Diaftia's Hybrid mods V2.3 - UPDATED: 01/14/10
By diaftia · Dec 01, 2009in Completed Mods/Themes💬 1,194 posts👁️ 195,795 views
Page 32 of 48
Posted Mar 19, 2010 · 14:10 UTC#776
Does anyone have the original files from an x910bt that are replaced by this mod. My SD card is corrupt and my backups are not readable. I need to restore my unit to factory so I can return it unmodified. Thanks for any help with this.
I was going to PM you the files, but the maximum file size is 2mb. So unfortunately, I think you are SOL since the file size is 5 mb for the original DATA.zip and the SYS.txt
Posted Mar 19, 2010 · 15:39 UTC#777
Are you taking about the data.zip files or the entire flash drive?
Posted Mar 19, 2010 · 17:35 UTC#778
I'm looking for the original files (as replaced in the instructions for this mod) or any that were overwritten by the process. I need to return it so as it appears brand new and unmodified.
from APl2\iGo (5 files titled "bnt.ttf", "DATA.zip", “Branding.zip”, “Digital.ttf” and "sys.txt" )
from APL2\iGo\Content\Speedcam ( 3 files here Red_Light_Camera_us.txt, Speed_Trap.txt, and SpeedcamUpdates.spud)
from APL2\iGo\Content\Voice (file Voice_TTS-nua-eng-us-f1.zip}
from APL2\iGo\Content\SCHEME (Copy 4 files here Pioneer_red_day.zip, Pioneer_red_night.bmp, Pioneer_blue_day.zip and Pioneer_blue_night.zip}
Posted Mar 19, 2010 · 18:03 UTC#779
try this:
http://browntownpr.fileave.com/downloads/APL2.rar
hope that help!
**keep in mind that some files from this mod were addons.
Posted Mar 19, 2010 · 18:48 UTC#780
ok i overwrote the current apl2 folder with this one. all appears to have went well. what files should i remove that were not there before ?
Posted Mar 19, 2010 · 19:49 UTC#781
just remove the one i did not put on the zip file.
Posted Mar 19, 2010 · 20:35 UTC#782
So Essentially, I should just delete the current apl2 folder and paste this one in it's place ?
Thanks for your assistance.
Posted Mar 19, 2010 · 20:42 UTC#783
No. I just post a few files only.
just overwrite the files with the one i post it and done.
Posted Mar 19, 2010 · 21:28 UTC#784
I noticed when I had cockpit overview on or whatever its called, I no longer have the option to mute or delete the route from the icon next to the quick launch menu...
Posted Mar 22, 2010 · 17:16 UTC#785
I am so happy. This was what I looking for.
I have a europ F900BT with firmware 3.ooo.200
- The only thing i cannot see is with map (year-Q) is in use. By "info" gives he the pioneer map dates :?
- The start-up time from the unit is a "little bit" (30 sec +/-) longer :?
- how I can import (with place) POI's. I have tried with KML poi on SD and in the POI map but he did not see this
POI's :-(
- Another strains thing are the local (normal) time is fine but the time of arrival is 1 our to late??
But first of all thanks from a happy user
Posted Mar 22, 2010 · 20:12 UTC#786
In full screen cockpit mode. That is correct. Click on the turn indicator (large nav arrow) and there will be an avoids screen with the buttons at the bottom.
Posted Mar 23, 2010 · 09:11 UTC#787
Could someone tell me what that number next to a small house icon indicates on the main map screen? (on the screenshots in the first post the number is 9089 i think)...
always a slight difference between the number on both sides too... i thought maybe it was distance to home but that doesn't make much sense and you wouldn't need to see that anyway so i'm thinking its something else...
any ideas?
Posted Mar 23, 2010 · 12:03 UTC#788
any ideas?
They are house numbers on the street. They are not 100% accurate, but it gives you a ballpark idea
Posted Mar 23, 2010 · 14:57 UTC#789
Hi,
Sorry for my bad english as i'm french.
First of all thank you for this awesome mod i'm using on my f500bt.(v3.0202)
I've two question regarding this mod.
The first one concern the speedcam audible warning.
There is an overspeed tolerance setting wich is great, i set it to 5kmh however i still earing the warning beep each time i 'm overspeed by a least 1kmh.Any suggestion? Can someone explain me exactly what does the different setting between alert and warning as it is pretty obvious what do reminder end desactivated.What is the verification beep?
