Official AVIC NEX Bypass (AVIC NEX Units Only)
By installereric · Mar 25, 2014in NEX Series💬 318 posts👁️ 344,345 views
Page 10 of 13
Posted Nov 15, 2015 · 14:32 UTC#226
You should connect the parking brake wire as described in the install manual & use the software bypass. If you ground the parking brake wire (or simply ignore it) you'll get occasional nag screens from the unit.
I know this from first hand experience, had mine rewired correctly (install shop wasn't happy cause it was more effort ) & no more nag screens.
Edited Nov 15, 2015 by pdclark
Posted Nov 15, 2015 · 23:31 UTC#227
Does the nag screen go away if u push "ok". If so I can deal with that here and there.
Posted Nov 18, 2015 · 13:41 UTC#228
Yes
Posted Nov 20, 2015 · 22:03 UTC#229
Confirmed this work. Just a question. Do I need to have the parking break on to update Navi? I can't seem to update my map on my NEX8000
Posted Nov 27, 2015 · 00:27 UTC#230
I have an AVIC-6100NEX installed myself, grounded parking brake wire. Once past setup, tried to initiate bypass via AV mode off, go to bottom left quadrant per directions. I repeated and repeated, moving slightly. Message never came up. Firmware was 1.01. I flashed/updated Firmware to 1.03 & updated maps. Repeated attempt to bypass. Will not happen. I disconnected parking brake grounding. Still does not bypass. Has the X100NEX update disabled this bypass? I simply cannot get it to work. I am sure I'm in correct screen, lower left quadrant, 1/2 inch in & up.  [email protected]
Posted Dec 19, 2015 · 06:38 UTC#231
I believe that's the video showing it
Posted Jan 01, 2016 · 21:31 UTC#232
Anyone who has done this bypass have successfully updated to firmware 1.11 yet? Really don't want to risk bricking my unit.
Posted Jan 02, 2016 · 01:26 UTC#233
You won't brick your unit. The worst that will happen is it will disable the bypass.
Posted Jan 02, 2016 · 01:29 UTC#234
Confirmed working with 1.11 on a 5000-nex. CarPlay crashes all the time but that is another story...
Edited Jan 02, 2016 by Abbott413
Posted Jan 02, 2016 · 08:21 UTC#235
Thanks for the reply, I did my update on the 5000NEX and everything went well.
Posted Jan 12, 2016 · 23:12 UTC#236
Can anyone please verify if the software bypass still works after upgrading 6100NEX to firmware 1.05?  I want to update, but don't want to lose the bypass ability.  Thank you.
Posted Jan 20, 2016 · 09:22 UTC#237
Another confirmation of 8100nex working. HU bought late Dec 2015. Self installed. Followed proper install procedures for parking brake. Used Hu for a while in normal conditions and noticed I couldn't do bunches of stuff while moving (w parking break off...).
Deployed firmware 1.05 on 1/18/2006, everything went smoothly. Applied the bypass 'tweak', works. Can monkey around with any/all settings while parking brake off.
Posted Jan 20, 2016 · 20:18 UTC#238
I completed the firmware update from 1.01 to 1.05 on my 6100NEX.  It is confirmed that my bypass is still working.  The only settings that I notice were reset to default are the ones in the GPS app.
Posted Mar 09, 2016 · 01:38 UTC#239
Confirmed this works on the 5100NEX on firmware 1.05. It took a few tries but I got it.
I do have the parking brake wire correctly connected to my parking brake. I had to apply the parking brake to do this bypass.
Posted Apr 24, 2016 · 22:56 UTC#240
Just purchased the 6200nex and my installer couldn't figure out how to do the bypass on this newest unit. I guess the secret button is no longer there. Anyone have any experience with this yet?
Posted Apr 24, 2016 · 23:02 UTC#241
i have a new 2016 avic 6100 nex and it wont bypass and menu bar is on side not on bottom like in viedo
Posted Apr 25, 2016 · 23:33 UTC#242
I have the same radio and I have had the same issue with the software bypass not working for me. That is because the placement of your finger in the lower left quadrant is wrong. It is not a half inch up, half inch out. Put your finger in the bottom left corner of the screen, like IN the corner of the screen and count SLOWLY TO 15. It will say "set on" before you reach 10.
