Diaftia's Hybrid mods V3.6 - UPDATED: 04/19/11 - Now with auto installer.
By diaftia · Dec 13, 2010in Completed Mods/Themes💬 857 posts👁️ 216,897 views
Page 25 of 35
Posted Mar 13, 2011 · 22:04 UTC#601
That is odd... you are sure they are on the flash disk?
thanks for the reponse..
Yep, just double checked. they are in my flash disk\APL2\iGo\Content\Voice . they are all zip files.
i cant see the aus in language or voice??
can i manually override it?
cheers
sam
Posted Mar 14, 2011 · 16:53 UTC#602
cheers
sam
Try this:
http://avic411.com/index.php?/topic/28403-voice-and-language-problem/page__p__210073__hl__%2Baustralian+%2Bvoice__fromsearch__1#entry210073
Also, if I remember right there are two different places to set the voice settings. One is in regional but there is another in the Pioneer side. If you dont have the option to browse to a TTS file via USB you are not in the right one. I will try to look later today if you don't come across it.
Posted Mar 14, 2011 · 20:04 UTC#603
Reposting ...
Hello Alex,
I've tried to locate the script for the distance scale ruler in the "Route planning screen" and the "Map screen", but could find it. Could you please shed some light on it?
Thanks.
Posted Mar 14, 2011 · 20:10 UTC#604
Try this:
Hi Alex,
ok i must be going mad but i cant find the brownse tts via USB in any menu. i have had a look at the regional settings and the language settings but neither has the option to browse via USB. The only place i can find to change voice settings is system settings/language
weird. everythign else is working from your mod. tried a fresh install of your mods but still nothing. I will have a a crack at changing the sys.txt.
thanks again.
sam
Posted Mar 14, 2011 · 21:06 UTC#605
Reposting ...
Hello Alex,
Thanks.
Hmmm... you mean the blue and white bar along the bottom?
Look at the scripts sc_init_zoomcontrol_browsemap and sc_init_zoomcontrol in scripts_800_480. I think that the browsemap script moves it off screen.
Edited Mar 14, 2011 by diaftia
Posted Mar 16, 2011 · 11:44 UTC#606
I'm having issues with the spoken guidance on my system.
I just recently typed in a location and as I navigated to the location the unit kept speaking a street or road name, spelling it out including ampersand's and backslashes etc. in the street names?
Is there a specific voice it should be on or is there a setting somewhere for fixing this?
Posted Mar 16, 2011 · 17:57 UTC#607
That is odd... Two things to try. One is to go to the street again and see if the name of the street shows correctly on the map screen. If it does then get the original voice file and replace the one that is on the flash disk and see if it still does it. If it was just one time on one specific street you have to decide if its worth even going after.
Posted Mar 16, 2011 · 18:55 UTC#608
Hey that is strange.last time out my 900bt did the same thing butiwas using dphurst mod at the time.A. Reboot sorted it out but it was the first time this had ever happenedî‰
Posted Mar 16, 2011 · 19:10 UTC#609
I just want to say thank you for this wonderful Mod! If I were a delivery guy still (pizza hut years ago), this would be a must have. Very nice work!
Posted Mar 16, 2011 · 19:37 UTC#610
Thanks. :)
Posted Mar 17, 2011 · 12:06 UTC#611
I am very interested to translate all the menu from English into Spanish. You know how you can edit the files?
thanks
Posted Mar 17, 2011 · 12:10 UTC#612
Thanks Alex!
I copy over the script for the Map Browser screen, it works with one hiccup that I don't understand: instead of having two distance markings in the scale as in your mod (i.e. 5KM, then 10KM), I have only one (the farther one, i.e. only the 10KM), any distance!!!
Any idea?
Posted Mar 17, 2011 · 18:44 UTC#613
Hi, hoping someone can help me on this.
I have been learning about all the settings by trial and error as I guess is the way here. But somehow I seem to have activated something really quite annoying... Every time I go over a roundabout I get a "beep" warning sound. It seemed to be associated with the turn restriction parameter being set to "on". But I have switched that to "off" and I'm still getting the bloody noise! I've scratched mu head and tried every setting I could think of to get rid of this warning sound but to no avail. I'm probably missing something basic, can someone point me in the right direction?
Posted Mar 18, 2011 · 00:10 UTC#614
thanks
menu.ui
Posted Mar 18, 2011 · 12:41 UTC#615
Under 'warnings' theres an option called 'lane' something or other. turn it off. it cured the problem for me.
Posted Mar 18, 2011 · 16:55 UTC#616
Sorry must have missed this question. Its called Lane Guidance. Beep comes up when there is a change in lanes on a freeway too.
Posted Mar 19, 2011 · 04:04 UTC#617
I had the same problem and deleting the file inside the PHONEME directory(*.ph) solved the problem.
Posted Mar 19, 2011 · 11:05 UTC#618
Where is the *.ph located? I looked under user/phone and found call history and phonebook.
Jimbo
Posted Mar 19, 2011 · 11:30 UTC#619
[quote Where is the *.ph located? I looked under user/phone and found call history and phonebook.
Jimbo
It's located in the APL2/IGO/CONTENT/PHONEME folder. Just delete the file with the ph suffix but make a copy first just in case.
Posted Mar 19, 2011 · 19:41 UTC#620
menu.ui
I have to edit the file menu.ui?
I do not find that file. I have not in my flash disk.
thanks
Posted Mar 19, 2011 · 23:30 UTC#621
thanks
You would have to extract it from DATA.zip. Then you have to rezip it with either WinRAR or 7zip.
Posted Mar 21, 2011 · 00:30 UTC#622
First off, thanks daftia for the impressive mods. I'm new to this game (used F900BT, new to me, 3.0201 firmware, otherwise stock), and I played with the base unit before I upgraded with your mods. A few questions, if I can:
With the stock setup, clicking on "Voice Volume" in the setup menu and dragging the slider caused the voice to state something at the requested volume level. Now, with this mod, it no longer speaks when the slider is selected and moved.
On the screen where "dynamic volume" setting is configured, I can click "On", but when I return to the screen, it is set to "off". Before, it stayed where I set it.
What does the red icon with the speaker and the 'X' do in the nav screen? I assume it means "mute", but it didn't seem to do anything when I clicked it.
I know this is not a map update, but it is unclear which of the many thread pertaining to maps I should pursue with this mod in place. I don't want to mess up the fine work in this mod as I update the maps.
Jim
Posted Mar 21, 2011 · 11:12 UTC#623
Thanks. It works fine now.
Jimbo
Posted Mar 21, 2011 · 15:10 UTC#624
:blink: Hi Diaftia.
Just installed your nice mod, and started to play around on the screens.
Nice work..
Is there a way that i could change the language on the "new" menuitems
from english to another, so they all correspond with the "originals" that
were there from the start??
thank you.
Posted Mar 22, 2011 · 21:00 UTC#625
My mods have a default mute setting when the unit boots or starts a route. Most likely you are trying to test the volume with it muted. Unmute the system and then try it again. You can start a route and then unmute or just turn off default mute in the sound settings and reboot.
This is a known bug that I have fixed in my dev environment and have not released yet. I need to do some more work on other stuff before I do. As far as I can tell the default mute would set fine if you dont go back. So set it to on and then hit the hard map button.
That means the nav guidance is muted (per my first reply at the top of this post). Just click it to hear the guidance.
I wish I knew myself. I include the license file so you can run any maps you like. You just have to find the one that is most recent with working links. Here, try this one I think I got mine from it: http://avic411.com/index.php?/topic/29707-teleatlas-201006-north-america
Jim
Page 25 of 35
