Anyway of getting my MSN direct back after installing the mod? I installed this mod to see if it would resolve a problem of my phone pairing (enabling BT) would automatically reboot my x910bt. No haps, still reboots after it pairs up.
Diaftia's Hybrid mods V3.6 - UPDATED: 04/19/11 - Now with auto installer.
Hi,
I had a mistake in the packed image.res name. Thanks for your help it fix the Problem.
Alex, Just loaded this today. It's gonna take some time to get used to, but I think I am gonna like it. If I use Abb's GFX folder and his schemes, will they work on your mod? Thanks.
Go into the regional settings and set the traffic mode to MSN.
Sounds like you have a deeper system issue with the BT. Might try holding the reset button and eject button for 5 seconds to do a full reset. Otherwise start a thread in the troubleshooting section.
Give it a shot. You might need another folder from the data.zip too. I think it's the igo8 one.
Say, I'm having an issue with the illumination color not sticking since I did your mod. Is this something that can be fixed or is it another issue? I tried looking for the problem in the main forum but the solution posted didn't work for me.
It worked! I just put his GFX folder in IGO, added his schemes and used his igo8 from his datazip. It gave me his car too. Lookin better and better!
Any way you can take a pic and show me what it looks like? Oh and how big is the data.zip now?
This should absolutely not be effected from my mods. Did you try hitting the reset button? If that doesnt work hit the reset button and the eject button for 5 seconds.
I just updated to this mod... but now Im missing street names on most if not all the streets/freeways. I know there was a way to enable/disable this...
Switch to 2D mode? I never got many street names in 3D even on the stock version.
File size is 16.4mb.
Sorry for the big pic size. Just right click and open in new tab.
Oh does he mean on the map itself? LOL... my bad. I thought he meant on the header and footer. ![]()
I suppose that is day and night. Looks good! I have been thinking about looking into a themechanger so that you can switch those on the fly. We'll see.
Yep, night and day. Abb's themes are really nice. I really don't like the pioneer defaults. Gotta have some pizzaz!
Wow, didnt notice this update...
I know its a long shot, but i have always wondered if its possible to have a split screen mode like what is found in the 04+ Yukon Denali factory/Delphi/Eclipse navigation systems. Here is a pic of it:
Basically, on the right bottom of the screen, it lists your current street. Above that it lists the distance of the next turn, the direction of the turn, and the name of the street. Then above that, it lists the next 2 turns. And when you are close to the turn, the right side of the screen changes, to show you the lane assist picture thing.
For example, if the exit has 2 exits on it, it will have an overlay picture of the exit and will draw a line on which lane to take when the exit splits into 2 different directions
That would be a quite useful split screen. I hope someone figures that out.
The data exists as a route list, the problem is it doesn't update. If you go into route itinerary its there but its static unless it has to recalc the route for any reason.
I just installed this tonight. Wow, amazing.
Is there a shortcut to change day/night mode like there used to be in 2.3 when you held the map icon?
Not currently. I will look into it for the next release. I am running out of things to make buttons. ![]()
Hi Diaftia,
have been on your 2.3 for ages, and now you being back and all is just great. I went thorugh the motions with this 3.1 and 3.2.1, and there is something that is, well bizarre
I very much like your idea of having one version for us and europe, where you can switch between roadsigns. But there already was a quirk in 2.3 (version edited by Merten3000) which still is there in 3.2.1: when selecting to have the Euro freeway signs, and the blue background, this only works on the freeways. On the intersections / ramps / changers or whatever you want to call them, they always revert to green. Past this intersections they go back to blue.
Something else I have noticed: the roadsigns (traffic jam and so forth) do change to Euro, but when I use the large blue signs, these seem to revert back to US, even in the TMC display.
Anyway, thanks for the effort you put in to create this work of art :$
Weo
Is there a way to get back to the Win CE shell using the run app method?
Also, another menu item missing is a setting to change the repetition in TTS. I usually only want to hear one instruction per maneuver but if i'm out of town sometimes it's good to have more instructions.
Every time I mess with v3 I find another menu item, I don't think there's much you can't change by clicking a few buttons. What does AutoKarta do?
Hi Diaftia,
Weo
Man I drove around all day with blue signposts and euro signs on. In route and not in route. Not once did I see green signposts. Is there any thing specific you can tell me to reproduce it? Maybe even a video recorded of it? I have never heard anyone mention this so it's pretty odd.
Have you seen this feature on the avic's before? I know they are chatty which is why I put the default mute in there. If that feature exists I would love it and probably put it in and turn it on by default. ![]()
AutoKarta shows you the difference between two routes if it recalcs because you take a different turn. As far as I can tell its kind of useless. I need to look into it more to make it useful I just havent yet.
Will try to make a video of it, although it will only show the change of colour, nothing else seem to change.
I know you don't live in Belgium, but one spot I am certain of is when I switch from the A12 to the R0 around Brussels (Belgium). Although I have seen it on lots of other intersections too, this is one I take almost every day. This junction around Brussels is a clover-leaf interchange (a 4-way interchange in which inner loops are provided for left turn movements and direct outer connections for right turn movements). As soon as I get onto the interchange, technically I am no longer on a motorway. Perhaps that is the reason the software treats this differently.
As for the other quirk: do you have any idea as to why the traffic signs revert back to US when I switch on Large signposts?
Weo
Thanks for the heads up about the traffic mode setting.
Yeha, I've been battling this BT issue with 2 different Avic's (F500BT and now x910bt). I had posted a thread in troubleshooting before, but everyone blamed my phone even though the problem occurs with ANY phone. I'm so fed up with this thing and Pioneer's useless tech support, I'm about to turn it into a wheel chock.
... I know they are chatty which is why I put the default mute in there. If that feature exists I would love it and probably put it in and turn it on by default.
If you are able to comment out lines in scripts on the fly, you can comment out the lines like "Drive..." or "Prepare..." in commands.csv within the Voice_TTS-nua-eng-us-f1.zip file
Or have a various versions of the Voice_TTS-nua-eng-us-f1.zip file and switch between them.
