FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 14 of 36
Posted Aug 21, 2010 · 03:21 UTC#326
The link is right there on the first page :lol:
Posted Aug 21, 2010 · 09:28 UTC#327
It's EU or US version?
And what's new in this fw?
Posted Aug 21, 2010 · 13:08 UTC#328
US. But you can change the maps to EU anytime after.
What's new? Search!
Posted Aug 22, 2010 · 20:59 UTC#329
I just picked up a 700bt on ebay from cowboom for $200. I installed this without a hitch, I haven't been able to test GPS yet since it is coming the mail (was a missing part). My 700 came in like new condition, I am excited to try some of the new Mods here!
Posted Aug 23, 2010 · 01:54 UTC#330
Thanks so much Retell for this easy made update. It worked like as easy as it can be. Few things on my mind:
I lost all my Mods I did for my 3.0101 fw. Will those old mod files work on this new one?
I kinda liked speed limits, shortcut icons on the screen and few other things that is missing on this update..
any one?
Thank again to Retell for you hard work. Appreciate it.
Posted Aug 23, 2010 · 05:11 UTC#331
can i use this update on my avic 700bt
Posted Aug 23, 2010 · 12:30 UTC#332
Yes this works on the 700
Posted Aug 23, 2010 · 18:33 UTC#333
ROCK AND ROLL.
Guys, thanks so much for this fix!!! I've been driving around with the goddamn reboot every 5 minutes for the last month, and then I stumbled across this fix. Everything seems to be working fine on my 700BT now.
I guess now we'll just see how long it lasts!!!
Thanks so much!
Posted Aug 23, 2010 · 23:27 UTC#334
can i use this update even i haven't update resently my pioneer avic 700bt. sorry if i have too many question just wanna make sure before i even do this. thank you
Posted Aug 24, 2010 · 00:54 UTC#335
Yes and that is what this update is for ...
Posted Aug 24, 2010 · 16:28 UTC#336
i have a f900bt and live in canada .. will this matter or is this update for USA only ?
Posted Aug 24, 2010 · 16:35 UTC#337
North America ... Canada included!
Posted Aug 24, 2010 · 16:46 UTC#338
thanks chuckie gonna take the plunge and see if the results give me a nice looking dash ornament or a awesome update.. :)
Posted Aug 24, 2010 · 17:03 UTC#339
one more question .,. theres a my flash disk folder in that file plus a test mode folder along with 3 seprate files.. the question is do i put the test mode and the 3 files in the MY FLASH DISK folder before i put it on the SD card ?
Posted Aug 24, 2010 · 21:14 UTC#340
Wowwww mrcool, make sure that you understand the whole thing before proceding ...
I think that you have to put all 3 files in the root folder of your SD card along with the TestMode folder, and the AVIC embedded updater will update your WinCE for you. You don't copy those 3 files to the "My Flash Disk" yourself!!!
Afterward, you then copy the whole contents of "My Flash Disk" of your SD card to "inside" the "My Flash Disk" of your AVIC.
Be careful not to cook your AVIC. Read first post man!!!
Posted Aug 27, 2010 · 20:11 UTC#341
Anyone have a rear view camera installed to their unit with this version? I've installed my unit with the camera all together and the unit wont switch automatically to rear view when I put it in reverse...
I did a multimeter test on the reverse wire and I'm getting 14.XX juice when in reverse so it's getting a signal and everything is connected right, but it just wont switch. Also, I'm getting an image when I manually input the rear camera in the AV section and I get a constant rear view image when the settings is set to ON and GND on the system settings/ rear camera
Can anyone confirm if their camera works on this firmware update?
Posted Aug 27, 2010 · 22:45 UTC#342
thanks chuckie .. its all good .. the update took very well .. looks nice .. thanks all for the update !!! :o
Posted Aug 28, 2010 · 02:52 UTC#343
Change the polarity of the camera within SYSTEM or A/V settings ...
Posted Aug 28, 2010 · 02:53 UTC#344
You're welcome and I'm glad to help.
:D
Posted Aug 29, 2010 · 07:26 UTC#345
thanks for this everything A-OK!
Posted Aug 30, 2010 · 14:06 UTC#346
Hi, thanks for the reply. I tried changing the polarity manually on the system settings, rear camera, from On-PWR to On-GRN. After I did that, everytime I turn the car on it would automatically turn on the rear view camera and it stays on, regardless on what gear I'm in. I have to do the hold map or menu button a few seconds to bounce me back into the settings or else no matter what I touch, the rear view cam screen stays on.
Posted Aug 30, 2010 · 17:30 UTC#347
Did it work correctly before FX 3.1, say with the stock software and OS?
Posted Aug 31, 2010 · 03:39 UTC#348
I see that nobody answered dvine1. Can someone take a stab at it? The reason I ask is my F-90BT stopped working out of nowhere with the Pioneer 3.0 installed and after trying to reinstall the Pioneer 3.0 software again I am getting this exact problem. I am going to try the 3.1 but my question is will it solve this? Thanks in advance for some to help out on this.
I followed the instructions that you have for this install, but when I get to step 5 and reset, nothing happens. My unit just comes back up with the splash screen; I can get to the "top menu" but then nothing responds. I hit "settings" and go to system info and it shows version 2.06 and for map version, it says "no maps loaded" When I try to get into testmode (with another sd card that has the testmode files), it gives me a 'windows-like' screen that looks like it's copying something then the system goes blank. I don't have a clue what to do next. Any help would be greatly appreciated.
Posted Aug 31, 2010 · 17:37 UTC#349
Just an update.
Installed Retell's files and all went well until the it rebooted for the last time. I got the dreaded "Caution: Image screen may appear reversed". Well the screen could still be touched with a audible response and I just started touching random places. Well it ended up doing a language quick boot into Spanish but at least I got the damn screen to show. Changed the language back to English and all is well. I have not tested it completely out but the phone at least syncs. Report back after a couple of days of use.
Posted Sep 01, 2010 · 14:05 UTC#350
In fact I didn't try it with the regular factory OS.
If I download the OS from Pioneer from their website into my SD card and install it, will it overwrite everything or only certain component?
Would Pioneer have a problem with working on it if I send it out for repairs? I know it won't be on warranty but it's only $80 to get it serviced.
Page 14 of 36
