Hi im having the same problem with my f900bt and I have tried everything It keeps saying 'system startup in progress, please wait' and then reboots constantly Regardless of speed or antenna in or out. I have tried updating the firmware but it just doesnt load the sd card or usb, I have downloaded the test mode but still it does not read The sd card or usb. I cant get into settings or maps, Someone plaese help!! Thank you
Basic Reboot Loop Fix
Hi take in my folders the folder name plt open it take the 2 files winces inside and put this files in your sd card and go in your car put the sd card on your device and do this : to go to the secret menu put the 3 button in the same time (map,menu,eject) and with stylet in reset when tke screen was black retire the stylet of reset and take the 3 buttons with your fingers (eject,map,menu)you go on the blue screen choice upgrade wince with sd card and let the avic read the folders when is finish to read turn off and after retire your sd card and with testmode you can enter into the device. Do this and tell what is happen
I believe I have got the wrong test file downloaded as the file I have hasnt got any folders in it. Where will I be able to download the right file from?
P.S I need the files for EU as im from England
it' s original pioneer files 2009000 version be certain your green fil connected on your parking brake ,because you can have screen bloked in red screen
https://drive.google.com/file/d/0B7FEE9jYpumyQVdvazFzUkNscVk/edit?usp=sharing
My f900 has gone all blank now, everytime I try some sort of update or test node or wince update it dont work. Now its all blank and even the reset button doesnt do anything
some1 plz help
https://drive.google.com/file/d/0B7FEE9jYpumyeG9yQ0R2Z2g5dXc/edit?usp=sharing
try this folder do the same copy 2 files of folder plt and format wince after reading files turn off your car and with testmode take all files and copy all folders in my flash disk and it was ok
some1 plz help
i have no idea where to get the test mode files from, I have always thought service mode and test mode was the same thing but I have just found out they are different. Now I cant find the test mode files anywhere. I have tried like 20 pages of google search ![]()
Update: ive managed to update wince and ive managed To downgrade back to the firat firmware without maps. But now the screen backlight comes on and nothing more, plus I can get into testmode but the problem is I dont have a stylus pen so its very hard for me to select and options around the edge of the screen. What should I do now?
hi use a pencil in side was not where you write and do the calibration of screen , i can give you the folder of map which country you want?
I need UK maps please but I think i still have an original pioneer CD for the AVIC but i dont know what it is for. Furthermore I have got into test mode and i am trying to change the sdmlc but none of the functions in test mode are working. and after update i have managed to get into the menu but the maps and av sources are not working.
Hi the folder of map united kingdom
https://drive.google.com/file/d/0B7FEE9jYpumya1VvUlZGcXpJbzA/edit?usp=sharing
Thank You i will try this as soon as possible
Update: I have done everything with no success, I have updated wince, installed firmware 2.00900, formated sdmlc, pasted backup files to my flash disk, installed maps. And I have had no luck now it just boots up and stays on the flash screen and I can only access system settings and nothing else. Please help I have now ran out of ideas and cannot find any further help on this matter elsewhere
delete user data ,and take the folder to be in 3.....
Can you provide European Maps with Portugal maps ?
Hi,
I have a 940BT (Euro version) that starts and reboots after approx 15 seconds.
Will the files in the torrent and and the process described in this thread help me?
Or are these files for US version only?
Hi lillbabs it's euro program not for your device only bt 700,710,900,
salut cesarpt le dossier avec la carte du portugal
Do you think this well help if I only get a blue screen when my radio turns on?
Hy,
i have a problem with avic f920bt - it doesn't start
can anyone please help me with the original files?
thanks
Hi your country is usa canada or european union ? i have full back up for avic 900bt i don't know he can work on your unit but i can give you all files i have.
Hi new here and was trying to get the files to try and fix an avic f900bt in the uk that is just lighting the buttons up blue for around 15 seconds then switching off,hopefully this will fix it.
Thank,s in advance.
