FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 15 of 36
Posted Sep 01, 2010 · 14:10 UTC#351
Just an update.
Installed Retell's files and all went well until the it rebooted for the last time. I got the dreaded "Caution: Image screen may appear reversed". Well the screen could still be touched with a audible response and I just started touching random places. Well it ended up doing a language quick boot into Spanish but at least I got the damn screen to show. Changed the language back to English and all is well. I have not tested it completely out but the phone at least syncs. Report back after a couple of days of use.
Im not sure if it works for everyone but for me, when it happens (Turn on the car and the rear camera comes on automatically ...or a black screen with the message) I usually hold the map or menu for a few seconds. it will switch to the deck brightness control, just hit the menu button again and you'll be able to see the 3 icons and from there, go to settings, system setting, rear camera, and then change the polarity to PWR or simply turn it off if you don't have a rear view cam.
That should fix your problem
Posted Sep 01, 2010 · 16:10 UTC#352
Thanks for the tip.
Now that I have had some time with this all I am going to say is WOW!. :shock:
Everything works as it should have with the 3.0 update (sarcasm on: Thanks Pioneer).
I had a very buggy system before and now it all works. Retell you need some compensation for your time and saving me some frustration. :mrgreen:
Posted Sep 03, 2010 · 06:44 UTC#353
I installed the 3.1 update just fine, along with Abb's v3 mods. Now when I attempt to make/receive a phone call the unit partially freezes giving me an error about the "Tel" file. Testmode also won't work, it keeps getting stuck in a "bootloop" of sorts. I've tried several different types of testmode.
My question is, can I use these instructions:
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
7. Press and hold reset for 5 seconds.
8. Select your language and voice options.
9. Enjoy FX3.1
to boot into testmode and try to replace the damaged file?
Posted Sep 06, 2010 · 06:14 UTC#354
I do not get it. I am another that is having a difficult time with this. Whenever I start the process, the multi colored blue screen appears for a bit. Then it goes right into the WinCE OS screen. So I attempt to start from that point. I do everything as said. It is very difficult to touch the screen to select stuff on the desktop. I cannot even select the "Start" button. Before overwriting the contents of "My Flash Drive", I get a screen that says the contents will not fit. So I take out a few maps...Hawaii, Alaska and Puerto Rico. Still to big. I say screw it and overwrite what I can. I then Press and hold reset for 5 seconds. I am then met with the damn WinCE OS again. What gives? I have the AVIC f900BT.
Posted Sep 06, 2010 · 20:51 UTC#355
I noticed there are some F500 owners able to do this mod. Could you please indicate your service combination keys to allow access to the WinCE update menu? I tried the one posted in this thread UP, UP, DOWN, MENU, LEFT then RIGHT but was unsuccessful over and over again.
Please post if you use a different combination. Or PM me.
Posted Sep 06, 2010 · 23:35 UTC#356
Hey there guys, newbie registered but ive been doing a fair bit of reading before I registered....just have a question or 2
Im in Australia, just bought a US model F700bt.
I plan on using the FX3.1 firmware on it just want to confirm that it will work properly, along with the Australian map updates found on here
(V3Update03 parts 1 and 2 files...I've downloaded all the files i need, along with the Update02b files for the skin.....havent installed them yet because i wanted to confirm that I had everything i needed to get this underway)
and that i just follow the instructions and copy over 3.1 files, use the autoinstaller for the maps v3update03 files and then copy over the update02b files
and that this will give me 3.1 firmware, with the Australian maps and updated skin etc.
do i need to download the speedcamera or poi update files as well or will the above do it?
I know questions like this have been asked, but just wanted to confirm for my situation! thanks heaps
Posted Sep 09, 2010 · 11:26 UTC#357
For all with problem" READ PROGRESS 100% and nothing happen... (AFTER STEP 4....)
Try to FORMAT SD CARD and copy once more all files to the ROOT. I have solved a problem with format SD card
My AVIC F900BT now running on 3.1FX, thanks for this mod.
Posted Sep 10, 2010 · 12:59 UTC#358
Just wanted to drop a quick thank you to Retell for this post and the torrent. I had made a real mess of my system "trying to fix it" the other day when it decided to get stuck at the startup screen. The firmware update from Pioneer just caused the system to constantly reboot and then when I got creative things went downhill in a hurry.
Luckily this post has a valid torrent associated with it and all the files I needed to completely restore my headunit!
Posted Sep 10, 2010 · 20:01 UTC#359
OK after some digging around in all these threads with weird headings, I was able to find the service combination for F500BT unit.
I found it in this thread. http://avic411.com/forum/viewtopic.php?f=34&t=27581&start=60#p206891.