The second question is more a custom setting.
As i've using a f500bt, i wanna if someone know how to custom the enter button(middle of the pad) because right now when you push it the unit repeat the last vocal instruction. I'm want to use it to pause the music on the sd card or mute it. I'm assuming it can be done by editing the sys.txt but maybe it is more camplicated. So the enter button can act by order of preference of what is possible to set or not as :
-Pause button for the sd card
-Mute the whole avic
-SD card off/on
So if anybody have any suggestion regarding this it would be really welcome.
Florian
Posted Mar 23, 2010 · 16:22 UTC#790
Hi diaftia,
thanks for this amazing mod ! I have a question about the TTS voice, I am in France and so I use Voice_TTS-nua-fra-f1.zip. What have you modified in your TTS Voice, is it possible to do the same for french TTS voice ?
Dts1
Also for the dutch?? :oops:
It is a really a great mod special when somebody now a solution for "my" another problem.
Thanks a lot
Ron
Posted Mar 23, 2010 · 17:11 UTC#791
Hey there,
Having trouble with the Trip computer. It doesnt seem to be working.
No actuals show up in the trip computer except for the speed.
Is there something i need to turn on to get this working each time?
Or something i need to put in a certain folder.
Any help appreciated!!
Posted Mar 23, 2010 · 17:25 UTC#792
Alex, I've now read from Page 1 to Page 35 and installed the mod two days ago. I'm loving it and have not had any of the problems that others have run into (just stuck with the old "measure twice, cut once" philosophy). I do have a question about the zoom settings though...and please know that I've searched the entire thread for "zoom" before posting this.
I use Smart Zoom and I've pushed both sliders all the way to the right so that I can see the sky background. But when I zoom in using the knob the horizon line raises up and covers more and more of the background. I noticed in the 2nd picture you posted from the first page that you are zoomed way in tight but you can still see the sky and the trees/buildings that are also part of the background image.
Can you help me get to this same viewpoint?? Thanks for everything by the way. This is an amazing mod!! Donation coming soon...
Posted Mar 23, 2010 · 22:48 UTC#793
Can you please put a step by step on how to do the 3d cars? I tried following idt's but can only modify the sys text
Add the following codes below to sys.txt then put the .mdl and .tex file of the car you selected in the "gx" folder of Data.zip. Make sure 3dcars is in the Igo folder.
[map]
3d_scale_carmodel=1
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
[3d]
;change the .mdl file to the car you selected
car_day=flying_carpet.mdl
car_night=flying_carpet.mdl
ghost_day=flying_carpet.mdl
ghost_night=flying_carpet.mdl
[3dcar]
work_dir="\My Flash Disk\APL2\iGo\3DCars" location of 3dCars folder
mortscript="\My Flash Disk\APL2\iGo\3DCars\Themechanger\MortScript.exe" ;location of MortScript.exe
I followed these instructions exactly and I do have a big rig now instead of the arrow symbol. The only thing I was unclear on is when you said "Make sure 3dcars is in the iGo folder." What I did was extracted the file I found on another thread titled gfx 3DCars.rar into a new folder called 3DCars. Then I moved that folder into the APL2/iGo folder. Is that correct?
The reason I'm questioning the change (since I do have a 3D car now) is that I noticed that under Settings, Route there is an option to change the car but when I change the setting to Taxi or Bus it doesn't change anything. I was hoping this would allow me to change the car through the UI instead of having to go back to the sys.txt file every time.
Also, I lost my sky background and am now getting the "overcast" look mentioned earlier in this thread. I did go and imediately deleted all save files except favorites but it didn't come back. Need help on a few items here obviously. :(
Thank you!
Posted Mar 24, 2010 · 12:07 UTC#794
Hey there,
Nobody, to my knowledge has solved the trip computer issues. Some seem to have no problems with it while it does not work at all for some others. What seems to work is start the AVIC and wait till the gps has fully acquired before moving that car at all. This works for me but I rarely do it. You can assist by reading and searching the forums. If you find a solution let us know we are happy to try it in the new version
From our testing it the problem appears to be in the ezrider.exe. If you call the trip compuer before the gps has aquired it crashes the tripcomputer portion of the ezrider resulting in blank data being fed back. We have been trying a number of things in the code to replicate the above fix (not moving) but as yet have not succeeded. Ie preventing th code calling ezrider till the gps has aquired. I'm hopeing to include this in the new version but no promices as it not really a fix for ezrider but a work around for an ezrider bug
Cheers
34by151
Posted Mar 24, 2010 · 17:27 UTC#795
Hey there,
Cheers
34by151
Is it possible to put a pause or a "wait" of sorts to the sys.txt?
