be the right CE for us. That was for me the reason to buy the official update, I wanted to have a clean basis to restore if anything goes wrong.
Just my observations from reading a lot in this forum, I'm just a user, tell me if I'm wrong
Jörg
I just check my AVIC-F7010BT and the version is 3.020100 official US Pioneer update.
Posted Feb 18, 2010 · 06:49 UTC#639
This is exactly how to delete nonexistent cameras. There were several red light cameras in my area that have been removed and I deleted them from the map. There were also cameras on some freeways (don't ask my why) but I deleted several of those.
If you have a problem putting the cursor on the camera zoom in as close as you can to make it easier to select. Goog luck.
Posted Feb 18, 2010 · 09:16 UTC#640
I just read through the Aussie thread. I thought your updates were near perfect but now I see that so more more can be added. I can hardly wait for the next version. Thanks for all the great work.
Posted Feb 18, 2010 · 16:09 UTC#641
I'm not sure if this issue has something to do with the the Diaftia mods or not but I have the most updated version them installed on a f500bt and everything seems to work great except..
I can't get the software to read the mp3s on the SD card. Nothing shows up in the media list though I have about 50 mp3s on the card in some folders and nothing else. It was working previously and now it's not. Is there a way to reset the media database so it scans the card again? Thanks!
Posted Feb 18, 2010 · 17:00 UTC#642
quick question with v2.3 can I incorporate IDT's 3D subaru instead of arrow.....only thing stopping me from pulling the trigger...thanks
Posted Feb 18, 2010 · 17:42 UTC#643
Hey, Alex,
Just an FYI.
Thanx!
Bud
I have seen this too. You have to actually click on the map on the map icon you want to edit and then go to the quick menu POI info to edit it. I have been trying to make it so you can edit them through clicking on it but it has to do with where the cursor is when you edit it. I think. I added that in as a convenience but I think its not possible. Strange that it pulls it up but doesn't actually edit it.
Posted Feb 18, 2010 · 17:44 UTC#644
Sometimes its people adding in known speed traps where cops hide. The easier thing to do is go to in and configure the alerts to not notify you on those. Its the icon with the badge (or car) and radar. I think its the second one.
Posted Feb 18, 2010 · 17:45 UTC#645
Have you done any other mods? My mods are navigation level mods and those are pioneer level issues. I would look in the troubleshooting forum maybe?
Posted Feb 18, 2010 · 17:47 UTC#646
Yes, I think you might need to incorporate the whole 3D cars thing. I know there are some threads on it and that IDT at one point even packaged up the 3D cars thing to port to other mods. Not sure if he still has that available or not.
Posted Feb 18, 2010 · 18:28 UTC#647
the link is still up, you can find it in the IDT thread, instructions are in there also
Posted Feb 19, 2010 · 03:50 UTC#648
Most of the freeway cams I deleted were not in "hiding spots" they were out on the open freeway, no bridge, overpass, trees, bushes or anything like that around. Usually here in So. Cal. we rarely even see CHP because there are so few of them around. I think some people are just idiots that got pulled over so they added a camera. I only found one so far on the freeway where a cop could hide and sure enough there was a CHP there.
Posted Feb 20, 2010 · 04:18 UTC#649
After a few hours of messing around with the data.zip, I finally figured out how to incorporate 3dcars and use "Run Application" feature. The media player that comes with leetlauncher is very useful wit this mod. I'm now able to view divx movies with coreplayer thanks to diaftia's mod. My next goal is to add the shortcuts to the quick menu. Diaftia, it'll be great if you can show me which file to modify in order to launch applications within the quick menu.
UPDATE: I found the file associate with quick menu but it looks pretty hard to add an application to the quick menu. Diaftia, Is there an easier way to do this? Perhaps, you can add a feature to the quick menu so that users can configure their own application to launch. Thanks again for such a nice mod.
Posted Feb 20, 2010 · 12:54 UTC#650
Can you please put a step by step on how to do the 3d cars? I tried following idt's but can only modify the sys text
Page 26 of 48
