Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 43 of 49
Posted Dec 02, 2014 · 16:09 UTC#1051
Thanks mate
Posted Dec 07, 2014 · 01:38 UTC#1052
I'm having trouble unpacking the download its asking for two passwords. i got one from the forum but not the PRGx.FLG password
Posted Dec 20, 2014 · 01:07 UTC#1053
I just installed this hack and I don't understand what is the point of this hack, can someone explain to me the use of this hack? thanks.
Posted Dec 23, 2014 · 06:42 UTC#1054
thanx condi,
it workt perfect, it took me a while because of the language , i am from holland.
but my f930bt runs like new.
i removed the whole password in the system,
Posted Dec 24, 2014 · 23:07 UTC#1055
hi there , im new to this forum and im trying to hack my avic 930bt but when i get to the password i got the first one wich is AVIC411 but the second one for the HACKMODE KEY .... thats where i get lost. any ideas ? thanks
Has anybody figured out the password for this problem..?
Posted Dec 25, 2014 · 16:46 UTC#1056
Just wanted to say that I nearly bricked my x930bt that was upgraded to z140 firmware when I used Condi's 2.21 autoinstall.  For some reason it deleted my AV.EXE file and installed an older version of it.  I don't understand why it did or even why it didn't backup the original but luckily I had a backup from previous backup I made and just copied it back to the PRG1\APL folder and then had to delete the PRG.FLG file in the root directory of USER.  I did this using Condi's HACKMODE v1.4 BASE and supertestmode which uses a TESTMODE.KEY that is modified.  Once I did so I restarted unit and everything was copacetic.   I then updated to the latest 2013 maps using http://avic411.com/index.php?/topic/38472-2013-usacan-maps-download/  which worked perfectly.  Just extract the contents of the Rar file to the root of my microsd card and when the stereo booted with the card in it, it detected it and asked to install update.  30 minutes later. I am sitting on 5.0 firmware and software!!!
Can you send me a link with your backup files. I tried the Condi autoinstall and i think i bricked my unit.
Posted Dec 29, 2014 · 19:21 UTC#1057
for F900BT it's ok ???
Posted Dec 30, 2014 · 13:57 UTC#1058
If you do it USING TESTMODE V1.4, no harm can be done trying.
Posted Jan 10, 2015 · 23:14 UTC#1059
I've been locked out of my AVIC-X850BT for 2weeks  feels like forever  all that shows up on myscreen when I turn my truck on is user hint PAPA  I bought the truck used so I didn't set up the password  what do I download for this model to let me use the damn thing!!!!!  I don't care bout gps I just wanna at east be able to listen to music lol
Posted Jan 11, 2015 · 14:16 UTC#1060
Use this thread: http://avic411.com/index.php?/topic/32929-x930bt-password-recovery/?p=240249
It should be the same procedure for the X850BT.
The procedure is harmless IF YOU USE TESTMODE v1.4.  Do NOT use HackMode v2.21.
Edited Jan 11, 2015 by Lyverbe
Posted Jan 17, 2015 · 12:26 UTC#1061
I managed to run some apps, TCPMP player, iGO8, Mireo Cardinale, and other gps software works too. New mortscript is not working, like some other software also, i think because of lack of some libraries/dlls. Windows in this units is very 'handicaped', there is no explorer.exe, control panel cpl's are not running etc.
I will make some scripts which will run some custom software/menu if proper files will appear on sd/usb.
For now I must get rid of av going front after ~30s.
When everything will work as I want to, then of course I will release full solution smile.gif
I download this program but i don't know what password to enter. At first I type avic411, and secondly I don't know waht password to type?!
Posted Jan 29, 2015 · 11:50 UTC#1062
I have got onto windows style menu on my f930bt but how do I remove the password off the unit?
Can someone please help me.
A step by step answer would be appreciated.
Posted Jan 30, 2015 · 12:50 UTC#1063
I am rapidly losing the will to live! What is the HACKMODE password (and please don't tell me to read the first post because I have and i still don't see it/get it)?
RIGHT! Sorted it and this all worked but the pw is 00000 and yet the unit says this is not right!! Now what??
UPDATE: YES!!! Works now. No idea why though. I put 5 zeros in until it locked me out. Went back a few mins later and put in 4 zeros, then 6 zeros and then 5 again and it suddenly worked!!!
Edited Jan 31, 2015 by Frimley111R
Posted Feb 06, 2015 · 00:27 UTC#1064
I loaded the hack successfully but now when i go to run my avi without  the hack, it stays frozen on the intro display screen.
Posted Feb 06, 2015 · 00:39 UTC#1065
anybody have back up files???????????? PLEASEEEEEEEEEEEE i'm bricked out
Posted Feb 11, 2015 · 11:06 UTC#1066
Can someone please share a working testmode for a f850bt or f960bt ?
I search and tried a lot of testmodes but can`t get it working .
Formatted sd in Fat32 and Standard Fat  placed  x50 testmode and x50 v2 but nothing seems to start up in testmode .
Has anyone been able to get it running in testmode ??
PLease share
Posted Feb 11, 2015 · 11:09 UTC#1067
anybody have back up files???????????? PLEASEEEEEEEEEEEE i'm bricked outI
I had this ones and I used the files in other folder within the unit , cant remember the file name but something like PRG0 and PRG1
Copied the files from one folder to other , seemed to be a backup . had me going for a while though to figure it out
Edited Feb 11, 2015 by Flipmode3
Posted Feb 18, 2015 · 19:52 UTC#1068
hello
I have a  AVIC-X930bt  well its x9310bt {Canadian i was told]
Any way while pasting original back up files i had in test mode the unit accidentally
got unplugged from power :?  :?
so now no matter what i try to do just get a screen that says program update started gets to 50% on the first status bar and then program update failed. restarting.  it just loops over and over can not access testmode anyway sd,usb,or the button method if i am doing it right for this devise
not sure what i can do now not trying to send it to pioneer for  250$
any help out there for this please
thanks
Posted Feb 18, 2015 · 19:55 UTC#1069
hello
so now no matter what i try to do just get a screen that says PROGRAMarrow-10x10.png update started gets to 50% on the first status bar and then program update failed. restarting.  it just loops over and over can not access testmode anyway sd,usb,or the button method if i am doing it right for this devise
thanks
Posted Feb 23, 2015 · 17:52 UTC#1071
to me it seems that it dosent even try to read the sd or usb therefor not letting me do anything
just keeps looping over and over
any ideas?? tried the removal nothing happened :?
Posted Mar 10, 2015 · 16:01 UTC#1072
100% work on f930bt the best hack mode
Posted Apr 02, 2015 · 03:52 UTC#1073
Is it working on Z130BT?
the GPS signal is good?
Thx
Posted Apr 02, 2015 · 14:12 UTC#1074
Hello everybodies,
I' ve got a problem with my Pioneer F850 BT (need password after car battery disconnection). I've tried with Condi's hackmode, but it doesn't work. I've got command "CAUTION, TEST MODE FAILED STARTING" when I put my Condi's SD to device.
Could you help me.
Kamil G.
Poland
Posted Apr 03, 2015 · 21:51 UTC#1075
I,m also having a problem with the screen saying CAUTION, TEST MODE FAILED STARTING Turn of ACC. Anyone know why? I have an x850bt and used hackmode v1.4
Edited Apr 03, 2015 by deucewood
Page 43 of 49