I know that the trip computer is in conjunction with the tracklogs. Since my unit was new this function would NEVER work unless I waited for the unit to fully boot (around 2min.) and I rarely ever wait that long before I shove off.
I am anxiously awaiting a fix for this because this is the one mod that I really love except I can rarely use and it is quite frustrating :x
BTW, what program do you use to disassemble the EZrider for editing?
Bud
Posted Mar 24, 2010 · 18:03 UTC#796
First I must say, very nice mod!! I haven't had a chance to try it out yet, but the look is great. I just have one question. Where do I turn off the illustrated text? Like I said, I haven't tried the nav out yet, but if I run into the memory problem I want to be prepared. Thanks!
-Brian
Posted Mar 25, 2010 · 00:40 UTC#797
The illustrated text can be turned on or off through the UI now. I believe it is under Nav Settings and then Navigation.
I'm still having a problem getting the sky bkgd back. I've reversed everything I did with the 3D car and my data.zip and sys.txt is back to the format supplied by this mod. The only other thing I've changed prior to losing the sky was I deleted all other state maps, poi's and buildings other than CA, AZ, NV, WA and OR. I was hoping that would free up space. Is there anyway that deleting these files I could lose the sky??
Btw...I DID go delete all the save files again (except favorites) and that didn't resolve it.
Posted Mar 25, 2010 · 14:40 UTC#798
It is so beautiful mod. I love it. Really Diaftia (I will look how I can give you a donation)
.... But .... :?
I didn't have sound from the route-system. I can listen to the radio enz. but the Navy didn't tell anything. Also no bieps for/from buttons.
The loudspeker icoon is on the low left corner and no red line in it. When i push the street in the top from the display the radio stop but nothings happens only a red line in the loudspeaker. :evil::(
When we driving the radio stop bt changing of situation but no noise form Nav?
I think it isn't the voice. I have also not a beep from buttons in Nav. When I go back to radio I have the beeps form buttons for the Pioneer part.
The sound from nav stay on max.
I think also the TMC didn't works. He give in the left corner from the line a blue point, but that is all.
No files or anything else.
I have the European version from the F900BT,
Everything stay on Dutch (that is the reason for this bad written :? sorry
Firmware version Pioneer 3.002.xxxx
I use the Igo 2009.9 maps Europe
and have download (and install) the europ version from this mod.
Is there anybody they can help me... please.
Thanks again
Ron-nl
Posted Mar 26, 2010 · 13:40 UTC#799
Alex,
I am having a problem with the skyline showing up on my unit. I have read this post from page 1-54 and still can't figure out what I have done wrong or if maybe it is my X910BT having a slight difference from the F-series units.
Have you come across this before? I have tried moving the sliders and turning off the smartzoom and nothing seems to work. It also looks like the map has snow on it. Instead of the terain being green it is white while in daytime mode and at night the terain turns black. Has anyone else had this problem? I deleted all of my saved data when I installed, even the favorites.dat file. I have no Idea what I could have done wrong.
Thanks,
Rob
Posted Mar 26, 2010 · 16:49 UTC#800
To all that are just now starting to get problems with the sky:
As you can see this version of the software has not been changed since January. Now all of the sudden people are starting to get problems with the sky. Since nothing has changes since Jan and these problems are just now starting to crop up, have you done any other mods? Have you tried copying the files from my zip back to the AVIC and see if it fixes the problem?
I have had people have problems when they start adding other peoples variations of my mods to their units. Obviously if you have problems with someones variant of my mods you will need to ask them. Otherwise I will see what I can do to help.
I think it was AVICAddict that asked how to zoom in tight to the road. To do this turn off smartzoom. Then touch the map to get the map rotation arrows and use the up arrow to zoom in really close to the road (or just push up on the knob). If smartzoom is off it will stay in that position when you go back into map follow mode.
Page 32 of 48
