X930BT runs alternative navigation
By Ralpharn · Mar 11, 2013in Hacks/Mods💬 184 posts👁️ 73,582 views
Page 4 of 8
Posted May 08, 2013 · 00:27 UTC#76
I've tried to run Sygic on my X930BT, got stack at activation screen. Activation code it gave me is:  XXXX-XXXX-XXXX-XXXX instead of normal letter/decimal code. Any ideas how to get correct code?
Add: Now I can see Device ID code but Sygic doesn't want to sell activation code to private person for automotive in-dash navigator. :evil:
Edited May 10, 2013 by Ralpharn
Posted May 10, 2013 · 13:09 UTC#77
i installed pioneerus and everything went fine, except i have no sound from igo.
does someone know how to fix it?
i have a x930bt
Edited May 10, 2013 by otavio15
Posted May 10, 2013 · 13:23 UTC#78
Turn Beep On. (button press sound in the shell)
Posted May 11, 2013 · 21:43 UTC#79
Hi,
I have a Z140BH and I´m from Brazil.
Is the Pioneerus compatible to this device? Also my only problem is to use GPS with Brazil map, any software.
Tkx
Posted May 13, 2013 · 01:34 UTC#80
Yes.
Posted May 14, 2013 · 13:23 UTC#81
I´m trying to get Tomtom or Navigon to work, but with no luck, can somebody help ?
Posted May 14, 2013 · 16:25 UTC#82
Igo have fresh maps for all world. Best maps from Navteq and TomTom. And you can find too many skins and addons for it.
Posted May 16, 2013 · 06:16 UTC#83
i know, Igo is OK.
But it´s fun to try to see the another Navigation program run.
Posted May 16, 2013 · 12:35 UTC#84
Can someone please tel me where to find this soft., Or is it the same as condi's hackmode v2.21??
Posted May 17, 2013 · 06:11 UTC#85
just finish to install gps Igo in my AVIC Z-120BT. BEAUTIFUL!!!!!!!
Edited May 17, 2013 by dinodpg
Posted May 17, 2013 · 06:54 UTC#86
Now someone know where to download navitel to install in ou hu?
Posted May 18, 2013 · 12:27 UTC#87
hello. After installing pioneerus, to start igo8 igo get stuck on the logo. One doubts the maps come in a "fbl"?
Posted May 18, 2013 · 21:23 UTC#88
Insert fbl maps in Igo8\content\map folder at SD card
Posted May 18, 2013 · 22:17 UTC#89
I did it. And also tested in a computer emulator wince 6 and works well.
Posted May 19, 2013 · 08:16 UTC#90
Try to delete \Igo8\save folder and reconfigure Igo again
Posted May 19, 2013 · 11:55 UTC#91
Thank you. worked. and take this opportunity to say that you did a good job pioneerus is fantastic. One more question. to add a video player it will work?
Posted May 19, 2013 · 19:04 UTC#92
Try TCPMP, it may be work
Posted May 19, 2013 · 23:56 UTC#93
THANK YOU AGAIN!!!!!!!
Posted May 20, 2013 · 11:05 UTC#94
Yesterday I got it the navigator Igo8 run in the pioneer. The problem was that I erased the file language Russian. I am going to try install tomtom but I don't know where get it to install at pioneerus. Any idea?
 Hi - I'm having the same problem. What russian language file did you erase? And what did you do to get the iGo program to start? I just get the iGo startscreen briefly and then it returns to the Pioneerus menu....
Posted May 21, 2013 · 09:58 UTC#95
Hi - got it working! iGo needs to configure on first startup - if something fails (like wrong or missing language- or voice files), delete the save folder and try again.
Now I just hope, that TMC will be fixed, as I need that functionality :-)
And I would also like that sound in iGo could work without "beep" enabled in general - the beeps annoys me! :-)
But thanks until now!
Posted May 27, 2013 · 03:23 UTC#96
My device has no "home" button. How could I switch to the alternative navigation? Does "menu" works?
Posted May 27, 2013 · 15:28 UTC#97
Without Home? What model?
Posted Jun 01, 2013 · 08:58 UTC#98
jg500 ,for roewe350. Only have menu, av, navi, phone buttons and a volume knob.
Posted Jun 03, 2013 · 17:51 UTC#99
Please post photo of general menu. May be, it is not avicz110 series device?
Posted Jun 04, 2013 · 04:54 UTC#100
Page 4 of 8
