2013 USA/CAN Maps Download
By misterwoofwoof · Mar 08, 2014in Hacks/Mods💬 317 posts👁️ 150,467 views
Page 6 of 13
Posted May 13, 2014 · 07:27 UTC#126
rgarjr and anttid,
Thank you for your responses.
Posted May 16, 2014 · 23:57 UTC#127
Worked like a charm on my z130BT. Showed my gratitude via PayPal.
Posted May 18, 2014 · 00:54 UTC#128
I have z110bt with the cnsd-11fm update, I used the card that came with that and it says wrong card and will not move from that screen? I tried a hard reset still nothing.
Posted May 20, 2014 · 12:13 UTC#129
Ok fixed problem, had to use the 2012 file.
Posted May 22, 2014 · 00:19 UTC#130
is anyone having problems downloading this... mine will get most of the way through then just tell me download failed   4 times now  takes like 3 hours each time   quite agrivating any ideas?
Posted May 22, 2014 · 04:02 UTC#131
well i finally succesfully downloaded files unzipped to sd card copied other file over and when inserted into z140bh nothing happens doesnt pop up with update as instructions tell me
do i need testmodekey?
Posted May 24, 2014 · 06:27 UTC#132
All you have to do is unzip the files and put them in the root of your SD card, then place the CARDINFO.cif from here CARDINFO.zip  into your SD card.
Posted May 29, 2014 · 23:09 UTC#133
Worked like a champ on my x920bt. VR still works for music on iPod.
Posted May 29, 2014 · 23:29 UTC#134
I have a z130bt updated to z140bh (software update) so do I use the z140bh instructions and file or z130?
Also, is there a way to install this update in testmode? I have another unit that has corrupt files and will only go to testmode...
Edited May 29, 2014 by pcguy760
Posted May 30, 2014 · 00:21 UTC#135
Z130 and Z140 updates are the same!  You can always manually install files, but you have to know what files to load!  My advise to everyone is to stop trying to do something you have no knowledge about!  You either deleted needed files or installed Condi hack, which in turn crippled your system!  Send it to Pioneer to fix and stop trying shit you don't have any knowledge about.
Posted May 30, 2014 · 03:27 UTC#136
LOL and this is?? Your answer and contribution to my question? LOL. Nice way to increase your post count eh? Just for the record, the unit is now working after manually installing some of the files. So hows that for trying "shit" I "dont have any knowledge about" ??? In your face fool.
Posted May 30, 2014 · 05:20 UTC#137
Hi, I have the X920BT, and mines not working.  About 20% the update stops.  Telling me to reinsert SD card.
I tried different types of SD card, no luck.  reformatted, no luck.  Used most of the Cardinfo.cif....
What version or file name is the correct one with the right date stamp and time?  Please help!! Im trying to get this to work..
Thanks!!! :eek:
Posted May 30, 2014 · 11:21 UTC#138
I used the one in the first post of this thread...no errors or anything funky. It just worked.
Posted May 30, 2014 · 13:17 UTC#139
...Used most of the Cardinfo.cif....
If you have the wrong CardInfo, the HU will just do nothing (or maybe start searching for playable media files) when you insert the SD. That should help you verify that you have the right one.
There's something wrong with the SD - either the card (unlikely since you've used several) or the files on it. I can't be more specific than that. Try downloading and extracting the upgrade again. Maybe it is caused by the program you are using to decompress/expand the archive.
Posted May 30, 2014 · 17:02 UTC#140
Thanks for your help!! I My unit is stock, Ver 2.0000 i believe.  Does the unit itself needs to be mod/hack?
I will download again.  I'm using winzip.  The SD card i'm using is a SanDisk ultra 32GB microSDHC class 10, i formatted to Fat32.
Would the fat32 have a problem?  It was on ExFat.
What decompress program should I use?
Should I download the file on the computer or mobile phone?  Previous post people had issues on the DL.
You guys awesome on helping out!! :-P
Posted May 30, 2014 · 21:50 UTC#141
Yeah it has to be on FAT32. It does not need any mods or hacks. Simply extract the map files onto your SD card and extract the corresponding cardinfo.sif file onto the root of your SD card.
