hi pionara
I change files and format card again, unit start automatic updates from 0% and finish again on 99% , then message "wrong card, replace card ....."
hi pionara
hi pionara
read the thread i linked to. this means you have some corrupted files on your update. maybe bad card, maybe bad update.
download update again, try new sd card, try again
Hi
Pionara can you share for me all update from the different source,
Can you send me link to update. I'm still waiting for my new microSD.
I dont have any files. You will have to find those for yourself.
Hi
pionara doesnt have the files, they have been provided by my and are clearly working fine for others and 100% worked for me. I would put a guess on a screwed card or your download was corrupt. If an alternate download is offered, they are only going to be based on the files i uploaded anyway.
Try and redownload. Perhaps use a download manager like internet download manager. That always works nicely for me.
Hi guys,
First of all, thanks for the software.
I have an avic f930bt eu, and, at about 49% i get the message, update failed do you want to retry?
Of course i tried that, but with no succes.
now i have the testmode software because i want to try to delete the update part, i have read about this at this thread http://avic411.com/i...sd/#entry258286
I can get to the directories but if i am in USER\SYSTEM\RENEWAL there is no Progress.dat to delete.
When i am in USER\SYSTEM\Download\ there is no StartKnd.log to delete
I only get very strange signs with dir behind it and they seem to be empty.
is it possible for the f930? do you guys know where or how to do it?
The F930BT doesn't restart the update automatically, it starts up with my normal starting screen but after that the screen goes black, although menu is there but not functioning.
I have formatted my 8 gb sdhc en re-installed the software, i have even tried to unpack the download with another unzip programm.
I am now downloading for the 2nd time the software.
I dont have any backup files and yes i know, STUPID!
I even have tried to put the files on a new sd card (4 gb sdhc) but its the same effect, it starts, normal starting screen, then i get the question do you want to update, i select yes, screen goes black, doesn't reboot, no reaction.
thank you for your answers.
Hi driverke,
I own a F9310BT (F930BT EU designed for Volkswagen). I've done the update with success.
On a FAT32 microSD >= 4Gb :
FIRMWARE folder 1,98 Mo (2 077 336 octets), 1 subfolder and 3 files. (for BlueTooth)
UPDATE folder 3,37 Go (3 621 773 202 octets), 18 subfolders and 216 files.
CARDINFO.cif file 300 octets (300 octets).
Make sure that in the UPDATE folder the " VERINFO.DAT " file (40 o) is pionara's one.
Hi driverke,
Hi Joss,
Thanks for your answer.
I have done all that.
I have checked the files and everything should be there.
I have used the verinfo.dat from pionara.
I have fiddled around with testmode and can get in the directories.
In my post above, i have insterted a link to a topic, also here on avic411.
There they talk about how to delete some software and your unit would return into normal mode.
But that's for a F10BT.
So i am wondering if its possible to do the same with a f930bt.
In the past i have had problems with a powerdip after glowing (diesel).
So it might be possible that my memory is damaged (which i don't hope).
Don't know if this F10BT method can apply to F930BT, files can be different.
You get very strange signs with dir behind, you mean that directories names are non-standard characters ? Perhaps caused by a transfer interruption, reading/writing errors or damaged sectors in NAND memory.
Care, i'm not a specialist.
Before upgrade my USER\SYSTEM\Download\ folder was empty, i would try to copy and erase these strange elements, then try to restart navi or upgrade.If it's a NAND failure perhaps there is the relevant test tool in the Super testmode but these sensitive functions are not recommended.
Hi Everyone.
Thanks Pionara and Radeonorama
I tried and tried, and resolve problem!!!!!!!!!!!!!
I tried lot of memory cards but ONE from them is the best. Kingston MicroSDHC 8GB class 4. This card resolve My problem. If someone had the same problem and update was finished on 99% or earlier and Avic show information about wrong card must a change card.
Thanks again, Good luck.
Thanks joss,
I will try to copy and then delete the download folder.
And restart. i have the kingston 8 gb sdhc class 4 card as in post above.
Pionara, maybe u have an idea?
