Abb's Chrome NAV Mod V3.25 - Aug 30th '10
By abb1 · Jul 23, 2010in Completed Mods/Themes💬 571 posts👁️ 80,104 views
Page 13 of 23
Posted Aug 25, 2010 · 21:37 UTC#301
hello ABB1, Great work I felicite you
Posted Aug 26, 2010 · 00:27 UTC#302
Thank you, I had to look up felicite in an international thesaurus though, lol
Posted Aug 26, 2010 · 00:28 UTC#303
Congratulate, applaud, cheer! :lol:
Posted Aug 27, 2010 · 19:02 UTC#304
I have also made the text in the menus crisper and easier to read as well as reducing the file size down from 20.5 mb to 19.5 which will improve efficiency as well
Man your brain just doesn't stop LOL,
Looks great, can't wait for the update. Are we gonna get a scheme update too????
Posted Aug 27, 2010 · 21:22 UTC#305
I don't know about a scheme update just yet as I only have one new scheme made and they are very time consuming. After I get this update out, I will try to focus on some new schemes
Posted Aug 27, 2010 · 22:02 UTC#306
Absolutely no pressure on the schemes, just noticed the new one and thought it was cool.
Posted Aug 30, 2010 · 01:46 UTC#307
V3.25 IS UP!!! Sorry it took awhile, but it took a lot of work as there were a lot of changes. I hope you enjoy it.
Here are the changes and improvements. PLEASE RE-INSTALL EVERYTHING PLUS PUT A NEW FOLDER NAMED 'SYSTEM' FOLDER INTO 'MY FLASH DISK' IT IS IN THE .RAR FILE* Please remember, Beer money is always appreciated :D
New Features in 3.25 update
1- AV version is added
2- New graphics for the speedometer screen with speed units
3- New background for Destination Dial
4- fixed an issue that I came across when routing using TA maps. The 'next street' name would overhang partially covering the phone icon. This is now fixed!
5-File sizes are reduced considerably for reliability and responsiveness
6- Menu text is a lot crisper now and more readable in bright sunlight
7- it has a new 'Application Menu' accessible in the Top Menu which shows the 'resource info' while navigating, gives you direct access to 'Total Commander' while navigating. Applications are in the 'V3.25.rar' file that must be installed for the apps to work
8- Enlarged the text of the signposts as they were too small before
9- Non AV version now has the info bar at the bottom with current street fully extended giving more information. The AV version is as before so it can leave room for the AV bar while on route
INSTALLATION: PLEASE REPLACE ALL THE FILES WITH ALL THE FILES IN MY .RAR FILE AS THEY HAVE THE APPLICATIONS, PLUS ADDED INFO NOT FOUND IN THE OLDER FILES, SO ALL MUST BE REPLACED
UK Version 3.25 Update
All the new features titled above PLUS:
*The UK version will come in an AV version only as that is what was requested
1) The color of the freeway signs were changed into blue
2) The traffic alarm signs were changed to Europe signs
3) The position of the speed limit sign was lowered to avoid conflict with the Elevation sign.
4) MSN button has been changed for a TMC button that allows direct access to the TMC menu
Posted Aug 30, 2010 · 04:12 UTC#308
Thanks a mill Abb. and thanks a lot to Chuck88 for pointing me out to this Mod. I used to use IDT till now. But since I went back to upgrade fw with latest version on my F900bt. I lost my mods and I have to start all over again.
Some how 3dcars folder gave me hard time, I deleted most of western states maps and Poi and that gave me almost 500mb free and then I made some mistakes. My system keep rebooting. Formatting SD cards, downloading files again. Eventually I made it work after consuming half tank gas. Same with GPX folder, schemes wont show up. Even now, Pioneer screen shows up and our schemes screen show up for 2 seconds and it will go back to Pioneer schemes. I just was able to pick Abb Day scheme since it was first option on your schemes. I hope it will settle down eventually.
Oh yea. finally when I downloaded New Features in 3.25 update it worked like a champ. That system folder is the key.
I love our split screen.
I still miss Quick screen changes from 2D to 3D or it is no more an option?
Also I turned key sound off, it still clicks loud when i click on some icon to select it.
Any how wonderful Job. Kudos. Keep up the good work.
One last question or suggestion: can we have a icon for voice calling instead of using volume knob?
