🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 23 of 98
Posted Oct 03, 2012 · 15:15 UTC#551
It does work on AVH-P8400BH you just need to be in advacned App Mode
Posted Oct 03, 2012 · 22:48 UTC#552
I keep getting a black screen on the radio when clicking on non compatible apps; it's runs through my phone not the radio. I've read everything on the thread, which is mostly just telling of different ways of installing software; basically just reboot after every step and resetting all settings which I've tried but to no avail. I have an appradio one (SPH-DA01), a jailbroken iPhone 4s on iOS 5.1.1 with a properly installed appex 1.9.9-11 and appradio app 1.8.0. I've made sure I don't have backgrounder and I have all the dependencies downloaded. Not sure what RC3 or how to downgrade, could someone please help :) thank you in advance
Side note I'm from Australian if that is any addition information that might be the reason
Edited Oct 03, 2012 by imholy
Posted Oct 03, 2012 · 23:24 UTC#553
Whats the firmware version on the SPHDA01 itself?
Posted Oct 03, 2012 · 23:32 UTC#554
it's on V2.56 firmware
Posted Oct 04, 2012 · 00:33 UTC#555
Just a status update:
Fixed a bunch of issues with landscape lock today. Everything is looking good for a first release on Cydia. Stay tuned.
Posted Oct 04, 2012 · 16:36 UTC#556
Great news!! Thanks a lot!! :-)
Posted Oct 05, 2012 · 02:23 UTC#557
Hey Mike like the work you done so far. I was wondering have you contacted pioneer and got their API for their stereo. I wonder if it would help with some of the bugs. Thanks again for all the work.
Posted Oct 05, 2012 · 17:57 UTC#558
Does this work with the AVIC-Z140 too or just one of the AppRadio head units?
Edited Oct 05, 2012 by Heckler
Posted Oct 05, 2012 · 18:06 UTC#559
No, I doubt they would give me access to the API.
I've only tested with the AppRadio but I've heard that it works with other head units that support "advanced app mode". If the head unit works with the AppRadio app, this should be able to work.
Posted Oct 05, 2012 · 20:24 UTC#560
I can confirm that AppExtensions is working perfectly on the F40BT unit of Pioneer (Advanced Appmode) I'm using it daily :mrgreen:
Brilliant Mike, thanks for all your work.
Posted Oct 10, 2012 · 02:03 UTC#561
Yupp, works with the AVIC-140BT no problems at all. Use it everyday too
Posted Oct 10, 2012 · 02:06 UTC#562
Has anyone updated to the new AppRadio 1.8.2? Wonder if I should stay away or update. The app notification on my iPhone is getting annoying...
Posted Oct 10, 2012 · 02:15 UTC#563
Yes, works fine.
Posted Oct 10, 2012 · 02:56 UTC#564
First, Mike I truly appreciate all the hard work you have put into AppEX and all for free, you're a great man.
Here's my issue. I've seen it mentioned a few times but no fix for it that I've seen yet. (and yes I read the entire post from page 1 to here and its been very helpful) When I plug-in to the AppRadio (SPH-DA01 firmware 2.63) it recognizes my device (iPhone 4s 5.1.1) with the AppEX 1.9.9-11 (verified in Cydia) I try to launch the "Apps" icon on the radio and I get the option to toggle my e-brake bypass (on/off switch to ground) and hit "OK" and all i get is a blank/black screen. The "iPod" icon also shows a blank/black screen. After toying around I opened Pandora on my phone and it forced it to the AppRadio screen as normal so I know my cable is fine. I then took my girlfriend's iPhone 4s with the same specs as mine but without ever installing AppEX and her's works "fine" as designed by Pioneer :P.
I have uninstalled both AppEX and the Appradio app and rebooted my phone and reinstalled everything accordingly but I always get the same outcome with the blank/black screen. What I think is happening and please correct me if im wrong; when I uninstall both the AppRadio app and AppEX they are leaving behind files on the device (plists maybe?) and after reinstalling them since these files still exist somewhere on my phone my problem stil exists.
If this is true how would I do a clean sweep of these files on my device and start from scratch?
You guys are great and I'd like to hear any ideas, as much as I'd hate to I may restore my iPhone if all else fails.
Again Mike you're doing a great job with this and AppEx is 85% of the reason I bought the AppRadio.