Posted May 31, 2014 · 02:05 UTC#142
According to the user manual the HU only officially supports up to 16GB. I use 4GB. As noted, format FAT32. I use WinRAR v3.8 but WinZip should work. Be sure you tell it to unpack files into the original directory structure. Otherwise it extracts all files into one directory.
Edited May 31, 2014 by RonS
Posted May 31, 2014 · 03:29 UTC#143
I would like to thank everyone that helped me on this.  I guess the 5th time is the charm.
Steps I did for the X920BT:
1.  Downloaded the file using Firefox version 29.
2.  Did a reg. format to FAT32.  (Not quick format)
3.  Extract the zip file using 7-zip file program (freeware).  I got no errors this time, even tested the file.  Extracted right into the microSD card. (SanDisk Ultra 32GB Class 10)
4.  Inserted the microSD card into unit, Update menu appeared. Whoa!!! Yup!!
5.  Ran all updates time duration was like 30 mins.  Plus the Bluetooth upgrade firmware also.
Tip:  Make sure your car battery is in good condition, my car battery was weak last night running it.  Ran 4 times trying to update the 2013 map.
Everyone have a wonderful weekend!!! Peace!  :-P8)
Posted May 31, 2014 · 20:17 UTC#144
Thanks... This worked for my previously upgraded Z130bt.
Posted Jun 15, 2014 · 14:38 UTC#145
Awesome! Thanks
Posted Jun 16, 2014 · 18:52 UTC#146
Got this to work for me on X9310BT after fighting with the "insert the correct sd card" error.
What ended up working for me was the full format to fat32 with the 16k allocation unit size
I also unzipped to my pc with winrar and then individually copied to the microSD card, the FIRMWARE folder first and then the Update folder next and finally the correct CardInfo.cif file.
Edited Jun 16, 2014 by BlakeStone
Posted Jun 18, 2014 · 13:26 UTC#147
Worked great on my X930BT. Not only upgrades the nav maps to 2013 but also includes update for blue tooth firmware and new buttons for Aha radio and Pandora. Thank you so much. This is what I needed.
With that being said, can someone please explain to me why I would want to install the Condi Hack. I know this is propably in another thread, but can't seem to find an answer. If the condi hack does not work with the GPS, what would be the main reason someone would want to install it? Is someone is willing to answer this, please provide a list of what the condi hack does/includes. Thanks and excuse if this is a repeat question. I am noob and trying to learn.
Edited Jun 18, 2014 by donrich
Posted Jun 18, 2014 · 20:14 UTC#148
... With that being said, can someone please explain to me why I would want to install the Condi Hack. I know this is propably in another thread, but can't seem to find an answer. If the condi hack does not work with the GPS, what would be the main reason someone would want to install it? Is someone is willing to answer this, please provide a list of what the condi hack does/includes. Thanks and excuse if this is a repeat question. I am noob and trying to learn.
No reason in the world - its just a dangerous toy. It has bricked many units. I've asked several times for the moderators to pull it, or at least post WARNINGS. You've now been warned.
Edited Jun 19, 2014 by RonS
Posted Jun 18, 2014 · 21:58 UTC#149
Sounds great!   I have a couple of questions --
* Will this update directly from version 3.00x?   (I have a z130bt running 3.001)
* Does this update include the nag screen removal?  (I implemented the nag screen removal hack last year, but on 3.001)
Thanks.  John
This should work directly from any version including 3.00x. And no it does not have the nag screen removal. Nothing has been modified except to bypass the password requirement for the update.
Hi,
Was anyone successful in updating a Z130BT running 3.0000? I followed the instructions exactly and was only able to update bluetooth firmware (to 3.32).  I am going to wipe out the SD card completely and try again, as I had some older AVIC files on the SD card (feeds, wallpaper picture, etc) and cross my fingers... Will post results.
Thx,
Jenn
Posted Jun 18, 2014 · 22:32 UTC#150
Hi,
Thx,
Jenn
Its updating now ;) Removed all other files from SD card (less ones DL'd via instructions) and now updating as expected. GRACIAS...sending some $$ your way now :)
Page 6 of 13
