🔒 Locked
AppRadio Extensions 2.0 Beta - Full iPhone control
By mikedecaro · May 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 2,444 posts👁️ 945,070 views
Page 22 of 98
Posted Sep 26, 2012 · 21:54 UTC#526
Hey guys,
actually I have an iPhone 4S with iOS 5.1.1 and have installed the Extension RC2. When I start the AppRadio-App without connecting
the iPhone tp the Radio and tap on the "compatible Apss"-Button the App. Starts loading and loading, but nothing happens.
When I connect the iPhone to the Radio and start the app.-Mode and tap on compatible apps on the radio screen I see the same screen as I describe above. It's loading and loading but no apps are shown on the radio screen.
When I choose some Apps in the Extension, for example Navigon or Safari, they were also not on the radio screen. I know that the Extension works, because when I put the clock in the Extension option on it shows me the clock on the radio screen.
Shortly, it shows me no support or any unsupport app on the radio screen, only a loading symbol.
I hope someone of you could help me with my problem.
Thanks and greetings and good evening from Germany
A411
P.S. Sorry for that bad English, hope you could undertand my text.
Posted Sep 26, 2012 · 21:59 UTC#527
Can you update to RC4 and see if you have the same problem?
Posted Sep 26, 2012 · 23:12 UTC#528
Hey what's up, if you google ios 6 jailbreak with cydia you will get page after page of instructions on how to do it. I've done it and now have a fully jailbroken iPhone 4 with cydia installed. Most of cydias packages have been upgraded to ios 6 it runs with no problem. My only issue is, unfortunately, appradio extensions is not compatible with ios 6 yet. Patience is a virtue. I'm sure it will be soon.
Attitude is everything. :-P :-P :-P
Posted Sep 27, 2012 · 02:55 UTC#529
Sorry, I didnt mean to sound offish
Posted Sep 27, 2012 · 03:04 UTC#530
"Patience is a virtue. I'm sure it will be soon."
Your attitude is GOOD. :-P :-P :-P
Posted Sep 27, 2012 · 17:23 UTC#531
Posted Yesterday, 11:59 PM
Hey mikedecaro,
thanks for the update info, it works perfect now after a restart of the iDevice. It is an amazing Extension tomorrow I will send you a donation.
Hope it comes an update for iOS 6 soon.
Thanks for your time that you invest in this Extension.
a411
Edited Sep 27, 2012 by A411.com
Posted Sep 28, 2012 · 10:11 UTC#532
Everything was fine until I updated "App Radio" app via itunes on my iphone 4: BLACK SCREEN on Appradio (1). Tried everything - with/without extensions.. But it is the original app from Pioneer that causes the black screen......
So DON'T UPDATE the app!
Posted Sep 28, 2012 · 14:47 UTC#533
I just tested the newest version of the AppRadio app on my iPhone 4 running 5.1.1 and everything worked fine. Did you try deleting the app and installing a clean version? What is the radio's firmware version?
Posted Sep 28, 2012 · 17:40 UTC#534
I am really sorry.......
I used a dock cable extender and that cable was the problem.....
Works fine with app radio 1.8.1 and RC4 on iphone 4 16GB (Appradio is on 1.63).
Thanks for your work!
Edited Sep 28, 2012 by User77
Posted Sep 29, 2012 · 10:25 UTC#535
Hi,
I am running on RC4 (1.63 iOS 5.1.1):
1.) my mail.app keeps in landscape mode - after unplugging from apradio. Till I respring / reboot
2.) no "force single display" anymore? This would be very helpful because I got my iphone next to the display of my appradio...
Edited Sep 29, 2012 by User77
Posted Sep 29, 2012 · 10:44 UTC#536
Hi,
Hey,
I have the same issue with a landscape lock on the mail app. Though I don't gave a fix, I found that once you unplug your phone from the radio that you can exit out of mail, than double click the home button and x out of mail. It puts it back to normal w/o having to reboot/respring.
I haven't brought it up on the forum yet but I guess if I'm not the only one having the problem, we can assume there are more people that also have the same issue.
Posted Sep 29, 2012 · 11:15 UTC#537
You re right:
Close and restart mail.app solves also the problem. Thanks!
Posted Sep 29, 2012 · 18:46 UTC#538
Hi,
For one display just run app with backrounder work fine :-)
Posted Sep 30, 2012 · 03:05 UTC#539
Fixed this issue, should be available in the next release.
Posted Sep 30, 2012 · 19:29 UTC#540
Thanks a lot!
Can you please say sth about the missing "force single display"? Was there a problem?
Posted Sep 30, 2012 · 19:47 UTC#541
It's not missing. I just changed the name of the setting so it makes more sense. "Force Mirrored Display" prevents apps from using the second display, so the iPhone screen can be mirrored.
For example, Navigon added a screen that displays a message stating something like "maps can not be viewed on an external display due to license restrictions". Enabling Navigon in Force Mirrored Display prevents it from showing this screen, allowing the navigation to be mirrored to the radio.
Edited Sep 30, 2012 by mikedecaro
Posted Sep 30, 2012 · 20:05 UTC#542
Thanks for the explanation!
I had trouble wirh my dock extender csble so I hant test RC4 completely...
Posted Oct 01, 2012 · 10:00 UTC#543
Update:
When I choose "Mirrored Display" for an app then I got both displays: iPhone and Appradio. And the option "force landscape" doesnt work: its only in landscape if I turn the iPhone horizontal...
Edited Oct 01, 2012 by User77
Posted Oct 01, 2012 · 16:13 UTC#544
this is probably an appradio software issue over the appradio extensions itself but just thought id mention it. ive updated both appradio app and appradio extensions to rc4, while playing pandora a popup will make the screen go black on the appradio. bitesms pop up or notification center pull down is what i did and experienced it with, after closing said popups pandora would show up again.
Posted Oct 02, 2012 · 16:54 UTC#545
I've came across this with bitesms too, when a text pops up it causes the screen to go black as the pop up shows up on top of whatever app is running. Not sure if there is a way around this other than removing it altogether.
Posted Oct 02, 2012 · 17:37 UTC#546
I don't have bitesms so I can't test it. Can you try uninstalling the extensions and see if the screen still goes blank when you get a message?
Posted Oct 02, 2012 · 20:44 UTC#547
Hey guys, i wanted to know if the latest AR extensions work with the latest AR update from pioneer?
Posted Oct 02, 2012 · 23:42 UTC#548
hey mike,, im new to this forum. and came across this, and im really really impress.. i know this is for app radio
but i was wondering if there is any way in chance will this work . on my 8400 bh .. can you please help me to get this work on there.
im running ipod 4th gen 5.0.1 n avh 8400bh.. please help thank,..
Posted Oct 02, 2012 · 23:47 UTC#549
i installed everything and uninsallted backgrounder... but everytime i click on a app like angry bird.. on my ipod it switches over n then it shows up but cant control anything..
Posted Oct 03, 2012 · 15:10 UTC#550
As far as I know, yes. I'm using an AppRadio 1 with the latest firmware and the most recent AppRadio app.
Not sure if it works on the 8400. All of my testing was done on the AppRadio. If the AppRadio app works on that head unit, this should work as well.
Page 22 of 98
