Diaftia's Hybrid mods V3.6 - UPDATED: 04/19/11 - Now with auto installer.
By diaftia · Dec 13, 2010in Completed Mods/Themes💬 857 posts👁️ 216,897 views
Page 26 of 35
Posted Mar 22, 2011 · 23:44 UTC#626
:blink: Hi Diaftia.
Just installed your nice mod, and started to play around on the screens.
Nice work..
Is there a way that i could change the language on the "new" menuitems
from english to another, so they all correspond with the "originals" that
were there from the start??
thank you.
I am not sure what you mean by the new vs. originals? Can you explain more?
Posted Mar 23, 2011 · 00:10 UTC#627
Sorry for not being clear enough.
I live in Denmark, and the menuitems that are in the original software
all have danish names. I was thinking that perhaps i could find the english
words somewhere in a file, and then exchange them with the danish words, so
that all the "buttons" would be in the same language.You would likely know
where i should look, if it is at all possible what i want to do.
thanks for responding.
Per
Posted Mar 23, 2011 · 17:54 UTC#628
Per
Someone must have redone them to be in danish.
To do it yourself extract the data.zip and edit the menu.ui file.
Posted Mar 24, 2011 · 17:46 UTC#629
Thanks a lot.
will try
Per
Posted Mar 29, 2011 · 21:31 UTC#630
You would have to extract it from DATA.zip. Then you have to rezip it with either WinRAR or 7zip.
if I change the names inside the file
"main.ui"by the same name but in Spanish on the
browser will come in Spanish?
We must also change all files with extension
*. ui by the name you put in "main.ui?
I mean .... to translate all the menus, only
edit "main.ui? everything will work?
thanks
Posted Mar 29, 2011 · 21:44 UTC#631
thanks
Yes, just extract the data.zip find the file menu.ui. In that file is a script named <script d_LBQP_setlist>
In quotes you will see the menu text. There are two entries and a number. One for the menu itself and the other for the smaller menu for when you are changing the button by long pressing one of them. Change them both to whatever you want. The number is the position in the order of appearance and where it looks in the image file to pull the image it uses. Leave that alone and just change both instances of text.
Posted Mar 30, 2011 · 14:05 UTC#632
Awesome mod, will send you a few dollars, keep up the work.
Only question is there anyway to get the cruise screen as the default screen instead of the speed screen?
Also have not done many mods, what are the reasons for doing TA and NT maps?
Posted Mar 30, 2011 · 17:53 UTC#633
Thank you for the donation!
Not sure what you mean. There is a setting so that you can choose what screen comes up when starting a route. I think I called it "Default Nav Screen". You can choose from the different screens I have added.
Some people have found that one or the other maps give better data in their area. For the most part you should not need to switch unless you want to see what the other maps are like.
Posted Mar 30, 2011 · 18:03 UTC#634
is there anyway to use the cruise screen when not in nav mode? Or is it only available if you are on a current nav route?
Posted Apr 06, 2011 · 08:37 UTC#635
Hi, just a question about the mpg calculation function. Can I check if gallons are US or Imperial (UK)? Or, can you select as required? Also, is there a way of displaying the results in miles per litres? Although mpg is commonly used in the UK, fuel is actually sold in litres.... It would just make the estimated cost of travel a lot easier to derive if I could keep miles at the units of distance but litres as the units of volume.
Cheers.
Posted Apr 06, 2011 · 17:35 UTC#636
You can select any screen at any time from the menu. The amount of information it displays depends on if you have a route or not.
Posted Apr 06, 2011 · 17:37 UTC#637
Cheers.
I dont think it matters since its based off the price and units. Its linked to the setting you chose in regional for the units. Feel free to look through the code in the FuelCalc.ui files.
Posted Apr 07, 2011 · 21:30 UTC#638
3.5 Changes on 4/07/11
  • Fixed Dynamic volume toggle not working.
  • Added screen off executable to menu so that you can make the screen actually off.
  • Added in Saved Search Criteria link in POI search screen
  • Fixed blacking out of sort by when searching around GPS location.
  • Added in a #12 option to the installer so that you can install just a data.zip and nothing else.
  • Fixed (hopefully) the avicon hide feature coming back on at odd times.
Edited Apr 07, 2011 by diaftia
Posted Apr 07, 2011 · 22:25 UTC#639
Hi its a good mod,
Please let me know how to add POI or camera while driving?
Also reporting a bug, If click on MENU from the map screen, I will get a new screen with many icons(Address, POI, Favorites, .....)
If i select Exit ... It should take me to the map again but it take me to the main desktop of device, Then I can't access the map anymore.
I'm using F500 Ver: 2.006000
Regards;;
Posted Apr 07, 2011 · 23:20 UTC#640
Hi its a good mod,
Press the elevation screen on the exact location as you pass it that you want to add one. Otherwise go into the Route planning screen, click the location on the map where you want to add one and click the cursor (target looking icon) button and add cam.
Turn off emulator mode in the regional settings.
Regards;;
Posted Apr 09, 2011 · 04:16 UTC#641
It looks good. The AV icon works as it should. I've only just installed and will test out tomorrow. Thanks Alex for another great mod. I'll advise if I find anything you should be aware of. Till then...
hg
Posted Apr 09, 2011 · 08:28 UTC#642
I really liked your mod and so really want to keep it updated with this new useful features. At this point it generate in me a relativly newb question...is the auto-installer even an auto-upgrader?
I mean, I've just intalled the 3.4 version and so I've used the auto-installer (everything went smooth as it was the first "upgrade" to my default system). To install the 3.5 now, can I use the new auto-installer directly, or it is better to set everything to default (I mean to use my backup) and then apply the installer?
Posted Apr 09, 2011 · 15:07 UTC#643
If you are just upgrading from 3.4 to 3.5 you can just use the last option that I just added. That will just copy the data.zip and keep all of your existig settings.
You can also run the original option you picked. To answer your question, yes the installer upgrades too. This is always the safest option but removes any settings you made and you start from scratch. But it also assures that there will be no conflicts.
Posted Apr 09, 2011 · 17:13 UTC#644
Thanks again for yet another update to this awesome mod!
Posted Apr 10, 2011 · 03:17 UTC#645
Thanks for the mod! I just installed it and it works great! I love the new features!
I do have 1 issue though, 2 out of 3 times I start up the nav my touch screen freezes and there is nothing I can do until i restart the car. any ideas?
thanks!
Posted Apr 10, 2011 · 13:27 UTC#646
thanks!
That is odd. The only thing I can think of is to try the install again. One time I installed and it was acting funny. Installed again and it was fine.
Also give the screen a calibration. There could be something off in the calibration file.
Edited Apr 10, 2011 by diaftia
Posted Apr 10, 2011 · 16:24 UTC#647
thanks for the quick response. I will try re-installing it and calibrating the screen and see if that works.
Posted Apr 11, 2011 · 06:20 UTC#648
Yesterday I've done the "upgrade" and at the moment the new version is, as always, very stable...
Thank you again, for the mod and for your availability.
Posted Apr 11, 2011 · 08:21 UTC#649
Firstly thanks for the mod, really enjoying using it.
My question is about the speed limit signs - I have an EU F900BT unit with a UK map, yet the speed limit signs (and spoken voice warning triggers) are in KPH. For example a 70mph motorway limit is shown as 110. Other measurements such as current speed are displayed correctly in MPH. I've searched through the options several times and can't find a way to change this, is it fixable please?
Posted Apr 11, 2011 · 17:41 UTC#650
You're welcome. :)
Page 26 of 35