Hi driverke,
Last things: erase the contents of Download folder or erase it and recreate one empty.
Perhaps you have a PRG.FLG file on the root of USER, it means that you'll load applications from the PRG1 updated folder and no more from the PRG0. If your PRG1 is damaged perhaps you can load the system from PRG0 original applications just by backup and remove the PRG.FLG. I never tried. There's few threads on PRG.FLG.
Your MicroSD model is ok, you suceed to boot on it, and you didn't get a "wrong card" error message. You can also checkdisk it from pc.
Hi driverke,
Hi joss,
Thank you so very much for your answers.
Meanwhil i've got grip of the original files 3.001, the only thing is that they are from a x930bt (USA).
Can i use them?
But, first of all i will try your tips!
Greetz,
Driverke
US applications and functions are not exactly the same as EU ones. I would favorise EU sources.
thx,
i knew that
u know a place where i can find them?
No, never looked for. Did some tests ?
Hi joss,
Can i use them?
Greetz,
Driverke
Yes, you can use that us software for the purpose of manually replacing. It is the same software
Hi Pionara,
Thanks for your response.
Are there more people who had these problems with the update (looking here, it seems to be that i am a loner)?
Do you have any suggestions?
Can i manually replace all files?
I have read about somebody who had the same problems after using hackmode.
Hello,
Radeonorama and Pionara : thank you!
I just did the update during a one hour travel this morning and everything went flawlessly.
Now I'm going to figure out what changed with this update... I've already seen that now my android phone send the mp3 tags via BT when using BT audio and the apparition of the city names in the POI list, but I'm sure there are a lots of other new things to discover.
Greetings.
EDIT 1 : after testing everything, it seems that there was a problem with the TTS voices during the update. all recorded voices are present and can be selected in the language menu but I've lost the western europe TTS voices (FRF, GED, SPE, ...) which aren't in the TTSData folder anymore. Now there are other TTS voices that weren't here before (CZC, FIF, GRG, HUH, PLP, TRT) and they can be selected in the language menu.
And the most surprising is the ENG voice which is present in the TTSDATA folder and is not present in the language menu... ![]()
EDIT 2 : the "azerty" keyboard used in France was replaced by a "qwerty" keyboard... there is a true problem with the localization.
"Nach dem Upgrade des AVIC-... mit diesem Produkt entsprechen die Funktionen und die Bedienung annähernd dem AVIC-F940BT bzw. AVIC-F40BT.
hier mal für alle Deutschsprachigen:
01) Download die rar vom Link im ersten Post oder hier klick mich
02) Entpacke die Datei an einem sicherem Platz
03) Öffne den entpackten Ortner und gehe in den Ordner Update
04) ersetze die Datei VERINFO.DAT mit der aus dem zweiten Post von pionara oder diese Datei klick mich nehmen
05) Kopiere alle Dateien, welche entpackt wurden auf einer lehren SD-Karte (4GB+)
Die Dateistruktur müsste wie folgt aussehen:
FIRMWARE (Ordner)
Update (Ordner)
CARDINFO.cif (Datei)
06) stecke die Datei in dein Autoradio, gehe dabei sicher, dass das Auto gestartet ist oder die Batterie am Ladegerät hängt, damit es während des Updates keine Ausfälle gibt
07) Das AVIC macht einen Reboot und startet neu
08) folge den Anleitungen auf dem Bildschirm, Dauer ca. 20min.
09) manchmal fragt das AVIC am Ende, ob das Update noch einmal starten soll, einfach nein drücken.
10) Gehe in den Bluetooth Einstellungen und und starte das Update der Bluetooth Firmware. das dauert meist noch länger als das AVIC Update -> ca. 25min.
