If I delete these, I get no warnings anymore, I just want to get rid of the Icons on the map-
Jörg
Hello
You create a translucent image bmp named speedwarn
To put in: DATA-ZIP/ui_pioneer/common
Here is the image
Jörg
Hello
Here is the image
Hello
Here is the image
Thx, will give it a try
Jörg
Hi Diaftia,
Afther installing the 3.2 version i got problems with the voice, i life in holland en want to use the dutch voice .
I have sound but no voice directions.
Greetings,
Martijn
You might need to go in and edit the sys.txt to point to your voice file. Unfortunately its hard for me to include all countries since there are so many. If you send me the voice file and sys.txt entries I might be able to add it in to the next release.
Hi Alex
All was working well after deleting the save file. I uploaded your new version today and found that even though I selected the model I have in Australia it didn't change the sys.txt file nor did it erase the save files. I changed the sys.txt file manually to the correct version, deleted the save files and all worked ok. Not sure if it was something I was doing wrong or a bug in the loader. Great mod, works well.
Interesting. I am not sure. In all my tests and beta testers it worked fine. Are your paths different than everyone elses?
Wow, didnt notice this update...
I know its a long shot, but i have always wondered if its possible to have a split screen mode like what is found in the 04+ Yukon Denali factory/Delphi/Eclipse navigation systems. Here is a pic of it:
Basically, on the right bottom of the screen, it lists your current street. Above that it lists the distance of the next turn, the direction of the turn, and the name of the street. Then above that, it lists the next 2 turns. And when you are close to the turn, the right side of the screen changes, to show you the lane assist picture thing.
For example, if the exit has 2 exits on it, it will have an overlay picture of the exit and will draw a line on which lane to take when the exit splits into 2 different directions
Hmmmm... really tall order. I might be able to do something similar but I had my split screen as a variation on this. I will see what I can do though. Unfortunately there are a ton of components to what you explained and its not going to be anytime all that soon. ![]()
This is the sys file i am using, maybe i am doing something wrong?
Your file says you are using english:
[local]
voice_key="Eng_us_m1"
default_language="english US"
Maybe I am missing the problem?
Hey Alex,
you are way too quick for me
I'm still on 3.1 and have at least one thing which I find needs improvement: to toggle between the map styles you have to press the compass, but I find it very hard to touch the button so it responds in the right way. 90% I end up setting the cursor in the to right corner instead of toggling between 2d and 3d. Maybe it's just me, but takes a lot of attention off the road.
In addition I have one question: Is there a way to hide the speedcam icons on the map? Here in Europe you can get serious fines in some countries if cought with a System like that.
Jörg
I think you need to calibrate your screen. Its actually very easy to press and I have huge hands. The compass is actually one of the largest buttons on the screen minus the quick menu buttons. Can you try that to see if it helps?
What size sd card do I need for this.. I have a 8gb but it says the file is too big?
How do I add the TELEATLAS 2010.06 North America Maps from here: http://avic411.com/index.php?/topic/29747-avic-x910-software-3010100-extras-mods/?
I'm lost without directions.. Any help is much appreciated..
My files are 79mb. What else is on your 8gb SD card?
You need to replace your map files in apl2/igo/content/maps.
You should probably take up map replacement in a different thread so we keep things on topic as map replacement is not really a part of my mods. Only reason I ask is that it can get hard to keep up with things as it is.
Hello
Here is the image
You can also just put this in \My Flash Disk\APL2\iGo\ui_pioneer\common (make the last two folders) and put the file in there. Should work. If not then just open the zip file and replace the image motte posted.
Thanks, i have been using v2.3 for over a year now and this new version is awesome!! Keep up the good work:)
I've had this issue as well(In all previous versions too). Never been able to push the compass to change. Always just moves the marker to the top corner. Yes, I've calibrated. ![]()
Hey, Alex,
Will your hacked EZrider for the elevation fix work with the TA 2010 Q6 maps?
Thanx,
Bud
Hey, Alex,
Thanx,
Bud
Its a hacked/hacked ezrider so yes. As long as you have the license files.
I will look it over again but you seem to have issues that nobody else is having based on how your system is wired. Maybe his system is wired the same way.
Cool!
Thanx!
Anyone know how to disable 3D mode and turn on 2D?
I was able to switch to 2D in Diaftia v2.3, but cant figure out how I did it then or how to do it now...
Wow Diaftia, great mod! I especially like the customizable menus, it is now set up exactly how I like. I have been using your 2.3 version mod previously for the past year or so and found it to be the best available at the time. This new version is unbelievable! Fuel consumption, return to office, autokarta, customizable menus. Wow! I did have some problems getting TSS working, but simply copied and pasted from my old sys text file in the [folders] section.
Hi Alex,
Installed the 3.1 mod on a F500 running FX3.0 and been testing for a week. Every thing works as expected. Overall, a great mod. You and your fellow modders deserve a big thank you.
However, I'am not getting any warnings (both audible and visual) for speed cams. I can see the speedcam icon (small black&white camera) on the map, but nothing happens when I approach it. It's the same in simulation also. I verfied that both audio/video warnings under the settings/warnings menu are turned on, master volume is not muted etc. I even tried setting the speed limit to 10 mph, but still no luck. I can add/edit speedcams, though.
Any idea why the cams are not working?
seeker
The compass is a button. It changes map mode.
Can you send me your sys.txt so I can take a look?
Hi Alex,
seeker
So you clicked the enable speedcam option under warnings and got the legal disclaimer thing? Or did you go into the volume settings and enable the alert?
Once again I want to thank you for the great work! But be sure to ask - before I have to upgrade to V3, 2 edit SYS.TXT?? I'm in Europe. Thank you in advance Pat
Hello, I'm Italian and i would like to load your skin V3.2 on my F910BT, now I have version 2.3 italian version.
If I put V3.2 I will loose italian language for the entire system (AV, NAV, FM ...)?
Thanks in advance
Gaetano
Yes, I turned on the speedcam option under warnings and did get the legal disclaimer. I also verfified that there is an alarm on the basic camera types. In addition, the speedcam volume along with master volume is also turned on under the volume settings.
I never tried the speedcam warnings on my device and was wondering if they even work on the F500.
Thank you very much for all your help.
Hi. I'm extremely new to all of this upgrade stuff. I recently installed firmware v2.009 to my f900bt which made an improvement on boot up time etc. After searching the net I came across your mod so have decided to give it a go. How long does it take to install? I have had 1 attempt at which I selected which version and country which installed after a couple of minutes. Then after a few minutes I did the reboot thing and now have no sat nav and keep getting the navgate bootup screen on the display, even though all the other functions still work. I also comitted the cardinal sin of not flashing the memory so I cant go back? Is there any hope for me or have I blown it for the sat nav function?
