Nice work ![]()
Do you have tomtom fully working or are there still bugs?
Does any of the alternative navigation software support TMC maybe?
Nice work ![]()
Nice work
got 3 versions, 1st worked ok, but after some driving crashed with not enough memory message, 2nd works ok - need to test it more, 3rd is earlier version - will work 100% if 2nd one will fail
im sorry, i've got not much of free time recently, gonna finish tests asap and share here ready-to-go shell + each gps software.
Gold Job condiczek. I wait your shell
Sanik, this morning I have be able to prove pioneerus and the igo8. Pioneerus works but when the igo8 stars to load (the logo appears )it stop and returns to the gray screen. What happens? Thanks
Have to delete the fold pioneerusfirstinstallus?
Excuse me. I had not finished writing. I want to say that if I had to delete the folder FirstInstall of Sd Card.
I have delete this folder and the Igo8 don't stars. I have prove with tomtom and the same. The tomtom star and then appears the gray screen. What can I do?
got Sygic (almost) working
Hi, I'm new at this, I installed z140bh on my car and I was woundering how can I install Sygic on my system, thanks in advance.
Pioneerus Can be uninstalled from the device? How?
I still do not understand what your problem is. Why did you removed something from somewhere?
Add Igo 8.3-compatible maps to content\map folder. Igo cannot work without maps.
I don't removed anything. Igo8 begins to load (in the screen appears the logo igo) but a few seconds after the logo disappears and gray screen appears again. My device is the avic f940bt and the firmware is the 4.000. I hope I explained and I'm sorry for mi bad English
I think my problem is the navigator. Igo8 stops when in the screen appears the logo igo8 and "language". I think but I can be wrong
Please try this way!
hola, puedes decirme donde bajo el pioneerus y como lo hago para pagar los 50 esos que dices? gracias
Hola Alexis99. Tienes que enviar un privado a Sanik y el te dirá una cuenta de correo donde pagar los 50$ por paypal.. Después te envÃa un archivo de texto con instrucciones en inglés, un archivo con el pioneerus y un archivo con el navegador igo8 pero sin mapas. Si te animas a adquirirlo nos ponemos en contacto e intentamos sacarle el máximo rendimiento. Como ponÃa instalar el pioneerus es fácil. El problema lo estoy teniendo para insertar el navegador.
Yesterday I got it the navigator Igo8 run in the pioneer. The problem was that I erased the file language Russian. I am going to try install tomtom but I don't know where get it to install at pioneerus. Any idea?
How did you do it? I'm very interested to do run the tomtom in pioneerus. ThanksOK GUYS. TomTom with sound!!
New version 1.2 avaible!
What's new in V1.2
Fixed bug that sometimes
caused reboots during first start of Pionerus.
Brand new algohave been re-written from
scratch.As result now official navigation software does not loose connection to
satellites and that have increased stability of virtual GPS port.
Fixed bug that caused screen freezingvolume
adjustment.
New shell added to Pioneerus screen.
Buttons and passes to navigation programs can be adjusted via editing
"pioneerus.cfg" file.
Some minor tweaks
Aha that was what the email was about ![]()
My russian is not that what it used to be anymore.
What's new in V1.2
adjustment.
Some minor tweaks
How to do to upgrade?
What's new in V1.2
adjustment.
Some minor tweaks
Where's the download link and instructions?
Magosasueldo, check you private messages, please.
Ok. Thanks
Igo8 running on a F9210BT.