Die Dateien sind kein Hack für das Upgrade, sie kommen offiziell von Pioneer, es wurde lediglich die Datei VERINFO.DAT so geändert, dass kein Passwort für das Update angefragt wird.
vom 2. Post:
Die existierende Datei cardinfo.cif ist für die EU Versionen des AVIC F930 & F30 etc., aber wer ein F10, F20, or F920 etc. besitzt, muss die Datei cardinfo.cif editieren. Öffnet die Datei mit dem Texteditor, sucht nach der Stelle:
KMQ1S8PF5CUQE7LKUX
und ersetzte diese Stelle mit folgender:
X07EURX27EURX30EUR oder diese Datei klick mich nehmen
alle Links und Dateien ohne Gewehr
Dear all,
I have a feq questions due i'm new in the navigation world.
I currently have a Pioneer F930 BT (EU version) with 2011 software+maps (11/12)
I would really like to update my F930bt this way, but i got a few questions:
Which maps are included? (whole europe or west europe?) I mostly need cards of BeNeLux, Germany, and France
And the Language of the system? Can i install the dutch language again?
How is the first time right % of this update? Because i don't have a backup of my current maps/ system.
Is there a way to make a back up of my current system and maps?
Thanks in forward for ur help
King regards,
Rick van Haaren, Netherlands
Hi Rick,
Just finished the upgrade with succes on my F930BT. I have put all the files on a 8GB micro sd and did the upgrade. After the upgrade you first select english (Dutch is not selectable) and after the reboot you can change the language to dutch. Didn't check the country's yet.
Hello,
Greetings.
So, these 2 "problems" are solved. The 6 TTS voices installed with the update (CZC, FIF, GRG, HUH, PLP, TRT) can't be modified but at least, I can install one (and only one) optional TTS voice (I have DAD, DUB, ENG, FRF, NON, PTP, SPE and SWS : if you need one, just ask
) with an SD card following the official way : my french TTS voice "Virginie" is back... And for the QWERTY keyboard, there is an option to modifiy it to AZERTY but it's only visible when we enter an address! ![]()
Hello all, I have kindly been given access to the CNSD-310FM EU 2012 update and have the CARDINFO.cif and VERINFO.DAT files which hopefully with a little help from pionara, will make the update function for us EU users?!
The full update is currently uploading so i will post a link to that once it becomes available. (21%)
The link for the full update is here
To do the update on an F930BT you just have to:
01) Download the rar from the link above above.
02) Extract it to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with the one in pionara's second post on this thread.
05) Copy everything you extracted onto a clean 4GB+ SD Card
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif (file))
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer should reboot and start the update.
08) Follow the on screen prompts
09) Once completed, it may ask you to update again, if so, select no.
10) Enter Bluetooth settings and update the bluetooth firmware. (This seemed to take longer than i expected but dont worry, it does eventually get there!
The above files are not a hack to do the upgrade, they are the official Pioneer Update Files. The only hack is with the VERINFO.DAT which I believe all it does is bypass the passcode request when the update starts. There shouldnt really be any reason for this to fail.
As always, with anything like this, I would always advise you backup first!
Cheers, Radeonorama
Thanks It'sworking perfectly on avic F10
Hello ,
I have an AVIC 9310BT ( VW version) of 930BT ; with September 2011 version of software and TELEATLAS map.
I would like to thank people posting here all details with a lot of patience to same type of questions coming ; I have read the thread but like everyone would like to be sure %100 before I do anything with the unit.
I would like to have the update installed as well and have few questions ;
1- Will the update cover the same map area as I have ( All EU installed ?? I am in Turkey so need East EU actually) , new version will be NAVTEQ 2012 map installed is it correct ?
2- Will the update make the new app mode enabled as well ; waiting for buying iphone apps ( this is the main reason for me to update )
3- How do you get the backup of the current system , I would like to get prepared for anything going wrong just in case ?
4- Should you need using 4GB or 8 GB MicroSD card only ( do you need class 4 ; I wonder if my 32 GB class 10 microSD card is ok to proceed, if not thinking to buy 8Gb Sandisk Class 4.
5- SD card placing time ; if I run the car first ; the unit starts immediately, should the card placed after the unit starts or ?
I can already run internet radio from my iphone to the unit and change radio stations from my steering wheel controls, wondering if I can use my google maps or other maps I buy from appstore after update?
sorry for the disturbance if this thread is only telling how to update
Once again Thank you for your support.
