Official AVIC NEX Bypass (AVIC NEX Units Only)
By installereric · Mar 25, 2014in NEX Series💬 318 posts👁️ 344,345 views
Page 13 of 13
Posted Dec 04, 2019 · 16:17 UTC#301
I've had a 4400NEX installed for about 7 months.  Setup with the touchscreen bypass on firmware 1.01.  Able to watch DVD fine in motion.  Can anyone confirm whether or not the new firmware (1.02) will change that?  The new version claims to fix my steering wheel buttons in AA (which is my only real complaint), but I am hesitant to update...
Posted Dec 12, 2019 · 16:23 UTC#302
On Z8500, with source off, the traditional lower left bypass hack does not seem to respond at all
Posted Dec 15, 2019 · 11:03 UTC#303
Hello everyone! Though I'm a long-time avid reader, I'm new to posting on the AVIC411 forums and I'm so impressed that this 5+ year-old thread is still alive and well, while it continues to be such a source of knowledge, comfort, and inspiration to so many, including myself.
First, I can confirm that this bypass is working perfectly on an 8200NEX (firmware 1.08) with Maestro RR and "proper" wire installation (parking brake wire from harness connected to parking brake wire from Maestro; not grounded). No warning signs about improper parking brake wire install at all. Both Carplay and Android Auto (henceforth "AA") working fine.
I recently switched to a W8500NEX, updated to latest firmware (1.03), still with Maestro RR, installed exactly the same way as the 8200NEX. Bypass is still working fine. However, I'm having an issue with AA being stuck on the warning screen about stopping your vehicle and/or applying parking brake (phone: Pixel 3 XL). I was wondering if anyone has found a way around this issue? Someone mentioned earlier in this thread that AA required the parking brake wire to be grounded, can anyone confirm this? I had it working fine on my 8200NEX without grounding, so I'm a bit skeptical with that solution. I'm also wary that people who chose to ground their parking brake wire have gotten the intermittent warning about improper wire installation. Does anyone have a W8500NEX (or even a W8400NEX) and have AA working (wired or wireless)? If so, do you recommend I ground my parking brake wire?
Thanks in advance for all your gracious time and insightful information.
Edited Dec 15, 2019 by sampark1980
Posted Feb 13, 2020 · 17:52 UTC#304
Hello!
New here and soon to be owner of the AVIC-W8500NEX (well my wife will be at least).  I wanted to ask a quick question regarding the on-screen process vs. a mini-bypass device.  What are the pro's and con's of either or?  I'm tempted to go the device route since I already have one and for rest assurance.  Anyone have any opinions about this?
Posted Apr 30, 2020 · 00:19 UTC#305
Thanks in advance for all your gracious time and insightful inormation.
anyone have an answer to this? i am about to do an install of the 8500 and would like to use AA while in motion. i do not want the improper wire installation pop up. that would drive me batty. i am leaning toward wiring up the p-brake wire "properly" and not grounding it to avoid the error message.
Edited Apr 30, 2020 by -hef-
Posted Jun 15, 2020 · 03:51 UTC#306
Anyone have any inside information for how to bypass the new NEX models (DMH-WT7600NEX and DMH-WT8600NEX) with the new software?
The old trick doesn’t work.
Posted Jun 25, 2020 · 19:51 UTC#307
Same! I have the 8600, trick won’t work. Having a hard time getting video in motion.
Posted Jul 03, 2020 · 13:40 UTC#308
Hi. After many hours of screen presses, I figured it out. The Pioneer DMH-W and DMH-WT models have a special hidden menu bypass requirement. No interface bypass is required, but you can leave it connected if it is already installed. Dean and Fernando at Five Star Audio made a video of it on the tubes if you’d rather see it than read it. Here is how to do it:
1. Update the firmware to 1.13
2. Enable the hidden menu bypass by sourcing the radio off (source off, not power off).
3. Press and hold the bottom left corner of the screen for exactly 10 seconds (use a stopwatch as timing is critical).
4. Within 1 second, press and hold the bottom right corner (to the immediate left of bluetooth icon) for 10-12 seconds until a small “set on” icon will appear (in the bottom middle of the screen) confirming the bypass has been activated.
5. If you do not get it the first time, cycle the ignition off and back on and start over.
6. If you need to reverse this process, reset the radio.
Posted Jul 04, 2020 · 01:25 UTC#309
THANK YOU!!!  You just made several people very happy!
Posted Jan 02, 2021 · 00:59 UTC#310
AVIC-8600NEX has no firmware update available. Did the 10 second press on bottom left trick. Display reports, "set on" but AA still complains parking brake not set.
Posted Apr 17, 2021 · 13:49 UTC#311
And yet another option that is low cost that I use on my AVH-x5600 is a single pole double throw rocker switch.
Wire the green from the HU to the center terminal, and ground wire to either of the other 2 terminals.
Mount switch in inconspicuous place with easy access. After HU is powered flip the switch off then on.
Viola, tricks the HU into thinking the Pbrake is on.
Posted Jan 04, 2022 · 01:09 UTC#312
is there a bypass for 4400NEX ?
what AA stands for?
Posted Jan 13, 2022 · 19:43 UTC#313
I used the DIYBypass wire with chip.  It auto grounds each time you power up.  So far so good.
http://www.diybypass.com/instructions2.html
Posted Jan 14, 2022 · 23:39 UTC#314
Mircoswitch bypass not needed for NEX models
Edited Jan 14, 2022 by bonee
Posted Jan 19, 2022 · 23:44 UTC#315
I have an AVIC-W8600NEX.  i could not get video or Android Auto to function until I grounded the green brake wire.  Even with the secret lower left bypass set to on, I still had to ground that green wire.
Posted Aug 04, 2023 · 02:14 UTC#316
Did anyone with the AVIC W8600NEX get video in motion to work using the screen quadrant bypass? Considering swapping my W8400NEX for W8600NEX but not if I will lose video in motion with the simple bypass trick.
Posted Jul 18, 2024 · 00:24 UTC#317
this did not working on my DMH-2660
Page 13 of 13
