I am having the exact same problem. Did you find any solution?
I am having the same problem as lordjohn. I am pretty sure I was on 3.0 or 3.1 I was running your mod version 2.3 since last summer. After installing the new mod, I am stuck on the startup screen.
Interesting. Seems three of you are having this problem. Lets do a couple things. Can you also reply with what install method you chose (looking for menu option # based on device and location).
Delete all save files. You can do this on your own or let my testmode script do it. Its one of the options at the bottom.
1. Easiest way to see what is happening is in testmode. Once there navigate to my flash disk\apl2\igo and double click ezrider.exe. That will load it so when it generates an error it should pop something up. Can you let me know what happens?
2. You very well may have ran out of room. Check to see how much free space your unit has. Select the flash disk in explorer and then go to the file menu and click properties. Check to see how much is free.
3. As another test can you verify that all of the files that are in my distribution made it over to your AVIC? Look in the mitacap folder in my zip file and see if each of the files that are in there are on your avic.
Thanks,
Alex
