Diaftia's Hybrid mods V2.3 - UPDATED: 01/14/10
By diaftia · Dec 01, 2009in Completed Mods/Themes💬 1,194 posts👁️ 195,795 views
Page 6 of 48
Posted Dec 09, 2009 · 21:48 UTC#126
here it is 'On Route'
Posted Dec 09, 2009 · 23:45 UTC#127
Hmm I see what you mean. I just did it in an emulator. It certainly does zoom out to the full level and then come right back down. I will take a look at it. Thanks for finding it.
Thanks for taking the time to check it out and address it.
M
Posted Dec 10, 2009 · 00:10 UTC#128
NICE! Can you send me that image?
Posted Dec 10, 2009 · 01:52 UTC#129
yeah NP, pm me your email address and I will send it
Posted Dec 10, 2009 · 05:28 UTC#130
Hi Alex. Great mod as usual.
Little glitch. In the overview mode, I have no problem with it doing the close up after I'm within 3mi (my setting) of the next instruction. It then goes back to overview, 2d, north up. Good. The problem I have? The cursor (car icon) stays in the 3d, heads up, position. It should move to the center of the screen. Its terrible when heading south, you only have a half inch of map showing. Any ideas? Thanks again.
Posted Dec 10, 2009 · 06:47 UTC#131
As for the signposts... just grab the signpost files from another mod. N-S-E-W added some transparency to the images I am using and you should just be able to replace the images if you don't want it.
Alex
vansmack2 - The bmp for signposts on page 4 does not have any transparency. Extract it from the zip and paste it in your common folder. Don't use the laneinfo_signpost.ini unless you want blue sign posts.
I got it and will give it a try. Thanks.
Posted Dec 10, 2009 · 19:01 UTC#132
UGH! I thought I got all of these! Can you give me the steps to reproduce it? Settings and map views? I should be able to get it when working on getting the overview and smartzoom stuff working.
I went and looked at Stanislavovich/Andr2000's current release. Looks like they may have seen these bugs before because in the current release they have removed the ability to turn off smartzoom at all. Probably related to all these variables being hard to trace down. I am going to try to work this out but I have a feeling it might take a bit to work out. IMO this stuff is where the code starts to get complex.
Posted Dec 10, 2009 · 19:03 UTC#133
Same here... email addy is in the first post.
Posted Dec 10, 2009 · 19:09 UTC#134
Set a route thats a distance away. The instructions will take you to a highway or whatever, then when the next instruction is more than 3mi (my settings) it goes into overview mode. Once within 3 mi, the zoom in mode works again as usual. Again, the problem is the position of the cursor when in overview mode. Hope this helps.
Posted Dec 10, 2009 · 19:23 UTC#135
Here ya go, I sent it by P.M. as I had a problem emailing it to you. Luckily it is small enough that it can be pm'd
Posted Dec 10, 2009 · 19:29 UTC#136
So you are you in 3D mode, it switches to 2D mode (overview) then back to 3D when within 3 miles of the next turn and that is when its off?
Posted Dec 10, 2009 · 19:41 UTC#137
Today I noticed somehow I lost TMC.
Is it removed? if so...How can I add it again? If not where can I find the settings to turn it on again?
Thnx
Posted Dec 10, 2009 · 20:36 UTC#138
Thnx
Two things...
1. Make sure sys.txt has the proper device set at the top (most likely cause). You can do this with notepad before copying it to the unit.
2. Make sure that the regional settings are set properly in the navigation unit itself.
Posted Dec 10, 2009 · 22:05 UTC#139
2 images I made for mine. Camera makes it look meh but looks Great in person. Red with carbon fiber edges.
Funny I'm in my driveway but says I'm 570 feet away from my house. :o
Posted Dec 10, 2009 · 22:32 UTC#140
[attachment=0]IMG_0002.jpg/attachment]
[attachment=1]IMG_0001.jpg/attachment]
Looks good! Only comment I have is that I would flip the image so the CF pattern goes in the same direction as the buttons. I am picky though. Hence the reason I have spent countless hours making sure things line up in these mods. ;)
Posted Dec 10, 2009 · 23:13 UTC#141
The cursor is 'off' the mark when in overview mode. In overview it should be in the center of the screen, not on the botton center. This is what I was referring to.
Also, another item I can't seen to find (or get working). HOw do you save into favorites? Nothing I do let's me go there. In manage mode, the fav's are darkened out, & I find no way to add to them. Thanks again.
Posted Dec 10, 2009 · 23:36 UTC#142
OK... I have it replicated in an emulator. I will look into it.
When adding a favorite it does it off the location of the cursor in the plan mode screen. Before you would click add favorite, then enter the address then save. Now you would go into plan mode, click address and make the location search. Then click the target and add to favorites. Or just click the
A little shift in thinking on the usage. That is the way the add poi, pin and road blocks work too.
Hope this helps.
Alex
Posted Dec 10, 2009 · 23:38 UTC#143
I dont understand what you mean. :?
Posted Dec 10, 2009 · 23:48 UTC#144
As usual, thanks Alex. I don't mind a change in thinking. I just needed the re-education. I'll try it out. Thanks.
Edit: And yes, that works. I now can add to fav's. Thanks.
Posted Dec 10, 2009 · 23:51 UTC#145
If you look at the first picture that you attached in your post, the lines of the red CF slant upwards to the right. The white buttons in the same picture show the CF slanting upwards and to the left. I believe Diaftia was saying that it would look better if the red pattern also went up and to the left. I think that would make it look better too. But It still does look great! Good Job!
Posted Dec 11, 2009 · 01:44 UTC#146
I have both bugs fixed with overview mode. The map centering when it goes up to 2DN mode and the bug when you are in 2D and it zooming out and back in. It was actually easier than I thought it was going to be, just took some thinking. I will try to get an update posted in the next few days while I make sure it didnt break something else. ;)
Posted Dec 11, 2009 · 03:03 UTC#147
Ahhhh....I see. Didnt even notice that. I was going to make some small changes anyway so I'll fix that too. Have to start over though because I forgot to save the stupid thing before I flattened it. :oops:
Btw, the only thing thats carbon fiber is the top and bottom bits. The red is just a pattern I found. 8)
Posted Dec 11, 2009 · 03:51 UTC#148
With the update, can you also change the code to 480 instead of 580 for the 'current street - no route'. I tried 520, and 500 and neither fully cleared the bluetooth icon with the longer street names. 480 should be good. I will test it out tomorrow
Posted Dec 11, 2009 · 03:54 UTC#149
You can just flip the image in photoshop and then save it
Posted Dec 11, 2009 · 05:22 UTC#150
Does anyone know the best way to look up an address if you don't know the city?
I live in Chicago and know the city very well. Every so often I will need to go to a particular address in the suburbs.
Let's say I need to go to 123 N. Main Street... It won't let me look up an address unless I know the exact city, or suburb. Unfortunately sometimes you might think the address in one suburb, but it's in another.
On my old factory nav if I put in 123 N. Main Street it would list that address in cities in texas, florida, illinois, etc and I could choose the one I wanted.
Has anyone experienced this situation?
Page 6 of 48