MAP, MAP, MENU, ENTER (Press down on the joystick), MENU then ENTER.
Here is the other helpful item from that thread. You can only use the RESET button in this service menu.
So to move from option to option, you press RESET quickly one by one. To select, you hold down RESET for 1/2 second or so.
When it ask for you to reset, hold both RESET and POWER for a few seconds until it reset.
I was able to flash the new WinCE and copy over the My Flash Disk from OP. Everything seems to be working so far.
Good luck.
Update!!
Now that I had a chance to fully tested, there is no guidance voice on the F500BT like the two previous F500BT users posted on this thread. I noticed something was weird when the sound volume is really low.
I guess the hacked EZRIDER in this rar file is not fully compatible with F500BT. Guess back to the drawing board.
SUCCESS!! WOWEEEE!! Everything is a success! I found the issue and fix the audio issue.
Please following this instruction for the F500BT model. I was very successful.
You need only a single SD card, at least 2GB in size. Copy the entire contents of the RAR file except for the WINCEIMG.BIN and WINCEIMG.CKS to the root of SD card. For the two WINCE*.* files, I had to use the one I download from this link. http://www.rapidshare.ru/1206567
The one that came with the FX3.1 would not allow me to boot after I flash WinCE>
You will need to go to the folder APL2\iGo\ and delete the current sys.txt and rename sys_749UC.txt to sys.txt.
You can delete the other sys_*****.txt files and any maps that you may not use. You may need to do this because the F500BT may not the capacity for all the new maps.
1. Insert SD card (minimum 2GB) with testmode into AVIC and turn it on.
2. Backup My Flash Disk by copying
3. When the pioneer logo comes up, press and hold the power and reset buttons at the same time until the blue service screen comes up then release power and reset buttons. (you should see Press reset again to reset but don't press reset yet)
4. Press in this order MAP, MAP, MENU, ENTER (down on joystick), MENU then ENTER. (each button press will show an asterisk at the bottom center of the screen). If the correct combination is pressed, then a menu with options pops up.
5. Select Wince Upgrade with Format (SD)
6. At the bottom center will first display the status of reading in the file. It then will clear the message and will show the status of writing the file. Then it will do a quick test. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in (remember to reset you have to press and hold both power and reset buttons.)
7. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
8. On the desktop should be an icon to RESTART the unit. Double click on that to restart, make sure you take out the SD card so normal boot process happens.
9. Enjoy FX3.1 :)
A special bonus, I was able to download the latest 2010 maps from here http://gpsunderground.com/forum/showthread.php?2688-iGo-8.0-and-8.3-Navteq-And-Teleatlas-Map-Download-Index.-All-here./page25 into the F500BT without any issue. You will need to delete the older maps and just copy the MAPS, POI and BUILDINGS to the respected folder under /APL2/iGO/CONTENT
Really GOOD Luck now and enjoy to those able to succeed.
Posted Sep 12, 2010 · 02:43 UTC#360
So i ended up hooking up my US model f700bt to my computer power source to do all the updates while i waited for my wiring harness to arrive. its now cleanly installed in my subaru forester, with the FX3.1 on it, software and hardware bypass (coz i didnt know i had the software one on their!) and the australian v17 maps. I also have the CD-IU230 running under the handbrake compartment to a small pocket near the centre console with a little stand mounted in it to dock my ipod in.
The unit is also running a Rockford Fosgate Punch 360 amp bridged to power my MTX thunder4500 in the back. Balanced all the sound and finished cleaning up the install today and am so beyond impressed! soooo happy :D
Posted Sep 16, 2010 · 19:28 UTC#361
Hello All,
After reading carefully through all 24 pages of this thread, I need to ask for help.
I have a EU F900BT unit, that used to run software version 1.9000. I have downloaded the torrents and followed all instructions from Retell.
Everything went fine (test mode, WinCE update, restarted in Windows CE, copied all files over). However, when the unit restarts, it stays stuck at the first screen.
So, I have tried to reinstall by following the entire procedure again. This time, I am unable to start the procedure ! When I select Upgrade Wince (format), I have a red box at the bottom of the screen saying "SDMMC Update Fail!! Any key to continue".
I have tried with another SD card, and I have also tried to format and copy the files on the SD card from a different PC. No luck :-(
Any ideas ? Thank you !
Lili
Posted Sep 18, 2010 · 14:44 UTC#362
^You probly didn't copy the files from "my flash drive" to "my flash drive". You can't copy everything on the SD card directly over doesn't work like that.