To find the menu on the 6100 you just press the button (on the left side) that is different from all the rest. It is in the very center of all of the button. It is silver I think and has four little boxes. Then in the bottom right corner you will see "AV", press that. On the next page you should see, at the very bottom near center of screen, "OFF". Press that. Then follow the instructions above.
Just as a side note. I have read through every post, on every page of this thread and it wasn't until I searched "6100NEX" on this forum was I able to discover a thread from a member with a similar issue, with the same unit, and a member that made a post about the proper placement of your finger in the lower-left quadrant. The guy who posted this discovery should be given an award, however, someone decided to make him feel like crap and a "know it all".
I have tried for weeks to get Set On to come up. I went so far as to pulling my radio BACK out, extending the lite green parking brake wire and mounting to various known ground locations, soldering into radio ground, and even (don't recommend this) punching it lol. This entire time all I was doing wrong was putting my finger in the wrong place. That explains why the wife doesn't let me touch her anymore.
Edited Apr 25, 2016 by XRyan
Posted May 10, 2016 · 00:57 UTC#243
I can confirm this works on the 5200NEX.  Just bought it this week. Had to hold down in the BOTTOM LEFT CORNER, not a half inch out like the others.
Posted May 12, 2016 · 16:32 UTC#244
This doesn't work for the 4200NEX?
Posted May 13, 2016 · 20:11 UTC#245
I Installed a AVIC 6100NEX last Friday in my 2015 Subaru WRX.  The install went fine, very happy with the unit.  I knew about the AVIC software bypass, but I purchased a triple pulse bypass from a EBAY retailer with a very high feedback score just to cover all my bases.  This bypass was wired as instructed, Green to AVIC green parking brake wire, Black to Ground, blue to blue/white AVIC System remote control wire.  All connections soldered, shrink wrapped, continuity tested, etc.  On first power up I initiated the AVIC software bypass, which worked as people have described , AV off, press lower left corner of AVIC screen  for 15+ seconds- "Set on" message appears.  Can do all functions and watch DVD's while driving.  Have had periodic "Detected parking brake wire not properly installed" message at least once a day.  I did an experiment today.  I turned off the software bypass and noticed while driving, many of the Nav functions are greyed out, some of the Settings menu items were also greyed out, for example picture adjustment.  The interesting thing is, when you come to a complete stop these greyed out menu items turn white and can be used irregardless of setting the e-Brake.  When you start to move, they grey out again.  I am not sure if I have a defective triple bypass chip, or the AVIC knows you are moving and would override any hardware bypass unit.  In any case I will continue to use the software bypass.  I am going to email the seller of the bypass for his feedback and insight, and will share with you all.  Has any one else experienced this behavior on their AVIC? I wish I could get rid of the parking brake wiring problem message.  I know I could actually wire the Parking brake wire as instructed by Pioneer, but it seems the AVIC senses when the car is moving irregardless of the Parking brake status.
Posted May 16, 2016 · 19:24 UTC#246
Install the unit with the parking wire and remove the bypass, software bypass and enjoy. Why are you trying to fight what's already working.
Posted Jun 03, 2016 · 02:19 UTC#247
I have a 4200NEX. Anyone have luck with bypassing the DVD player settings when the car is in drive so that a DVD can play?
Posted Jun 07, 2016 · 02:37 UTC#248
Worked on my new NEX8200 without grounding the brake wire!!!
Posted Jun 19, 2016 · 05:31 UTC#249
Confirmed and working bypass with an NEX-8100
Posted Sep 05, 2016 · 21:47 UTC#250
So you're saying to:
Step 1 turn power on push main menu button (bottom center)
Step 2 push AV icon (bottom center)
Step 3 on AV icon screen push off button (towards bottom)
Step 4 touch quadrant 4 (half inch in and half inch up from left lower corner of touch screen) hold your finger there for about 10-12 seconds. "set on" icon will appear that means you are done.
I'm getting an 8200 next week and want to make sure I can set it up without problems. Thanks in advance.
Page 10 of 13
