Firstly thanks for the mod, really enjoying using it.
My question is about the speed limit signs - I have an EU F900BT unit with a UK map, yet the speed limit signs (and spoken voice warning triggers) are in KPH. For example a 70mph motorway limit is shown as 110. Other measurements such as current speed are displayed correctly in MPH. I've searched through the options several times and can't find a way to change this, is it fixable please?
That is strange that they are showing in different units. The system gets the unit values fron the regional measurement unit settings. The only difference between the speed limit and the current speed is that the speed limit comes from the map data and the current speed comes from the GPS. They are not hard coded as a type in my code. They pull from the system and whatever unit it set to appears. Are you using the original maps? Have you tried playing with the measurement units in regional?