Posted Oct 10, 2012 · 03:30 UTC#565
The settings are stored in /var/mobile/Library/Preferences and some data files are stored in /var/mobile/Library/AppRadioExtensions. The only thing I can think of is maybe the Backgrounder.plist is an old version, causing some apps to act inappropriately. Uninstall AppEx and delete the entire AppRadioExtensions folder from the Library. Go through the Preferences folder and delete the files that start with com.decaro.appradioextensions. Test your device without AppEx installed to make sure everything works fine. When you reinstall it, all of the settings should be set back to their defaults.
It's also possible that some other things that you installed from Cydia are conflicting with AppEx.
Edited Oct 10, 2012 by mikedecaro
Posted Oct 10, 2012 · 05:23 UTC#566
SSH scoured my phone and removed all traces of AppRadio and AppEx, rebooted and reinstalled. Works flawlessly again! Thank you!
Posted Oct 11, 2012 · 01:58 UTC#567
Just submitted AppRadio Extensions 2.0 to the repo. Not sure how long it will take to become available. If you have any problems upgrading from the beta to the official release just uninstall the beta, delete the data and settings folders, and try again.
Thanks for all of the help!
Posted Oct 11, 2012 · 15:48 UTC#568
Thank you!
Posted Oct 11, 2012 · 18:46 UTC#569
Any reason to move from the beta to the official?
Posted Oct 11, 2012 · 18:52 UTC#570
Mike,
I've been playing with app extensions for a few days now on my 8400BH. I can confirm that it works even though the touchscreen type on the 8400BH versus AppRadio probably makes it a little less than ideal. It accomplishes a primary goal I had and that was to display the TomTom app on my screen.
I'm using an Iphone4 that I keep tucked in my center console since I've upgraded to an iPhone5. This is because there is no current support for the iPhone5. Because I leave the phone in the car it would be excellent if you could tweak the app (or develop a separate plug-in) that when the phone senses that it's connected to a charger that it autolaunches the iPhone's AppRadio application. I've searched all of Cydia and I haven't found any app that will let me launch or terminate apps based upon detected charge status. Ideally, I'd like to auto-launch AppRadio upon a charger being detected and when the charger is no longer detected (i.e. phone unplugged or vehicle turned off) AppRadio, Pandora, TomTom or any other GPS app would auto terminate. If any of these apps stay running, even the AppRadio app then I find I have a dead battery the next morning. Just an idea that I'm sure others would imploy, especially since many are stuck using a legacy iDevice due to no iPhone5 support.
Thanks again for everything.
Posted Oct 11, 2012 · 19:27 UTC#571
The official release has a bunch of bug fixes, most related to the landscape lock. The settings menu is also a bit different, but it's only a cosmetic change.
The AppRadio app should automatically launch when you plug the phone in if you have the latest firmware installed. You just need to set the bypass to 'Accept' in the AppEx settings.
Activator (available on Cydia) has a trigger for accessory connected and accessory disconnected. I know you can launch an app when you plug the phone in but I'm not sure if you can kill an app when unplugging it.
I'll take a look and see if there is an easy solution to the disconnect issue.
Edited Oct 11, 2012 by mikedecaro
Posted Oct 11, 2012 · 19:57 UTC#572
Take a look at KillBackground (in Cydia). Just set the accessory disconnected action to use this and it should close all backgrounded applications.
Posted Oct 11, 2012 · 20:50 UTC#573
Just downloaded the App. Awesome update Mike!
Posted Oct 12, 2012 · 12:30 UTC#574
Thanks Mike, I didn't even think about activator having an accessory connected trigger. I got it all working now, except for some reason when activator launches the AppRadio application it crashes if I'm plugged into my Pioneer. If I'm plugged into a wall charger it doesn't crash. Anyway, I solved the issue by having activator launch Pioneer's "Car Media Player" app instead, which appears to work with the AppRadio app and it automatically switches over.
KillBackground also works, but it kills the background only. If I leave TomTom open and shut-off the car killbackground (for obvious reasons) won't close it. I have to remember to go to the home screen or to something that I don't mind remaining open like the Music app.
Once again, thanks for everything.
Posted Oct 12, 2012 · 14:46 UTC#575
I too had this problem but since I rebooted the phone it seems to be ok.
I can now get into the car, plug the iphone in and start the igniton and the Appradio app loads. I dont even have to unlock the phone any more.
Page 23 of 98
