IIRC you were the same one that had this problem before correct? Nothing should have been removed from 2.3. It should work the same as far as bypass goes. The pioneer.ini still has the bypass in it.
Yeah, Had this issue once before but you were able to get it worked out. Don't remember what was done.
Not sure what to do. Guess I'll go back to the old version until a solution is found.
