2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 14 of 18
Posted Jun 13, 2014 · 21:15 UTC#326
Funciona perfecto en el f-40 bt muchas gracias
Posted Jun 17, 2014 · 18:43 UTC#327
Hello, i have a F930BT unit with the 2013 EU Update, has worked well previously, but the battery discharged completely and had to replace it and now the unit asks for a password that is not what it was previously. Is there any way to bypass the password? Thanks.
Best Regards.
Posted Jun 18, 2014 · 22:01 UTC#328
Juancho 1980
tuviste que reemplazar los dos files, cardinfo y verinfo?
saludos
Edited Jun 18, 2014 by husus1
Posted Jun 19, 2014 · 14:46 UTC#329
HUSUS1, YA TE CONTESTO YO POR EL: SI, Y OTRA COSA
ADEMAS DE ESTOS MODELOS:
PARA QUE MODELOS MAS FUNCIONA LA ACTUALIZACION?
BESIDES THESE MODELS:
F30 F40 F940 F840 F930 F9310 F8430
FOR MORE MODELS UPDATE WORKS?
Posted Jun 22, 2014 · 21:29 UTC#330
Hi to all
if I understand....cardinfo.cif....dat ? (f940bt)
oups...edit :
940bt is a 930bt with 2012 software and map so... yes, you can follow the first post to update your 940bt.
But you don't need to change the Cardinfo.cif  just use the original one.
Edited Jun 23, 2014 by lafrance
Posted Jun 24, 2014 · 17:15 UTC#331
F930BT works grate!
Good work!
Posted Jun 25, 2014 · 19:41 UTC#332
What about record files to DVD and then install to F20BT? Is it possible?
Posted Jun 30, 2014 · 18:08 UTC#333
F20BT update successful via microSD 4GB. Thank you!!!
Posted Jul 14, 2014 · 14:32 UTC#334
Perfecto!!!  :grin:  :grin:  :grin:  :grin:
Posted Jul 28, 2014 · 17:07 UTC#335
@PUG
here are the instructions, you can put them in the first post.
INSTRUCTIONS
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the  VERINFO.DAT with this one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
Please be sure that you did everything as mentioned above. It's better to make a backup of your system before updating.
For those with Avic F10BT,  F20BT or F920Bt
Download this  CARDINFO.CIF
Open the original CARDINF.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps.
Regards
Hi! To update the F940BT its all the same like F930BT? No need to change CARDINFO.cif, only change the VERYINFO.dat right?
Best regards!!
Posted Jul 31, 2014 · 07:30 UTC#336
Hola para pioneer avic f-910bt esta actualización  es valida gracias
Posted Aug 01, 2014 · 13:20 UTC#337
How to make a backup of the system?
Do I need a particular software?
Please suggest me a topic with instructions!
Posted Aug 04, 2014 · 07:05 UTC#338
BACKUP MODE
  • download the TESTMODE for your device and put to the root of your SD-CARD
  • instert SD to your AVIC, Pioneer Service Mode will appear,
  • move down and enter FILE MAINTENANCE,
  • go to USER, select COPY on the menu,
  • move up, and go to SD,
  • select PASTE on the menu,
  • once it finish - BACKUP IS DONE.
  • now hold EJECT button for 5s to get to sd card, take it and connect to pc,
  • copy USER directory somewhere safe on your computer and delete it from SD.
Posted Aug 04, 2014 · 09:31 UTC#339
perfect and easy instructions...but where can I download testmode for F940bt?
BACKUP MODE
Posted Aug 04, 2014 · 11:50 UTC#341
cardinfo is used in the f-9220?
thanks
que cardinfo debo usar en el f-9220 el que viene original o debo modificarlo?
saludos
Edited Aug 04, 2014 by husus1
Posted Aug 04, 2014 · 19:37 UTC#342
I've been keeping an eye for 2014 updates.
Not confident they will be released.
The 2014 maps are out for the F50BT, F950DAB etc but not the models here.
I've just purchased the F50BT updates so will be interesting to see if the maps can be transferred over to a hacked F930BT update file or not....
Posted Aug 06, 2014 · 09:47 UTC#343
Hi this update is valid for avic F910Bt?
thank you
Posted Aug 06, 2014 · 23:06 UTC#344
thanks is a reply for my question
Posted Aug 08, 2014 · 17:52 UTC#345
Hello Pug,
I have an Avic F9310BT and asking myself exactly the same questions as you about the latest 2014 update. If anyone has any answers, he is welcome.
Posted Aug 08, 2014 · 18:45 UTC#346
Well I'm having trouble accessing the update card.
Stick it in the computer and it's saying no disk inserted.
Think I need to try a linux based machine......
Posted Aug 08, 2014 · 22:21 UTC#347
thanks pug for your update
Posted Aug 14, 2014 · 13:34 UTC#348
Hi there,
I've followed the instructions to the letter but when I put the card into the unit, it asks for a password. What is it please?
UPDATE: Note to self. Read the b****y instructions properly.
Works great, thanks!  :-P
Edited Aug 14, 2014 by rosbif
Posted Aug 18, 2014 · 12:42 UTC#349
Hi Guys,
Can this update work on the Pioneer AVIC-F3210BT? Does anyone know?
Posted Aug 21, 2014 · 15:00 UTC#350
Ho seguito passo passo la guida e tutto Ok. Ma nel  momento che inserisco la sd nel navigatore mi chiede la psw
pere aggiornare, come posso recuperarla. grazie
I followed step by step guide and everything is OK. But by the time I insert the sd in the browser asks me the psw
pears update, how can I retrieve it. thank you
Page 14 of 18
