2013 EU UPDATE F30 F930 F9310 F40 F940 F840 F8430
By pug · Sep 18, 2013in Hacks/Mods💬 445 posts👁️ 226,654 views
Page 17 of 18
Posted Feb 27, 2015 · 13:53 UTC#401
Hello i have download all the parts but i don't understand wich of these parts must i use?
I have a avic-F40BT
Posted Mar 04, 2015 · 14:11 UTC#402
hello, i tried to update my avic f10 bt, i put the sd card it started and then at 92 % it tells me rong sd introduce the corect sd card and it does this over and over no mather what i do, how can i make it work with or without the update, please help all it does now it shows the message insert the sd card to continue
Posted Mar 11, 2015 · 15:49 UTC#403
I download everything and make step by step as you showed and works great on my F920bt
Thanks a lot!!
what kind of sd card you used?
Edited Mar 11, 2015 by Janikra
Posted Mar 23, 2015 · 18:02 UTC#404
Guys please i need help. I read all post. Tested my F920BT with 4 difrent sd card, full format, use totall commander to move files. Same problem update starts and after fiu seconds "wrong sd card". I need my radio.
Posted Apr 02, 2015 · 13:21 UTC#405
Help!! prosze pomozcie
Posted Apr 04, 2015 · 11:59 UTC#406
bonjour j ai le meme souci sur un f500bt j ai tenter la mise a jour mais rien ne fonctionne quelqu un aurait une solution s il vous plait ?
Posted Apr 12, 2015 · 10:57 UTC#407
THANKS,  working perfectly on my AVIC F20BT :-P   and , i m not loosing my TTS files (french) after the reboot.
I also upgrade my bluetooth :)
Posted Apr 12, 2015 · 22:12 UTC#408
Hi, i was wondering of anyone could assist. When extracting the downloads (using 7zip), I keep getting an error message, either saying "Data error in encrypted file......Wrong Password?" or "CRC failed in encryptted file.....Wrong Password?" I'm using the password from the opening post so i'm not sure what it's asking for. From what I can see the files are NDATA.046 & NDATA.099. if anyone has any ideas i would be very thankful
Posted Apr 13, 2015 · 21:32 UTC#409
Hie tweedcladgent
I have exactly the same probleme with NDATA.070. And because of that this file was not unzip.
something going wrong when you download all fille. You should download againe "Pioneer 2013 update.(don t remembrer if it s part1 2 or 3 4 or 5 ...)
Posted Apr 23, 2015 · 09:33 UTC#410
Hello Everyone!
I updated my F940BT One year ago without any problem with the help of this topic but now I figure out one problem.
I would like to update to newest maps but all I can see overthere is about WinCE, My Flash Disk... And I have none of that. All I have with the testmode key is a screen like this video
and even if I made a back up of my files, I still don't know how to update the map because in the structure of the files, I have none of the APL2 or MAPS files.
Here is a picture of what I have in the USER folder and in the NDATA/NDATA folder
Thanks in advance for your help!
Posted May 23, 2015 · 13:45 UTC#411
People who want fixed cameras, to send me a private message and I send you.
alexis99,you may send the file via email cameras ? thanks! My email: [email protected]
Posted Jun 09, 2015 · 12:25 UTC#412
mid of 2013 ,  the last update  arrived.
now its mid of 2015 and it seems nothing will happen in future for the update.
If you look at map update page they request 149 EURO for 2013 update,
made the flawless update with the directions here instead.
Additionally paid less then 20 EURO for IGO Premio in Iphone to use via app-radio mode. its the only possibility to have newer map right now.
Posted Jun 12, 2015 · 08:09 UTC#413
Great JOB,
Every think works perfectly on 920BT. I just followed instructions.
I did update from 2.000 system.
PodziÄ™kowaÅ‚ ;)
Posted Jun 18, 2015 · 10:17 UTC#414
Enybody has this verinfo.dat file? The link to download it isn't working
False alarm.
Edited Jun 18, 2015 by tymek24
Posted Jun 18, 2015 · 10:18 UTC#415
I want also to backup my files before updating. What is the procedure?
Posted Jun 21, 2015 · 15:35 UTC#416
Successful update f30bt
Posted Jun 22, 2015 · 14:25 UTC#417
CONFIRMED! AVIC-F10BT works perfectly! Falowed instruction, put sd in player and after 30 min update have been completed sucefuly! Thanks!
Posted Jul 02, 2015 · 08:45 UTC#418
Does anyone have now the 2015 Update? Can he give it to me?
Posted Jul 05, 2015 · 17:09 UTC#419
Thanks a lot to Travolta, Pionara!
Installé en 30 min sur Avic F9210BT. Aucune sauvegarde à faire: :-P tous mes paramètres sont restés (français, BT, stations radio, ...).
Instructions suivies à la lettre: parfaites.
Half an hour on my Avic F9210BT to install. No backup done: 8) no modification done to radio, BT, french language...
Great topic!
Thanks again !
Posted Jul 06, 2015 · 10:11 UTC#420
Thanks a lot for the Update. No need to install the German TTS. My F30bt talk in German even after the Update :D
Edited Jul 07, 2015 by fingerhoch
Posted Jul 06, 2015 · 17:17 UTC#421
Alleluia , after missing 2014, the 2015 European map update T1000-23347 for AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT is finally available !
Pug, Pionara , you are expected in a new dedicated topic.
Edited Jul 06, 2015 by darktom67
Posted Jul 19, 2015 · 20:27 UTC#422
hi,
thanks for your effort. My device is F940BT. When I insert the sd-card, Show "password from Pioneer must be entered to continue with the update." I touched "yes" then asked me password. I deleted anti-theft password but still asks. I try 1111, 9999, 1234 but not entered. What can I do or what is password?
Thanks for help.
Posted Jul 20, 2015 · 11:47 UTC#423
That would indeed be very nice! :)
Posted Jul 21, 2015 · 10:03 UTC#424
I agree it would be great : )
Posted Aug 01, 2015 · 11:51 UTC#425
Hoe is het mogelijk om de navigatie kaarten van AVIC-F9110BT te updaten? Kan iemand me hiermee helpen?
How is it possible to update the Europe maps from AVIC-F9110BT? Can anyone help me?
Page 17 of 18