Anyways I just wanted to say I installed this update and have continous issues. It will work fine for a week then the GPS will start to lose it. "Return Home" always causes issues AND it no longer reads the SD card. The 3.0 update is nice but definetly not worth the issues for me. I'm desperately trying to find a back up. Didn't realize how to make one untill it was too late. Bummed about that. :(
Posted Sep 23, 2010 · 01:42 UTC#363
hello ok im trying to do this update on to an AVICF-90BT, i got everything downloaded on to a 16gb sandisk untral II sdhc ..... after the torrent download i extracted everything on to the sd card making sure that the extracted contant was the only thing on the sdcard when extracted i had no errors with the extraction and i moved on to trying to installed it... once i get into the update wince i choose option 0: update by sd/mmc (format) and heres where i get the problem ... at the lower center screen it says READ PROCESS:100% and stays there doesnt allow me to do anything else.... i waited for a good 15 to 20 mins and got no results....
i read on other forms that shortly after that it should say something about writing process but i never get to it.... anyone have any ideas on why this is happening?
Posted Sep 23, 2010 · 05:56 UTC#364
Gotta say it.. THANK YOU !!
I just installed an AVIC F700bt in my 95 Lexus this past weekend and it had the original firmware in it (1.00101 or something). The load times were atrocious, and half the button presses didn't even register.. the lag was UNREAL. I don't know how Pioneer could release such garbage.
After following the simple steps in this thread, and using the supplied files, I had the update up and flyin in no time (well, maybe 30 minutes). Load time is still sub par compared to factory units, but the button presses are crisp and fast, the system sounds are way cleaner and accurate, and the GPS much more full-featured.
Again, this has changed my owning experience and THANK YOU!
Posted Sep 23, 2010 · 11:54 UTC#365
Wowwww, a '95 car! I wish I can keep a car like you did! You have to live in the South without snow though.
Welcome to the club!
Posted Sep 24, 2010 · 15:30 UTC#366
I can't remember what page the information was on, but how do we make changes so that then boot time is faster? It was something like not having the OS recheck itself at each startup of something along those lines. I appreciate that the volume knob still works when I start the unit up right away, but it seems that bootup times vary, sometimes going straight to the main menu and othertimes showing the menu but saying that I need to wait while it's still loading. I don't understand why it's so inconsistant, but even if, is there any harm in it not rechecking itself everytime? I'd like to be able to car on the unit, have it fire up in like 10 seconds flat and be off and running vs starting the car, opening the garage, pulling out and being down the road to the stop sign before I can finally start making inputs.
Posted Sep 25, 2010 · 17:18 UTC#367
I tried installing the firmware on my f910bt today.
Everything went as planned, but when I start the unit up after the final step in the guide, it is just stuck at the Pioneer splash screen. :cry:
Any ideas?
Posted Sep 26, 2010 · 11:54 UTC#368
didnt work on avic f700. crashes and screen goes blank after the logo. i was using 3.0, can i go back to 3.0, if yes then do i have to do the same steps as given in tutorial for 3.0 installation, right now my 700 is unusable.
Posted Sep 26, 2010 · 13:08 UTC#369
Any ideas?
Never mind - my EU maps were the culprit.
Works like a charm now 8)
Posted Sep 26, 2010 · 23:23 UTC#370
i think maybe the maps are corrupt. so im trying right now to put 3.0 back with 2008 ta maps , hope it works..
Posted Sep 26, 2010 · 23:43 UTC#371
so i think either the maps or the file is corrupt. just loaded 3.0 works fine..
didnt work on avic f700. crashes and screen goes blank after the logo. i was using 3.0' date=' can i go back to 3.0, if yes then do i have to do the same steps as given in tutorial for 3.0 installation, right now my 700 is unusable.[/quote']
Posted Oct 03, 2010 · 20:03 UTC#372
FX 3.1 worked great on my 700BT, I evern upgraded the maps to 2010 Q2,thanks for the upload!
Posted Oct 04, 2010 · 20:34 UTC#373
I tried this on my f900bt today. Rebooted to "no application databases found" or similar. I reattempted with stock 910 v3 firmware and the error went away but now am in a reboot loop. I am going back to V2 for now. I have read everything from maps to parking brake mod as the culprit (mind you I am relaying my park wire, so I am not sure if that is really the case)
maybe I'll delete the maps?
Posted Oct 05, 2010 · 08:17 UTC#374
Hi, thanks alot for this thread, this is exactly what I need.
Um... anyone seeding? Pirate bay says there is one seeder, but looks like no one is... would very much appreciate it! Thanks in advance!
Posted Oct 05, 2010 · 08:27 UTC#375
k, someone is seeding now. Thank you, you've made my day! I really mean that. And I doubt that you'll ever read this thanks... anyway, I'll seed for a while in appreciation.
Page 15 of 36
