Is there a password for extraction? I keep getting password requirements.
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
Well, I advise against using this file as there are several threads on how to recover from using this... but if you insist, the password is in the first post: avic411
What are you trying to accomplish? If you want to look at the file system or something use this file instead: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788
I am trying to unlock an AVIC-x930BT
you are posting in the F series forum but you have an X series Avic.
I'm not sure what you mean by "unlock". Is it a password thing? Is it just not working? The link I gave above will "unlock" it to developer mode.
If you are trying to load other gps software onto your x930bt then re-read the first post again. It says you can load the new software but the gps part doesn't work. Seems like a deal breaker to me.
This condi hackmode is just a way to put the avic into a development/test mode. It never accomplished its goal. It doesn't work.
in order for me to extract the files its asking me for a password, I have no clue onto what the password is
Has anyone had the issue where they get stuck on the Pioneer splash screen after installing hackmode when trying to boot Norm, W/O an SD card?
I followed the instructions, and simply wanted to use Hackmode to replace my Navi.exe in PRG1, and when I was finished it wouldn't go past the splash screen no matter what I did. I could although put in the SD card and boot to hackmode, just not Norm mode...
I ended up just reverting back to the 5.1 update, but I would really like to replace this file. Any ideas?
x920BT
x920BT
HackMode should be called ScrewMode (and I'm being polite here) since it screws up most unit. I'd say 2 or 3 users really know what it does to the unit so I don't think you'll get an answer.
Stay away from it.
It is a pretty neat concept, it just seems unfinished. It really wasn't that hard to un-do, all I did was re-install the last update to 5.1.... It was just kind of scary when it didn't boot to anything but a splash screen after reading sooo many posts of people who bricked their units. I ended up today using the SUPERtestmode that was available in the posts.
Not sure about everyone else, but I definitely don't have $700 to unload.
Hi Condi
I just fixed my radio F930BT after a visit to my garage!
Thnx mate buy yourself a beer cheers!
Hi, following the advice to use the version 1.4.I have done all the steps: in /user/prg0/apl folder I deleted av.exe. I copied the folder condihack. Reset the unit with hackmode.key but it does not enter in hackmode.Additional Information:I have a pioneer F920BT firmware version 5 (which mentions a partner in post # 996)I have made ​​a backup of the entire folder USERI have made ​​a additional copy of av.exe file before to be deleted in the processI looked at the size of folders and prg1 prg0 and is different (slightly larger prg1).More Information:I check USER backup. I have PRG.FLG in USER and:EU090APL.HTM in PRG0: Release Version : 4.010000EU090APL.HTM in PRG1: Release Version : 5.000000Then, like I have PRG.FLG in USER then boot PRG1What I can do?1. Return PRG0/APL to original state (delete Av.exe and others files and folder CONDIHACK and re-copy original Av.exe to folder) and then hack PRG1/APL2. Delete PRG.FLG after backup-it?
Hello, I tried to delete PRG.FLG to force onset prg0 which has hackmode installed, reboot and show me on the screen a message that no program. I reseated prg.flg in place, reboot the device and boot properly.
Can I try to install the hackmode?
You can try but don't be surprised if your unit gets screwed up.
TestMode v1.4 by itself is harmless compared to HackMode v2.21. I suggest you stick with 1.4
Where can I download Pioneerus+IGO8.3??
I sent a private message to Sanik, but he don't answer
my email: [email protected]
I got to the last step and i deleted condihack from the SD root and now my avic is takin forever/not booting up at all. Is this normal or did i mess something up?
Just the fact that you installed CondiHack is bad enough. You don't need to do much else to screw up your unit.
Have you tried http://avic411.com/index.php?/topic/36854-undo-condis-hack-mode/ ?
Hello. I followed the manual installation process in PRG0 condihack 1.4 folder does not work. have would to copy the same files in PRG1?
What?
Is your unit working properly?
- Yes: Leave it alone
- No: What's the issue?
can someone call me and teach me how to use this program?
[email protected] email me if u can
Consider that there is an entire thread on how to undo the damage done by this program... and then consider not using it. You risk turning your unit into a worthless brick. There are other ways to do the things you want without installing this program.
Test Mode Fails to load on the AVIC-X8510BT is there a version I should be using to help with getting to the Pass word? We bought this unit second hand and during a trip to the Garage for repair it came back asking for a password...
Any help would be appreciated.
Ed Jones
Ed Jones
here's the link for supertestmode, I don't know if it works for x8510 but try it instead of the condi hack: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788
then try these password recovery instructions using the supertestmode instead of the condi hack: http://avic411.com/index.php?/topic/32929-x930bt-password-recovery/&do=findComment&comment=240249
must not work with the X8510BT as I got the same message that it failed to load testmode. so I guess I am stuck unless I send it to Pioneer. thanks for the help
Ed JOnes
Hi,
Who can make a backup of F30BT ((User)) and upload it for me?
My device crashed yesterday and won't boot anymore, restarted with supertest.key and didn't found the USER folder at all.
Its important an hope some one can help.
Regards
I think I messed up, I bought an 930bt from my buddy he forgot the password an old radio, I was trying to find the password and I installed the hack mode, is there a download for the regular ui?
Got the password but the headunit is stuck at the pioneer loading screen
