Tried all versions on x950bh us version. All times i got the attached screen. Failed and to turn off acc
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
PLEASE HELP
I have exactly the same probleme than gweny on AVIC F20BT
After install of Condi's Hack Mode 2.1 my f30bt didn't want to boot anymore.
I just remove everythibg with
HACKMODE_REMOVAL.rar but it s exactly the samething ![]()
The only screan i have in "THERE IS NO APPLICABLE PROGRAM"
what can i do for restore ?
I finaly resolve my problme !!!
===> The only screan i have in "THERE IS NO APPLICABLE PROGRAM" <========
Big thanks to BlakeStone
What i do it remove all my USER FILE with SUPER TESTMODE
and i put the one of BlakeStone => X9310BT USER Folder
eveything is there => http://home.comcast....nful75/x9310bt/
after a REBOOT everything coming back ![]()
:mrgreen:
:mrgreen:
so before doing anything ALWAYS MAKE A SAVE OF YOUR USER FILE
http://avic411.com/i...otten-password/ IT WORKS ! Thanks BlaeStone. I skip first 3 steps according Pionara suggestions.
Hi! On F940BT work?
Hello,
in the last release V2.2 ist there any GPS problems now or is that problem solved?
Hi the password for the zip files are not working. I used avic411 but it still ask for password
hello condiczek
i have a avic 9310bt unit and have the folders prg0,prg1
can i set a version of igo8 on sd card en copy the exe file from igo8 to the unit to start the igo nav running on sd card?
what file do i have to delete to start the igo8 ?
so i tought rename the igo8 exe file to the pioneer exe nav file name so i can start the igo8 navigation on sd card
greetz simon
When I run the test mode it fails will not load up.. Can anyone give some update on this plz...
Thanks very much for the hack! it worked and its awesome to have my stereo back!
I cannot unzip the file. after entering the password avi411, it asks me to enter the password for HACKMODE.KEY which I do not have. avic411 does not work.
So, I'm very new to this whole deal I have absolutely zero programming experience, I bought a new car and it is equipped with the x930bt, worked beautifully day 1, well then yhe dealer did some work on my car, and now... stereo wants a password, I tried putting this hackmode on my SD card and inserting it in the stereo but it won't go past the password screen, what do I do?
Please don't use condi's hackmode stuff. It can go bad real fast with its use. You don't need it. You only need the supertestmode here: http://avic411.com/index.php?/topic/35253-advanced-puzzles-testmodekey-scriptexecini/&do=findComment&comment=255788
Boot with just the testmode file on the sd card. You need to make sure there is no power to the unit first... put the sd card in and then turn on the ignition for power. It should boot to the developer menu. It should be easy to navigate to the password file and determine what the password is.
a. Grab the test mode files and load it up on the sd card and head over to the head unit..
b. Insert card and load up test mode.. Go to the file manager -> User -> system -> security -> password and do a Text dump of this file.. (thanks to user: odskaggs2 for the hint!)
c. write down the what is on the screen.. This is the password!!! =D
That's it!
The password does not include spaces and periods usually. If you can't figure it out that way, then I think just deleting the file is enough to get in.
Tried using your program and it locked up my AVIC-Z120BT. On the screen it says: 'There is no applicable program'. And there we have it. The screen stays stuck in this screen and I've tried to get out of it but no luck. Is there a fix for this? Or is my unit now garbage? Thanks
/sigh
Password "avic411" is not working. Any hints? I bought a used Honda Civic from a certified dealership and 2 weeks ago the battery died. Now the system is asking for a password. Went to the dealership and "they have no idea what the password is". So I have a useless radio and I'm DEFINITELY not paying $80.
nataliabea9
do not use this tool for recovering your password or doing anything with it... ever.
for password recovery you only need the testmode on an empty sd card here: http://avic411.com/index.php?/topic/32929-x930bt-password-recovery/?p=335762
then continue with the password recovery instructions.
im locked out of my avic x940bt and i used this, but i can do anything but use hackmode. is there anyway i can use hackmode to ulock my unit so i can use it
other than me being locked out it works for avic-x90bt
Hi everyone, any way use this hackmode or just testmode on AVIC-F970bt/dab series (for password reset) ? No SD card slot on device, only 2 USB ports.
Don't know, but TESTMODE (not Hackmode) is harmless. It can't hurt to try.
Testmode doesn't work for my F970DAB. Any other solution??
Hey Condi can you help me please? I just tried to recover password and did everything you wrote by steps and it looks like i did correct but my X930BT shows me "Enter Hackmode? Yes or No" So from here i dont know whats to do =( Even video from youtube stoped from here =( My X930BT steel not working after i change new battery on my car =( I dont remember password =(
