2300nex dont have a built in nav bypass only work on avic
Official AVIC NEX Bypass (AVIC NEX Units Only)
Will this work in the AVH-4201?
Thanks, OP. Found this today did it to the 7200NEX after F/W update to .07, thereby removing a PITA aspect of its 'features'. No ground of PB wire and limited time with the s/w mod.
Having left my music SD card in, it got fouled and needed repair via WinDoz10.
Confirmed working on new AVIC-W8400NEX.
doesn't work for the avic f77 with last firmware 1.10. someone have the same configuration?
I have a AHV-W4400 and installed the MicroBypass. But the 4400 has a GPS now and it picks up the cars speed. Any one know if there is a way to by fully pass the AVH-W4400NEX?
On 6/7/2018 at 1:20 PM, thierry34 said:doesn't work for the avic f77 with last firmware 1.10. someone have the same configuration?
For the European version in the Setting menu there is an item - Save Mode
Same issue with the 4400
Have same bypass , but screen blacks out under speed
On 23/06/2018 at 22:14, asd255 said:
Contournement officiel AVIC NEX (unités AVIC NEX uniquement)
Pour la version européenne dans le menu Setting il y a un item - Save Mode
yes i have !!! i'll test it and i'll tell you if it work.
thanks
So to be clear, the software screen bypass for video in motion is confirmed working on the
AVIC-W8400NEX?
bypass - does not work on AVH-4x00NEX devices.
only for AVIC of all versions NEX.
for 4000/4100/4200 the check was only for the parking brake(PKB)
For the AVH-4400NEX in Pioneer did a double check of PKB\SPEED
Update:
bypass works on AVH-W4400NEX with firmware 1.01 - download FW 1.01
8200Nex. I did the parking brake green to ground wire and pressed the lower left corner. Confirmed it worked for me.
So is there a way to bypass the 4400NEX?
I applied the software bypass to my 8200 NEX unit and grounded the parking brake and it appears to have worked, but there is some weird behavior.
Before I get started. I'm a computer hardware/software engineer and I work in the enterprise storage/server space on linux kernel modules and embedded systems so my background in this field is strong.
I intermittently get the "Parking brake misconfigured" message and I suspect I know the reason. It seems like I get this message whenever the car starts moving before the head unit has fully booted. My explanation of this has to do with the NEX boot loader on the radio and non-volatile configuration settings.
I believe that the software bypass feature is read from non-volatile storage somewhere during the boot procedure of the radio. This means that by default the radio starts to boot with the bypass disabled, and at some point during the boot procedure the unit reads the software setting out of their non-volatile storage. This would explain the behavior I have seen with the "Parking brake misconfigured" message appearing whenever I start driving the car before the radio is finished booting.
I'll keep paying attention to the behavior and if something changes I'll update my hypothesis.
I just posted in another thread about this & wondered if the 8200 has the same configuration as my 8100. The installation instructions direct to connect the green wire to the powered side of the parking brake switch, which is opposite from all the advice I received when having issues similar to yours.
I abandoned the green wire and did the bypass as instructed in this section of this site.
HTH
Edit; I had similar issues when moving before boot and nag screen "OK" when my green wire was grounded.
On 6/16/2018 at 3:36 PM, toyotaman said:I have a AHV-W4400 and installed the MicroBypass. But the 4400 has a GPS now and it picks up the cars speed. Any one know if there is a way to by fully pass the AVH-W4400NEX?
Snip the speed sense wire you dont need it anyway, plus after the latest update the magic corner works great, but after u snip the speed sense wire, hook up the micro bypass amd u will have video in motion… i have the same exact radio in my ram
Getting ready to install a w6400nex....and will use it with Android Auto. Read this whole thread.....but still can't decide: can I skip using the VSS, parking brake, and reverse wires, and the unit will function 100% (with no stupid warning messages). I did read about the soft bypass, but still can't tell if the brake wire needs to be grounded. I thought the answer was "no" for the newer NEX models. But also curious about the VSS and reverse: VSS should be easily skipped (only helps increase GPS accuracy), but does Android Auto require reverse wire like Carplay?
Thanks, Mike
Edit: 4/14/19. I consulted with a car forum I'm on, and folks in that group confirmed that I don't need any of the wires (VSS, parking, reverse) for everything to work ok. Since I'm not installing a backup camera, I don't care about the reverse either.
Does this work on the 8500NEX?
Should work on your 8500nex. Worked great on my 8400nex.
19 hours ago, zporty said:Should work on your 8500nex. Worked great on my 8400nex.
Ty, on another thread I mentioned that it did. removed the microbypass and hardwired everything and did the touch screen bypass. ![]()
Will this method work for 8500 with a maestro rr? If it does, do I need to ground both parking brake wires of the unit and maestro’s harnesses?
I don't have the Maestro RR installed (On my "To Do" list) so, I'm not sure how it would be installed nor if it affects the bypass/touch screen function toggle.
13 hours ago, }{yBr!D^ said:I don't have the Maestro RR installed (On my "To Do" list) so, I'm not sure how it would be installed nor if it affects the bypass/touch screen function toggle.
I just went ahead and installed it. The Pioneer’s parking wire to Maestro’s parking wire(already connected it before I thought about the bypass).
The bypass still works without having to ground either of the parking brake wires.
This does work on my AVIC W8500NEX. I don’t even have the parking brake wire grounded.
I tried it on my 8400 and snipped the pink - no such luck
