Diaftia's Hybrid mods V3.6 - UPDATED: 04/19/11 - Now with auto installer.
By diaftia · Dec 13, 2010in Completed Mods/Themes💬 857 posts👁️ 216,897 views
Page 8 of 35
Posted Jan 04, 2011 · 17:40 UTC#176
Once again I want to thank you for the great work! But be sure to ask - before I have to upgrade to V3, 2 edit SYS.TXT?? I'm in Europe. Thank you in advance Pat
Can you send me your sys.txt file? It appears you are from Prague. The default options will not support that country. I need to make some changes to my install script to support other countries.
Posted Jan 04, 2011 · 17:41 UTC#177
Hello, I'm Italian and i would like to load your skin V3.2 on my F910BT, now I have version 2.3 italian version.
If I put V3.2 I will loose italian language for the entire system (AV, NAV, FM ...)?
Thanks in advance
Gaetano
Can you also send me your sys.txt?
Posted Jan 04, 2011 · 17:44 UTC#178
Yes, I turned on the speedcam option under warnings and did get the legal disclaimer. I also verfified that there is an alarm on the basic camera types. In addition, the speedcam volume along with master volume is also turned on under the volume settings.
I never tried the speedcam warnings on my device and was wondering if they even work on the F500.
Thank you very much for all your help.
They *should*. I have never heard anything about them not working. Did you do a standard install or did you customize anything at all?
Posted Jan 04, 2011 · 17:47 UTC#179
Hi. I'm extremely new to all of this upgrade stuff. I recently installed firmware v2.009 to my f900bt which made an improvement on boot up time etc. After searching the net I came across your mod so have decided to give it a go. How long does it take to install? I have had 1 attempt at which I selected which version and country which installed after a couple of minutes. Then after a few minutes I did the reboot thing and now have no sat nav and keep getting the navgate bootup screen on the display, even though all the other functions still work. I also comitted the cardinal sin of not flashing the memory so I cant go back? Is there any hope for me or have I blown it for the sat nav function?
You need to make sure that you are running 3.0. That is the reason it is not working. Did you make a backup of the flash disk before you started modding? There are a lot of links out there to get the 3.0 files. Definitely get the files to update to 3.0 and once that is done run my installer again. You should be all set to go.
EDIT: Use this link to update to 3.0 and then after that is done copy all of my files to an SD card and boot off of that. Dont worry that this is for a 90. The files are the same.
http://avic411.com/index.php?/topic/22876-fresh-30-install-on-f90bt-with-pictures/
Edited Jan 04, 2011 by diaftia
Posted Jan 04, 2011 · 18:04 UTC#180
Here is the original SYS.TXT - when you buy Avic ...sys.txt
Edited Jan 04, 2011 by patper
Posted Jan 04, 2011 · 19:09 UTC#181
The compass is a button. It changes map mode.
Thank you.
Posted Jan 04, 2011 · 19:11 UTC#182
I will look it over again but you seem to have issues that nobody else is having based on how your system is wired. Maybe his system is wired the same way.
I was unaware these systems were wired in different ways. Care to fill me in? Mines just wired like a standard install, with the ebrake wire moved.
Posted Jan 04, 2011 · 19:36 UTC#183
I wanted the sys.txt that you are running. Is this it? This says that the language and voice types are UK english:
[local]
voice_key="Eng_uk_f1"
default_language="english GB"
Is this what you run?
Posted Jan 04, 2011 · 19:41 UTC#184
You are also supposed to reposition a wire in the harness and then take that repositioned wire and ground it with the parking brake wire:
http://avic411.com/index.php?/topic/17288-avic-f-hardwire-bypass-for-dummies/
Posted Jan 04, 2011 · 20:24 UTC#185
[local]
Yeah, that's it ... Now I have uploaded a V3, 2, and everything cool. For V3, 1 I gave the following -
sys.txt
Posted Jan 04, 2011 · 20:32 UTC#186
If you are using the english speaking defaults for the EU then you should be able to use the EU option in the install script each time no problem.
Posted Jan 04, 2011 · 21:19 UTC#187
This is my sys.txt.
It says English GB for language but the system and navigation language is italian...
