CNSD-310FM EU 2012 update
By radeonorama · Nov 17, 2012in Hacks/Mods💬 282 posts👁️ 116,695 views
Page 5 of 12
Posted Jan 12, 2013 · 17:19 UTC#101
Work a treat on my AVIC-F10BT just follow the guild and IT WORKS UK version
Posted Jan 16, 2013 · 22:23 UTC#103
yes, it is... ;)
Posted Jan 17, 2013 · 11:19 UTC#104
Advance App Mode for iPhone only works with cable.
The CD-IU201S is required for AppRadio Mode functionality and also enables audio and video playback from your iPhone® 4S or iPhone® 4
Source:http://www.pioneerel...ables/CD-IU201S
This update brings a change which allows you to set the connection to Wired or Bluetooth, not that I can get it to work, as I have an iPhone 5
Posted Jan 18, 2013 · 21:37 UTC#105
Hi pionara,
i followed your instructions and the update worked good, but when i tried updating the bluetooth i get a msg that an error has accrued and then my bluetooth stopped working... what should i do now?
thanks in advance.
Posted Jan 18, 2013 · 23:44 UTC#106
Hello. I have a problem:
After updating my F930BT I have only German voice, but no TTS. Voice of cd folder copied to sd card, I have also tried to install it, either. Where problems are de?
------- Can anyone give the TTS German Files for avic 40BT? --------------
Edited Jan 18, 2013 by koropez
Posted Jan 19, 2013 · 00:09 UTC#107
I did this update on my f920bt and the bluetooth failed... i get a msg that the update was failed and now the bluetooth is NOT working!!!! any suggestions to fix it? please help!
Posted Jan 19, 2013 · 01:04 UTC#108
hi
Only one question for you. Can you pls tell me if i can update my Avic F900BT with this update ?
If not why ? im just wondernig :)
I/ve recently bought SD from pioneer cnsd-300. but still looking for some fresh maps for EU
Thx in advance
Posted Jan 19, 2013 · 17:15 UTC#109
hi
Thx in advance
the f900bt is older then the f 920bt f930bt f940bt and is totally different hardware so wont work
Posted Jan 20, 2013 · 23:00 UTC#110
Hi,
did you try to do the BT update a second time ?
Hi,
you must create a folder "voice" on an sd card, in which you create another folder "TTS" and put all the 8 german tts files found on the DVD in it.
then you put the sd card in the avic, go to the voices menu and you should see something like "install from sd"... ;)
Edited Jan 20, 2013 by frisk
Posted Jan 21, 2013 · 16:01 UTC#111
tnx .work to f920bt on ROMANIA
Posted Jan 21, 2013 · 19:48 UTC#112
Hi,
Hi,
But the problem is that I do not have on DVD German TTS voice, maybe if there is anyone , give me :-)
Edited Jan 21, 2013 by koropez
Posted Jan 21, 2013 · 21:56 UTC#113
sorry, I've got almost all of them but not the german one...
I had the same problem with the french TTS voice that wasn't there after the update (and wasn't on my DVD!)
Edited Jan 22, 2013 by frisk
Posted Jan 25, 2013 · 00:00 UTC#114
Is it possible to provide information on speed cameras on the road?
Posted Jan 25, 2013 · 00:27 UTC#115
Thank you very much Radeonorama and Pionara! :-D
Upgraded from CNSD-210FM and all went smoothly on my F10BT using a SanDisk 4gb SDHC Class 4 card.
UK maps look fine, happy days :-D
Can't see AppRadio at the moment but I assume that functionality will appear once I plug in the CD-IU51V iphone cable to the unit.
Posted Jan 25, 2013 · 21:47 UTC#116
on F930BT works great. Map's are very good!
Upgrade went easily.
Thank you very much Radeonorama and Pionara!!
We'll wait now for more hacks, like avicnet, but on our AVIC's.
Best Regards from Poland!
Posted Jan 27, 2013 · 16:10 UTC#117
Hi all i want to try it with Avic F10 Bt is it all right ? does anybody here made a test ?
Posted Feb 04, 2013 · 22:49 UTC#119
Perfect! Works great on my F930BT, Dutch menu's and Dutch TTS. All are in the package. The only thing missing is the Speedcam warning. If anyone can help me with that, that would be wonderfull. thanks in advanced :mrgreen:
Posted Feb 05, 2013 · 16:28 UTC#120
I'm a bit curious. Pioneer says, that this update enables advanced app mode on 920bt, 930bt and etc. So the question is:
Did anybody try to run iGo Primo Navigation with iPhone via usb/aux cable using the Advanced app mode on Pioneer 920bt or 930bt? Doest it work, and if it works, is it possible to use iPhone, lets say browse the web on mobile phone meanwhile the Advanced app mode is running on it? Thanks.
http://www.pioneer.eu/eur/page/products/advanced-app-mode.html
I would try but I'm using second hand F920BT which came with no USB/Aux cable which I'm looking for.
Edited Feb 05, 2013 by vyttux
Posted Feb 05, 2013 · 20:27 UTC#121
Hello,
works great on f9310bt (VW)
Thanx
Posted Feb 06, 2013 · 07:33 UTC#122
Hi at every one, after the upgrade i lost my tts language, unfortunately i have not backuped it....
i try to install a zip file with tts file without luck, anyone have the original tts to past into the system?
thanks a lot
Posted Feb 07, 2013 · 08:43 UTC#123
Please help!!!
I try to uprgade x930bt.
Maps now 2012, Euro.
But After rebooting, device splash "Program update started", then from 2 sec. "Program update failed" , and rebooting.
Now no one testmodes not working.
Posted Feb 08, 2013 · 19:58 UTC#124
Hey, since I'm having BT issues when connected to an Android phone (does not show mp3info etc) I would like to update the BT firmware.
Would updating BT firmware without updating the rest work? I'm on v3.0 now with BT firmware 3.22.
Edited Feb 09, 2013 by Firewalker1980
Posted Feb 09, 2013 · 21:55 UTC#125
updated today, works like charm, thanks a lot  :mrgreen:
Page 5 of 12
