grazie
2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
Does anyone have a manual in German for the Avic-F940BT ? thx
Ho seguito passo passo la guida e tutto Ok. Ma nel momento che inserisco la sd nel navigatore mi chiede la psw
pere aggiornare, come posso recuperarla. grazie
I followed step by step guide and everything is OK. But by the time I insert the sd in the browser asks me the psw
pears update, how can I retrieve it. thank you
I would like to upgrade my system navigation map but i don't understand this post very well, where is the link to download the new map and in which mode i transfer its in my sd!?!?
Just update my F930bt without any problems. Followed the install steps.
Took around 20 minutes. At first Dutch wasn't available only English UK (and other locales) with Flemish voice (weird).
But once I went to the language menu Dutch was available. So that was nice.
I was running end 2010 software and map. I saw with the 2013 update, that the source menu icons on the left of the screen now has app radio.
Also the big icon for sources has changed (when you tap Menu).
Hallo,
muss man sich bei 4shared anmelden um das Update laden zu können, oder sind die links down?
Kann leider ohne Anmeldung nichts laden und wollte mich ungern anmelden.
Danke für Ratschläge!
Have some one used this on à f9110bt?
How do i make system backup ?
Hello,
im totally new on the avic scene, i have an avic f9110BT and i was wondering if it was possible to do this upgrade on my unit
tkanks a lot,
hello don't work on f9110 avic too?
Hello guys.
I'm new on this. i bought recently a Pioneer AVIC F3210BT and my version is 2.0000
Can you tell me if i can update the version by following this steps?
thanks
Hi,
I did the update on my F9210BT. The update was successful. Thanks a lot for that.
Hello. I've done an upgrade for Avic F20BT with success. Thanks a lot. Will make a donation ASAP.
I've been keeping an eye for 2014 updates.
Not confident they will be released.
The 2014 maps are out for the F50BT, F950DAB etc but not the models here.
I've just purchased the F50BT updates so will be interesting to see if the maps can be transferred over to a hacked F930BT update file or not..ca
would you share maps for f50 bt ?
Will this work for 710BT?
Hello,
it is work´s on Avic - F220 too?
Anyone got a 2014 update?
@PUG
here are the instructions, you can put them in the first post.
INSTRUCTIONS
To do the update on an F930BT you just have to:
01) Download the files from the links above.
02) Extract them to a safe place.
03) Open the extracted folders and go into the Update folder
04) Replace the VERINFO.DAT with this one.
05) Copy everything you extracted onto a clean 4GB+ SD Card which has been FAT32 Complete Formated
(make sure that the files and folders on the route of the SD card are:
FIRMWARE (folder)
Update (folder)
CARDINFO.cif
06) Put it in your Car (with the engine running or on a charger etc)
07) The Pioneer will ask you if you want to run the update choose ((yes)) the device will reboot and start the update.
08) Wait untill the update is completed
09) Once completed, it may ask you to update again, if so, select ((No)).
10) If you want to update your Bluetooth firmware then, enter Bluetooth settings and update the bluetooth firmware.
Please be sure that you did everything as mentioned above. It's better to make a backup of your system before updating.
For those with Avic F10BT, F20BT or F920Bt
Download this CARDINFO.CIF
Open the original CARDINF.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR
With
X07EURX27EURX30EUR
If you did everything correctly, you will have your AVIC updated to version 5.0 with the newest Europe Maps.
Regards
tried updating my australian AVIC F910 with the above instructions only to play some chinese conversations, lol. what 's the fix pls?
To update my F920bt I change the cardinf.cif do I also need to replace Verinfo.dat or is that for models above F920 thanks
Yes, you have to replace Verinfo.dat ![]()
​Everything is alright for the F920bt I got the same.
Hello guys,
Will this work on F320bt ?
I have version 1.004 , Is it a big issue it`s a bit out of date ?
I`ll make a donate with pleasure if it works...
yesterday i have updated my f920bt. It works perfectly (language: german).
Many thanks!
Hi, I'm new here, is that installed the map update 2013 and ending no more update (100%) is reset (normal) but here comes the problem, it just restarts. The image was wearing (logo) It gets the message and leaves the browser and reset again. There is no time to play anything, just leave 3-4 seconds before turning to reset.
the device is never updated avic F20BT. Versions were:
Platform version 2.000
Application version 2.003
version 02.0000
Bluetooht firmware version 3.11
Mecha version 01.03.01-00
What could be the problem? I do the steps as put, changing VERINFO And cardinfo, but nothing.
Someone could tell me something? Please !! Do not know what else to try.
A greeting and thanks !!
PS: sorry for my English, I'm Spanish.
From NL: just updated my AVIC F930BT: great job (!) donation is on its way ![]()
