🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 21 of 98
Posted Sep 22, 2012 · 14:44 UTC#501
Do you mean the list in the settings? Can you try reinstalling Applist in Cydia? Someone else just had a similar issue with the app settings and a reinstall fixed it.
I have reinstalled applist but still having the same problem, as soon as I toggle one of the apps in the list it crashes the phone, the phone restarts and comes up with exit safe mode at the top of the screen. To be fair I am having quite a few instability problems so am going to reinstall iOS 6 and jailbreak again. Hopefully that should fix it.
Posted Sep 22, 2012 · 14:50 UTC#502
Is everything else working?
Posted Sep 22, 2012 · 15:49 UTC#503
Good morning!
Mike, you are a man among men. Great job with what this app! This thread is the entire reason I chose an AppRadio (which I just installed yesterday).
I'm having a problem with the RC3 extensions where the screen goes black when I connect my phone. Iphone 4s 16GB IOS 5.1.1 Jailbroken. I installed the three prereqs and made sure Backgrounder wasn't installed.
If I remove RC3 and install the latest release from cydia, it works. Any suggestions for me?
Keep doing what you're doing!
Kev
Edited Sep 22, 2012 by CoachKevinD
Posted Sep 22, 2012 · 17:43 UTC#504
Which screen goes black? iPhone? Radio? both?
Posted Sep 22, 2012 · 21:37 UTC#505
Ok I've done further investigation now. I have freshly installed iOS 6 and re jailbroken. All ok. I installed appradio extensions rc3 and I am finding that it still crashes if you toggle an app in the phone settings menu and also if you plug the phone in to a power source or connect to the app radio it crashes the springboard and through it into safe mode. I uninstalled and reinstalled but still the same. For your info I found another app did the same, Activator. When I installed that it would crash whenever the phone received power. There is definitely an issue with rc3. Without being able to test rc2 I can't tell if its the app or iOS 6. Hope this helps.
Posted Sep 23, 2012 · 03:05 UTC#506
Sorry.. The appradio screenIs the one that goes blank. The appradio app on the iPhone will spin once and stay at the connector image on the display
Edited Sep 25, 2012 by CoachKevinD
Posted Sep 24, 2012 · 15:27 UTC#507
I am having the same problem as CoachKevinD.
I am running iphone4 on 5.1.1 with RC3.
When I launch an app such as Waze/Dashcommand the Appradio screen goes blank but the app loads on the phone. I have also reinstalled RC3 and the prereq's with no change.
Some apps do work such as Inrix and Carmedia player work ok.
Posted Sep 24, 2012 · 19:49 UTC#508
Having Updated the official Appradio App You're now able to post your location via facebook with the button on the left bottom of the screen. The only problem now is.... the SIRI button is blocking it.
Do you plan on moving the SIRI button ?
Edited Sep 24, 2012 by digzz
Posted Sep 25, 2012 · 00:09 UTC#509
Yeah I updated to the new AppRadio App shortly after I updated to RC3. Since RC3 wasn't working I thought I needed to update to the newest AppRadio app that was released today, bad idea!
Now the Extension doesn't work at all. It's like it doesn't exist on the phone anymore.
The AppRadio App works like a normal un-modded app now :(
Anybody else run into this issue?
Posted Sep 25, 2012 · 07:13 UTC#510
Unfortunately I've had to completely scrap app radio extensions now. It will not work for me at all now. The app throws it into safe mode and even plugging into any power source with the extensions app installed does the same. I'm truly gutted, it was a brilliant idea, it just needs a rebuild.
Posted Sep 25, 2012 · 12:17 UTC#511
EDIT: I changed nothing last night except for a double reboot and this morning I tried it in the car and 100% working order and it's much faster :)
Running: iPhone 4s, iOS 5.1.1, AppRadio 1.8.1, AppRadio Extensions 1.9.9-10 (RC3)
Posted Sep 25, 2012 · 14:41 UTC#512
I may have a fix for this. In one of the last few app updates, Pioneer moved around some internal files that I rely on for determining which apps are supported by the AppRadio. I'll post an RC4 with this fix to see if your problem goes away.
