Hi Diafia,
I've tried your latest version today and I'm having two problems.
First one:
I can't get the unit on with your image.res! It seems to be to big? It starts to boot but then it hangs up and stays in bootscreen.
Since V2.3 I use an image.res with a size of 1.03 MB - if I copy that one over it, everything works fine!
It seems, that every image.res with a bigger size is not working. Smallest one I've tested today was 1.5 MB and it still hangs up!
On my search for new images I found files with 3.5 MB - how does that work if mine is hanging up with half of the size?
I've also tried to unpack my image.res, changed some images and ziped that one again - but curiously I do not get approximately the original size again!
I even tried to unzip and zip my original .res-file, but I do not get the original size again!? Tried it with Win.RAR ans 7-zip - same result and size - it goes to 1.9 MB instead of 1.03 MB WITHOUT changing anything!
Any idea for that?
Second problem:
TMC is not working correct! It shows every TMC event with kind and distance, but it does not show freeway / highway numbers! only the shortcut for roadtype is shown, but without a number!
For example german freeways are A1 or A61 and highways are B1 or B61 - but it only shows the kind of event, distance to event an roadtype A or B instead of A1 / B61!
Any idea?
I've tried it with V3.1 and V3.3 - last one working was V2.3!
@ gehklaus: is it (TMC) working correct on your unit and does it show roadnumbers?
Maybe someone will try the image.res I'd like to use and tell me if it works on your unit: Image.zip
(Rename .zip to .res!)
This is the working one I use: Image.zip