Do you think I can install your 3.2 version and choose italian language in the setup?
sys.txt
Posted Jan 04, 2011 · 21:30 UTC#188
This is my sys.txt.
Interesting. It appears so. If you are not sure you can always make a backup of things (all files or just files like the sys.txt) and revert back if it doesn't work the way you want. In my next version (release 3.2.1 which is mostly install script changes) its going to make a backup of the sys.txt so people can revert back if needed.
Posted Jan 04, 2011 · 21:58 UTC#189
I will try tomorrow and let you know.
Thanks for your great job.
Posted Jan 05, 2011 · 02:47 UTC#190
The only thing non-standard I did was to add 3d car feature in sys.txt and data.zip. Just to be sure, I replaced them with yours, but still no luck.
Any other ideas?
Posted Jan 05, 2011 · 03:11 UTC#191
Any other ideas?
Is the device type set correctly at the top? Also, can you make sure that the speedcam_enabled=1 flag is set? (both in sys.txt). Other than that you could try clearing the save files and see if that clears it up. I have seen stranger things happen. ;) The code is working so its either a mis config in the sys.txt on my part or something 500 specific.
Other than that we need to see if there is another F500 user that knows of something specific that needs to be done. I would be happy to include any changes that need to happen if that is the case. I know that IDT has an F500. You might need to start a thread if all else fails to see if people can chime in.
Edited Jan 05, 2011 by diaftia
Posted Jan 05, 2011 · 05:45 UTC#192
Hey, Alex,
Have you incorporated the tripcomputer start delay in your current mod? I am one of the few owners of the "lemons" that this feature hardly ever worked and this particular mod made it a little better.
Thanx,
Bud
Posted Jan 05, 2011 · 06:09 UTC#193
Hey, Alex,
Thanx,
Bud
I am a Lemon owner myself and yes, its in there. ;)
Posted Jan 05, 2011 · 07:10 UTC#194
This is my sys.txt.
I got it anyway - only in Czech language .... and except for a few things that are not translated it works ....
Posted Jan 05, 2011 · 07:13 UTC#195
Good to hear!
My next version (which I am going to release shortly) is going to let you install the mods without a sys.txt. It should make updating easy for you.
Posted Jan 05, 2011 · 07:32 UTC#196
Minor update:
3.2.1 Changes on 1/4/11
  • Auto installer changes - Some clarification, sys.txt changes and added an option to install mods without copying a sys.txt. Use this if you are upgrading or are in a country where you need to make changes to the sys.txt to support certain language types.
  • Added a long click option for the bluetooth icon that lets you access the phone settings to quickly get to the dialpad.
  • Added an image.res file into my distribution to make it so that the AVIC settings look how I want. All cosmetic but adds some better buttons and images and makes things look nicer.
Posted Jan 05, 2011 · 09:22 UTC#197
Installed - it looks perfect! A few miles do you drive now, so the ladies know - just seems to not start .... TMC
Posted Jan 05, 2011 · 16:01 UTC#198
Yes, the device type was set to 749UC and speedcam_enabled=1 in sys.txt. I 'am not sure what you mean by flag is set in both? Which other file should I check? I know I did delete the save files because the intial location was shown in LA, till I got the GPS fix.
Also, when I press the Extr1 Menu->POI Menu->Saved POI Search, it simply returns to the map screen. However, when I go through Find Menu->POI->Saved Search, it works as expected. Is this feature tested or is it just me?
Thanks,
seeker
Posted Jan 05, 2011 · 19:06 UTC#199
Do you have screenshots of your changed buttons and images?
I'm asking, because I'm still using an edited image.res and till now I'm still overwriting others with that one!!
Posted Jan 05, 2011 · 19:11 UTC#200
Its all pretty subtile. Based a lot on the cmh changes. The main buttons are the same but there is a pioneer logo at the bottom. From there its small stuff to make it look better. Nothing drastic. Also, all the grayed out av source buttons (CD, Sirius, XM, SDCard, etc) are now in color just dimmed a bit.
Easiest thing to do is go in and rename your image.res file image.old. Then start my installer. If you don't like it then just delete mine and change it back. I tend to go subtile on changes so if you are looking for something drastic mine is not it.
Page 8 of 35