Yep.
Glad to hear everything is working. :) I didn't update to the latest version yet and you had me worried that they changed everything.
Posted Sep 25, 2012 · 15:22 UTC#513
Thats great, thanks Mike, looking forward tot he update!
Posted Sep 25, 2012 · 15:31 UTC#514
Once I get the current build finalized for iOS5, I'll start porting it to iOS6. No time frame yet though.
Posted Sep 25, 2012 · 16:49 UTC#515
Posted RC4. Fixed certain apps not showing on the radio screen, pressing system alerts, and the location of the Siri button.
Posted Sep 25, 2012 · 18:48 UTC#516
Superb, I can't wait, I'm missing extensions so much.
Posted Sep 26, 2012 · 03:23 UTC#517
Hi,
Im useing your most recent version of App extension and i have the app radio 2, When i use tomtom as well i get no Gps signal but as soon as i unplug from app radio i get full gps signal. Any way of fixing this? You are doing great work mike thanks for all the dedication.
Posted Sep 26, 2012 · 03:34 UTC#518
The only way I know of is by unplugging the GPS antenna.
http://avic411.com/i...antenna-or-not/
Posted Sep 26, 2012 · 16:00 UTC#519
Ill give this a shot tonight. Thanks!
Posted Sep 26, 2012 · 17:25 UTC#520
Bad news for me. I have been bouncing betweein IOS 5.1.1 and 6, and it looks like Apple has shut down the ability to restore to a saved .ipsw file. (I've been modding android phones for years but this is my first jailbroken ios device, so I unfortunately did not use TinyUmbrella to back up my blobs). I guess I'm stuck waiting for ios6 Jailbreak unless someone here can tell me how to downgrade from 6 to 5.1.1?
Edited Sep 26, 2012 by CoachKevinD
Posted Sep 26, 2012 · 17:32 UTC#521
Bad news for me. I have been bouncing betweein IOS 5.1.1 and 6, and it looks like Apple has shut down the ability to restore to a saved .ipsw file. (I've been modding android phoens for years but this is my first jailbroken ios device, so I unfortunately did not use TinyUmbrella to back up my blobs). I guess I'm stuck waiting for ios6 Jailbreak unless someone here can tell me how to downgrade from 6 to 5.1.1?
Once the signing window for 5.1.1 is closed, there is no way to downgrade unless you have your blob saved. I'm pretty sure there isn't a way to downgrade even with SHSH blobs saved until they update their jailbreak tools. Thats one of the reasons I haven't started porting this project to iOS 6.
A tethered jailbreak has already been released but it's targeted towards developers (no Cydia). If you know your way around the file system, you can get everything up and running.
Edited Sep 26, 2012 by mikedecaro
Posted Sep 26, 2012 · 17:35 UTC#522
Hi mike, I will do this today just out of curiosity is this a app radio issue or an iPhone issue? Or do you k ow ? Or if there will be any way to fix it in the future I'm just wondering If I should rip the antenna out or leave it for now and just unplug it
Chris
Posted Sep 26, 2012 · 17:36 UTC#523
I'll be waiting then. I'm not a developer and this is my first IOS device. I'm completely unfamiliar with the IOS file system. Lesson learned the hard way I guess. Really sucks because your app is the entire reason I chose the AppRadio, and I just installed it on Friday. C'mon IOS6 jailbreak!!
Posted Sep 26, 2012 · 20:38 UTC#524
Hey what's up, if you google ios 6 jailbreak with cydia you will get page after page of instructions on how to do it. I've done it and now have a fully jailbroken iPhone 4 with cydia installed. Most of cydias packages have been upgraded to ios 6 it runs with no problem. My only issue is, unfortunately, appradio extensions is not compatible with ios 6 yet. Patience is a virtue. I'm sure it will be soon.
Posted Sep 26, 2012 · 21:50 UTC#525
Those work for the iPhone 4 because of the A4 processor, but there is nothing out for the 4S yet. Still waiting.
Page 21 of 98
