Abb's NAV Mod V4.0 'All-in-One' -- Oct 24th '10
By abb1 · Oct 24, 2010in Completed Mods/Themes💬 376 posts👁️ 72,998 views
Page 8 of 16
Posted Nov 25, 2010 · 17:45 UTC#176
I am also thinking about the Nav settings image. Here is the one compared to the one in the previous post. I set up a poll in the hacks/mods section . I dont like polls, but I really would like peoples opinion on these backgrounds. Here is the new car background
Posted Nov 25, 2010 · 18:44 UTC#177
:mrgreen::mrgreen::mrgreen:
Posted Nov 25, 2010 · 18:47 UTC#178
The only comment that I have is that white characters on chrome or white background is sometime hard to read. So if you could set "color2=black" for the letter edge, it would be more crisp.
Posted Nov 25, 2010 · 19:44 UTC#179
The white text has a black border with a glowsize of '3'. Trust me, it is very easy to read.
Posted Nov 25, 2010 · 20:20 UTC#180
Yeah, I believe that should be fine! :razz:
Posted Nov 26, 2010 · 03:43 UTC#181
Excellent. It's easier to read.
Any chance you can double the clock's font size, for us older folks. thanks
Posted Nov 26, 2010 · 04:11 UTC#182
nah, I would like to have it larger myself, but in the Main/AV interface, we only have the ability to change the pictures, not the UI
Posted Nov 26, 2010 · 04:25 UTC#183
Maybe this is pushing it, but how about a split navi and fm-presets to change to another pre-set station without navi.
If you wander off Windsor way pm me and I'll buy you a pint or two.
Posted Nov 26, 2010 · 12:59 UTC#184
No, can't do it as unfortunately you would have to get into the AV coding to access the fm presets. We are lucky to be able to make the AV bar hide. I already tried for countless hours just trying to get a code so that you can access the AV Source screen from the NAV, no luck :(
Posted Nov 26, 2010 · 17:26 UTC#185
Abb, While on this topic, would it be worth considering enhancing display of critical info as suggested in attached.Order is not important nor is inclusion of elevation except here in BC. I realize space is a consideration to allow for posted Speed Limit. Just a thought for what it''s worth. Sure do appreciate your considerable efforts.
NV1v2.pdf
Posted Nov 26, 2010 · 18:54 UTC#186
It is not a bad idea, except that it will cover a lot of the main screen which kinda defeats my entire idea of my first creation of these mods.
Posted Nov 28, 2010 · 21:03 UTC#187
Well,we are all snowed in at this side of the pond but no posts to keep us going.Somebody must have something to say :)
Posted Nov 29, 2010 · 03:23 UTC#188
It's snowing sunshine here, mate!
Cheers :)
Posted Nov 29, 2010 · 04:36 UTC#189
Cheers :)
You guys have proved that posting in the forum is still working <_< !
Cheers! :wink:
Posted Nov 29, 2010 · 15:54 UTC#190
Hi, Abb!
I have a couple of questions regarding point 6 of the install instructions where you say: "If you are running an F500, or are using a unit in tne EU, then edit the semicolons at the top of the sys.txt file before copying them over to the AVIC".
Fact nº 1: I'm in Europe using an 700BT US unit.
Fact nº 2: I've downloaded the UK version of your "Chrome Nav Mod V4.0".
Question nº 1: Do I need to worry about your point 6 of the instructions?
Question nº 2: If so, I only have to delete the ";" before the line that has "type="PIONEER746EW" ;(EU) F700, F900, F90" and type ";" before the default one (type="PIONEER746UC" ;(US) F700, F900, F90), correct?
Thank you for your answears!
Kind regards.
Edited Nov 29, 2010 by muRte
Posted Nov 29, 2010 · 16:54 UTC#191
Hi, Abb!
Kind regards.
Yes, that is correct, all you have to do is remover the semicolon before the EU version and add the semicolon on the US line
Posted Nov 29, 2010 · 17:08 UTC#192
Thank you very much, Abb!
By the way, what does this little change do to the system?
Posted Nov 29, 2010 · 17:14 UTC#193
It sets the machine up for the country that you are in. It may not even function properly without doing this
Posted Nov 29, 2010 · 20:24 UTC#194
When you put a ";" in front of a line, it comments out the line (i.e. line not used).
Conversely, when you remove the ";" in front of the line, it resumes its effective function.
Posted Nov 30, 2010 · 02:38 UTC#195
Well, I was bored and also sick of the standard 'Destination Dial', so I made a new one
Posted Nov 30, 2010 · 02:42 UTC#196
getting better and better!!
Posted Nov 30, 2010 · 03:57 UTC#197
When is Pioneer waiting for before calling abb and diaftia to offer them something???
:mrgreen:
Posted Nov 30, 2010 · 09:42 UTC#198
Abb that new look destination screen is excellent.Is that the route progress bar along the bottom?
Posted Nov 30, 2010 · 12:56 UTC#199
Yes it is! When I put up my next update, it will be posted as V5 as there are so many graphical changes as well as interface changes, that it really doesn't look like the same V4 anymore
Posted Nov 30, 2010 · 12:57 UTC#200
:mrgreen:
A hackable Z120 would be nice :D
Page 8 of 16
