CNSD-310FM EU 2012 update
By radeonorama · Nov 17, 2012in Hacks/Mods💬 282 posts👁️ 116,695 views
Page 2 of 12
Posted Nov 20, 2012 · 07:23 UTC#26
This update is workink with F940BT ??? Anibody try this on this unit?
Is not in waranty so i will lose nothing if i change something (It was already instal in car,but the owner dont give me papers or waranty :neutral: )
Btw. Thanks for your valuable work Pionara !
Edited Nov 20, 2012 by livirys
Posted Nov 20, 2012 · 08:37 UTC#27
F940BT is already 2012 software. you can get 4.010 update from pioneer.eu - dont need anything special here for that
Posted Nov 20, 2012 · 10:16 UTC#28
Thank you nice Work
update my AVIC F9210BT in Germany :mrgreen:
Posted Nov 20, 2012 · 16:48 UTC#29
Hello,
Please can you says me if this update is ok with an avic f10bt use in france? please. Before i make a fatal error :?
thanks
Posted Nov 20, 2012 · 18:16 UTC#30
sacrebleu!
Read the freaking posts:
#2
Posted Nov 20, 2012 · 19:38 UTC#31
Hello,
ok thanks, sorry, i'm french and i'm not sure to have good anderstand all instruction, it's was why i prefere ask before do something.
I have a last question, please, how i can do i save of my actual firmware, is a have problem, for come back? i don't find tuto.
please, thanks
Posted Nov 20, 2012 · 20:58 UTC#32
Worked like a charm on F930BT! Thank you so much! Greetings from Austria!
Posted Nov 21, 2012 · 16:47 UTC#33
Hey,
Also tested this firmware and on my F930BT works realy FINE.
THANKS !!
About the cabel please look:
http://allegro.pl/ka...html#tabsAnchor
I have bought my F930BT unit from this guy. The cost is about 32 pounds but i don't know the cost of sending abroad (England If I good understand) ??
Edited Nov 21, 2012 by RafRoo
Posted Nov 21, 2012 · 21:08 UTC#34
Hey,
THANKS !!
Thanks for the suggestion but it would appear they dont ship to the UK. :-( Thanks again.
Posted Nov 22, 2012 · 18:28 UTC#35
hello,
someone know if i can make a backup of my original firmware before upgrade. it's a f10bt
thanks
Posted Nov 23, 2012 · 19:48 UTC#36
I have upgraded my 9210bt. So it was tested and worked with 9210 as expected.
Thanks a lot!
Posted Nov 24, 2012 · 00:42 UTC#37
Hi
Avic F9210BT, System after passing 99% shows me the "wrong card, change the card to continue." I do not know what to do next, nothing works. Please Help. Someone may have a solution.
Posted Nov 24, 2012 · 10:58 UTC#38
hai
thanx for all the work
I have a strange problem. I followed the instructions but when i put the sd card in the unit nothing happens. The files and directories are in the way that is described in the posts. I have succesfully updated the bluetooth to 3.24, but the unit does'nt start the firmware upgrade. I am using an 8gb sdcard (instead of a 4gb), but is that a problem?
I have an f9220bt which i have previously updated to f30BT-software using more or less the same method, and the same Sdcard.
But now nothing happens.
Anyone can help?
Edited Nov 24, 2012 by idude
Posted Nov 24, 2012 · 11:52 UTC#39
hello,
perfect on f10bt, thanks
Posted Nov 24, 2012 · 14:37 UTC#40
Thanks Pionara.
It works flawlesly, F920BT from Spain.
Posted Nov 24, 2012 · 16:26 UTC#41
bodziek,
try reformat sdcard, then recopy files. if that doesnt work, try new sdcard, reformatted, and recopy files
idude,
did you follow instructions about editing Cardinfo.cif?
Posted Nov 24, 2012 · 18:45 UTC#42
Hi everyone,
Pleased to enter your forum.
I followed the radeonorama's procedure (post #1) with the VERINFO.DAT from pionara (post #2). This CNSD-310FM EU 2012 upgrade works well on a F9310BT (september 2011 release). Thanks to you radeonorama and to you pionara :-)
For information the versions below are retrieved booting with pionara's "supertestmode" testmode.key copied on a microSD (note: copy/paste functions enabled).
AVIC F9310BT initial versions:
PRODUCT NUMBER= AVIC-F930BT / XNEU5
NAVI INFORMATION= NX072/EU5
REGION CODE= 2
APL PROGRAM= 3.001
VOLUME INFORMATION= 3
BLUETOOTH FIRMWARE= 3.22
Versions upgraded:
APL PROGRAM= 4.01
VOLUME INFORMATION= 4
BLUETOOTH FIRMWARE= 3.24
Note:
-First boot after upgrade i set the french language but the next boot the system was in a kind of norvegian language. Looking in the regional settings the french softkey is selected. Switched to english (reboot), came back to the regional settings, and reselected french to recover my language, and a normal heart rhythm..!
That's all for this thread.
I'm now on the quest of the softmod to neutralize the caution screen for the video while driving.
@pionara: you let understand that there is a solution, in the post #2 of this thread:
http://avic411.com/index.php?/topic/35540-new-firmware-pioneer-401-and-bypass/page__hl__f940bt&do=findComment&comment=258314
But I have some difficulties to find the method. Is it because there is no softmod for this feature but only hardmod (around Velocity Speed Sensor signal) ?
@radeonorama: sorry I cannot help you for your cable.
Thanks to everyone helping, if I can, just ask.
Posted Nov 24, 2012 · 22:24 UTC#43
hi pionara
i used memory card 16gb, maybe my card is too large,
Posted Nov 25, 2012 · 10:26 UTC#44
hi pionara
Is it a cheap brand of card or one of the known good brands such as Sandisk?
Did you format it in Windows using the Default allocation unit size?
I had no issues updating with this using a Sandisk 8GB MicroSD card on an F920BT.
Posted Nov 25, 2012 · 11:35 UTC#45
Worked well on F10-BT (was on version 3)
However, the upgrade from 4.00 to 4.01 was not successful (system doesn't recognize/start any upgrade.)
Can 4.01 be achieved with older hardware models than Fx40-BT?
Posted Nov 25, 2012 · 15:41 UTC#46
syros - this update already takes you to application version 4.010. You dont need the update that is for f40bt. That is only for a stock f40/940 that has application version 4.000.
Edited Nov 25, 2012 by pionara
Posted Nov 25, 2012 · 18:02 UTC#47
Indeed:) Thanks again!
Kudos to radeonorama for sharing
Posted Nov 26, 2012 · 12:03 UTC#48
hi pionara
reformatting my card and put again into device not give me difference, only on screen is information "wrong install updates do you want install again" and press button "RETRY" Unit installs updates and after 0,5s back to the "wrong install updates do you want install again" and when i press "RETRY" is exactly to same again. Now i ordered 8GB Kingston micro sd card class 6 and a will try again.
Posted Nov 26, 2012 · 12:05 UTC#49
bodziek,
idude,
hi pionara
Posted Nov 26, 2012 · 15:29 UTC#50
follow these steps to kick the unit out of upgrade mode:
#9
Page 2 of 12