:D
Posted Aug 30, 2010 · 10:28 UTC#309
Hey guys did you notice on the 3.0 mod that if you have the TA maps on the auto correct time is ok but when you use the NT maps we have to set the timezone manualy. Does anyone else have this prob and can it be fixed. I like NT maps better so I always have to change. Time zones manualy when I drive from quebec to new Brunswick
Posted Aug 30, 2010 · 12:40 UTC#310
@bassboy - No, I did not notice that.
@Abb1 - v3.25 is Awesome, plus I got my voice recognition back on the map screen. Believe it or not, I missed that, but my wife REALLY missed that on hers. she uses it all the time. So needless to say, she tried it right off the bat, and is very happy, therefore, I am very very happy. GREAT Job!!!
Posted Aug 30, 2010 · 12:57 UTC#311
When using NT maps it seams to default to Edmonton time zone. I am in New Brunswick
Posted Aug 30, 2010 · 13:10 UTC#312
Hmmm, I use Navteq maps in general as they are superior here in Canada as far as streets go. I have NEVER had time issues with NT maps. There is nothing in my mod that should change that. My suggestion to you is to delete your IGO folder in your user data. That will most likely fix it up.
Posted Aug 30, 2010 · 14:06 UTC#313
Can u tell me what UFO folder to delete? The user data??I did dete it and it still defaults to Edmonton time. As soon as I switch to TA maps the auto correction is on and gives me the correct time
Posted Aug 30, 2010 · 14:17 UTC#314
Hmm, that is weird, it just started doing that to me as well. An easy fix is just to shut auto correction off and have it set to your time zone. I will look more into it though to find out why it is doing that. Unfortunately, I need a day off for that so I can be near my Avic which seldomly happens :(
Posted Aug 30, 2010 · 15:11 UTC#315
lol i had greenland on mine.
Posted Aug 30, 2010 · 15:20 UTC#316
Hey Abb,
Loading the new update today, but had a QQ. Might have been asked in previous threads, but was wondering if you had an option to keep the Source info (Source, and Station/Title) showing all the time in the Map?
With your previous update, i have to hit the AV Show button everytime. Is there a way to have it show by default?
Would that be the difference is the Non-AV, and the AV versions?
Posted Aug 30, 2010 · 15:32 UTC#317
Hey Abb,
Download the AV version!
Posted Aug 30, 2010 · 15:40 UTC#318
For those that are having problems with the timezone in NT maps, is it just with the V3.25 version, or was it with the prior version as well? Also, what map version are you using for NT? The reason that I ask is that I never noticed this prior to 2009Q4 maps
Posted Aug 30, 2010 · 17:19 UTC#319
I am on ver 3.0 as I am on vacation and cznt upgrade to 3.25 untill I get back. I am using the latest q4 from nt and it's working awesome with street signs and everything it's just the time zone seams to be locked at Edmonton when I have it on auto correct. As soon as I change to TA maps all is ok. It's not a big prob fir me as I just have to manualy change the timezone when I go back to Quebec. The nt maps are by far much better here in rural nb than ta maps are!!!!
Posted Aug 30, 2010 · 17:34 UTC#320
Just a suggestion ... did you guys check the default Long/Lat set in SYS.TXT?
I know that TA is OK but NT is not, but just an idea ...
Posted Aug 30, 2010 · 18:02 UTC#321
No, it is not that as I have tested various settings. Also this is a default lat/long setting which should be consistent with both maps. The problem lies in the navteq 2009Q4 maps, not the mod. A fix for this is to permanently have 'Autocorrection' set to 'OFF'. This now works ok when switching
Posted Aug 30, 2010 · 18:18 UTC#322
It is confirmed! The problem definately lies in the Navteq 2009Q4 maps as this same problem exists when trying to switch the maps in my 2.75 mod. Again, the solutions seems to be having 'Auto Correction' set to 'OFF'
Posted Aug 30, 2010 · 19:51 UTC#323
YES so I, "moi" discovered a flaw lol???? just kidding.... it is only a peeve the auto correct is off for me anyways... and when I drive back to quebec Ill just change it back to EST..... cant wait to put 3.25 on...!!!!!
Posted Aug 30, 2010 · 21:10 UTC#324
Thanks Abb for the update.
But how stupid it is ... NT. If you tell that to Pioneer, then they will tell you that they only support TA, not NT :mrgreen:
Posted Aug 30, 2010 · 21:18 UTC#325
Like I said, just turn 'Autocorrection' off, input your timezone, and that fixes it.
Page 13 of 23
