Alex
Can you please tell me what settings i need for FULL SPOKEN WARNING in safety cameras?Its the only thing that I cant get to work.
Alex
Alex
It's at the bottom of the warnings section.
Thank you for the update, love this mod!!!
This should absolutely not be effected from my mods. Did you try hitting the reset button? If that doesnt work hit the reset button and the eject button for 5 seconds.
I managed to get it to red....
I like your mod so far though. Just wondering, is there a way to turn off some of the extras? I don't really use much but the extra buttons on the nav screen.
Alex, if I have a CUSTOM folder on the SD card, will it ignore it when I run the update install script?
I have set it up in there bu t do i need to set the audio setting to anything ie simple,full etc.
Specifically what are you speaking of? Most things have a toggle in settings. If you just want a couple of items in the menu hold down one button and make it (or all of them) what you want.
Yes. It will be fine. It will just use my folders.
Not sure I follow. Spoken warning is on or off plus voice volume. If you mean the speedcam alerts themselves that is for the beeps you hear:
- Camera settings:
Any camera type can be turned off separately (no yellow border). There will be neither visual nor sound warning when approaching a camera.
Custom Audio Warnings:
For every camera type you can select audio behaviour
* Off: No audio notice.
* Alarm: If not going faster than camera speed, there will be no audio alarm. If speed is within acceptable range: In 1000, 450 and 250 meters there will be one warning sound for attention. If going faster than limit + overspeed: In 1000 meters there will be a single alarm, then, starting with Alarm distance there will be constant alarm sound, increasing in frequency as you approach the camera. In 150 meters there will be last attempt to bring you to your senses. After that, warnings are useless anyway.
* Warning: If not going over camera speed: no sound. If speeding (no overspeed applied): From specified alarm distance until the camera there will be constant audio warning of the dangerous zone.
* Reminder: In 800 meters there will be a single reminder, independent of speed.
Thanks man! Glad you like it ![]()
Mod works here for me (EU, German, Blue-Sign, TMC and Blutooth). Nice Update
Any hint were I can change the voice speech settings? (I mean the spoken next event) I will disable the 300m voice.
Ok so change to english GB. Its not consistent. I guess its supposed to be:
[local] voice_key="Eng_uk_f1" default_language="english GB"
So you also made the TMC stuff with the 2?
tmc_events_icon_set="$tmc2.spr"?
I've deleted the complete TMC 2 stuff.
Ok so it sounds like I need to release a small update that fixes that TMC status screen to look correct and changes the UK to GB for the speech. Will get on that as soon as I can.
From what I understand that is not changeable. Granted I was gone for a year or so. Is it more chatty than other mods? I have been meaning to go in and look at the commands in the speech file based on another post. Will check it out.
Can you please tell me the button to get to the analogue speedo - I came across it once but cant find it now.
thanks
thanks
The shortcut is a long press on the current speed sign.
Everything is in the quick menu. That particular button is under the user menu 2. To get there bring up the quick menu you will see "Extra 1 Menu" then "User 2 Menu". There you will see all of the extra screens. The one you want is speedo.
Alex
Alex
Ahh that makes sense as my current speed sign seems to have disappeared. I was pressing everything else lol
Ill have a look through those menus tomorrow and try to get there as well as get current speed back.
thanks
ps. I find it quite amusing I had no problems getting all these mods on with no issues after a day of owning but cant work out what some simple buttons do ![]()
thanks
Too funny because I consider my mods some of the easiest mods to use because of the quick menu! ![]()
The setting you want is under settings>Visual>Nav Screen Options>Signs displayed on map.
Don't worry, its definitely me.
Ill have a play tomorrow, bed time now.
Hope I can find quick menu ![]()
Alex,
I am putting all of the files in manually because there are several I am keeping that I have extensively modified. Where does your "mapchanger" folder reside?
Thanx,
Bud
TMC is enabled in Regional. Tried what gehlkaus did, but no effect.
attached 3 pics.
first pic is the normal tmc settings page (with nothing present)
second pic the navisettings with the red/blue car icon which directs to pic 3
pic 3 is what I mean by "extra TMC settings" (never seen that screen before)
Can someone with TMC go into the regional settings and turn on emulator mode and TMC? Then go back out one level and click the TMC button. Does that screen show valuable information to TMC users? Like is it showing signal strength and options that are useful? For some reason this goes to a broken screen when eumlator mode is off. When its on the screen is rendered correctly.
Make sure you turn emulator mode back off when done. ![]()
Alex
hi diaftia, what do you need from an australian AVIC to get as much customisation correct for AUS as posible?
Hi Diafia,
I've tried your latest version today and I'm having two problems.
First one:
I can't get the unit on with your image.res! It seems to be to big? It starts to boot but then it hangs up and stays in bootscreen.
Since V2.3 I use an image.res with a size of 1.03 MB - if I copy that one over it, everything works fine!
It seems, that every image.res with a bigger size is not working. Smallest one I've tested today was 1.5 MB and it still hangs up!
On my search for new images I found files with 3.5 MB - how does that work if mine is hanging up with half of the size?
I've also tried to unpack my image.res, changed some images and ziped that one again - but curiously I do not get approximately the original size again!
I even tried to unzip and zip my original .res-file, but I do not get the original size again!? Tried it with Win.RAR ans 7-zip - same result and size - it goes to 1.9 MB instead of 1.03 MB WITHOUT changing anything!
Any idea for that?
Second problem:
TMC is not working correct! It shows every TMC event with kind and distance, but it does not show freeway / highway numbers! only the shortcut for roadtype is shown, but without a number!
For example german freeways are A1 or A61 and highways are B1 or B61 - but it only shows the kind of event, distance to event an roadtype A or B instead of A1 / B61!
Any idea?
I've tried it with V3.1 and V3.3 - last one working was V2.3!
@ gehklaus: is it (TMC) working correct on your unit and does it show roadnumbers?
Maybe someone will try the image.res I'd like to use and tell me if it works on your unit: Image.zip
(Rename .zip to .res!)
This is the working one I use: Image.zip
From what I understand that is not changeable. ... Is it more chatty than other mods?
No, I's the same as before! But I've often been wondering about the sence of that 300m command, too - on freeways sometimes it sucks!!
Maybe there is a way to get it away by editing the excel-file in the voice_xxx.zip file?
Diaftia,
Thank you for your work!!!
One big request though.....
Can you PLEASE have your mod make me coffee in the morning?
I think that's all it need to be completed!!!!
Thank you once again!
