Official AVIC NEX Bypass (AVIC NEX Units Only)
By installereric · Mar 25, 2014in NEX Series💬 318 posts👁️ 344,345 views
Page 4 of 13
Posted May 13, 2014 · 14:18 UTC#76
Has anybody had the "Parking brake wired incorrectly" message appear even after wiring the bypass?
I'm using the 8000NEX and have had it happen twice, both times after turning off the car to fill it with gas, and then turning it back on it.
I've soldered the parking brake wire to ground and used heat-shrink tubing to prevent shorts so I know it's wired correctly and securely.
Not a big deal, but it's still weird that I still see the message (albeit very rarely)
Posted May 13, 2014 · 14:20 UTC#77
Leave your car running while pumping gas. ðŸ˜
Edited May 13, 2014 by VBLUE42
Posted May 14, 2014 · 00:47 UTC#78
lol that too. Sand the ground surface with sand paper. make sure its a good connection or you can use a multi meter to check it.
Posted May 14, 2014 · 01:30 UTC#79
8000 wooooo!!!!! hoooo!!!!! no need to even ground  parking brake
Posted May 17, 2014 · 14:54 UTC#80
Worked perfectly on my 5000, just did it this morning, a local shop wanted $90 to do a bypass...  Thank you for the post!10353387_592834830814304_188808135993396
Posted May 18, 2014 · 14:56 UTC#81
Just finished my install of my NEX-8000 and the first thing I did was the bypass - worked perfectly, thanks again for the post!
Posted May 25, 2014 · 23:07 UTC#82
Worked like a charm, first try, on my 5000NEX.
Posted May 28, 2014 · 09:09 UTC#83
Sorry if this is dumb?. Are we 100% sure the touching the screen doesn't work with the 4000nex? Anyone been successful? Does it only work if you have a nav unit? Assuming you try this with parking brake off and DVD in unit. I tried multiple times didn't work for me.
Posted May 28, 2014 · 14:29 UTC#84
The 4000 is not and AVIC unit and as the title states this is for AVIC units only. Feel free to try it but it has already been discussed what AVH units need to achieve the bypass.
Posted May 28, 2014 · 20:00 UTC#85
I get that every so often, no rhyme or reason as to when it happens.. I might not get it for a week, then I get it once a day two days in a row. The bypass is absolutely working for me though.
Posted May 29, 2014 · 13:25 UTC#86
The 4000 needs the "traditional" microbypass approach as it does not have a nav reference that it can use to "verify" if the vehicle is moving or not.
Posted May 31, 2014 · 04:11 UTC#87
AVIC-7000NEX - worked fine for me - it was nice to get that parking brake message to go away...
Posted Jun 02, 2014 · 17:07 UTC#88
Does anyone have a tutorial on how to ground the parking brake wire?  I have never done this before, but am definitely interested in it so I do not have to keep pulling over to enter new NAV information.  I have searched high and low and have not found anything about it.  I have the Pioneer AVIC-8000NEX head unit.  Thanks in advance!
Posted Jun 02, 2014 · 17:16 UTC#89
Hoestly if you have to ask this question you should probably not be doing your own installs in any way. That being said you splice the wire to a ground wire. The back wire from the unit harness will suffice.
Posted Jun 02, 2014 · 17:27 UTC#90
I didn't do my own head unit install, but I did take it back apart after to fix some of the connections that the installer did incorrectly, as well as run more wiring to get my phone to connect to the AppRadio.  You are correct that I am very inexperienced, but splicing wires isn't hard.  :)  I just need to know which ones.  Thanks for your reply, it is much appreciated!  :)
Posted Jun 02, 2014 · 17:32 UTC#91
Just be careful with what you do. Good luck.
Posted Jun 02, 2014 · 17:38 UTC#92
Absolutely.  Thanks again, VBLUE42!
Posted Jun 02, 2014 · 19:13 UTC#93
I don't think that the parking brake wire has to be grounded. I hooked up my parking brake to the parking brake but did the bypass on the unit and it is working fine. BTW I have the 8000.
Posted Jun 02, 2014 · 19:20 UTC#94
At least up until this unit was released the brake wire had to be grounded along with other proceeders to properly achieve the bypass. It has been reported by a couple of people here that the hidden screen proceeded detailed here is all that's needed to achieve the bypass but I'm not sure I would trust that you won't have issues later. Be safe and ground the wire.
Edited Jun 02, 2014 by VBLUE42
Posted Jun 02, 2014 · 19:49 UTC#95
Okay, thanks for the info.  Would you suggest me try just the bypass first?  If it starts throwing the error later, then I can ground the wire.  Is that a logical enough approach to the problem?
Posted Jun 02, 2014 · 21:53 UTC#96
Yeah I would say try that. That way we can get a good idea if the wire actually needs to be grounded and if Pioneer actually did change the bypass scheme. Just be aware though. If this whole secret screen thing is by accident, they will likely fix it in the first update.
Posted Jun 03, 2014 · 00:06 UTC#97
it clearly says on the wire with a little green tag on a green wire "PARKING BRAKE WIRE" just use a tap connector to the ground connected on the harness
Posted Jun 03, 2014 · 04:15 UTC#98
Just confirm, in my avh-4000, i use old bypass that i have on my appradio 2, works fine!!
Posted Jun 03, 2014 · 04:33 UTC#99
Thanks for the info but it is in the wrong thread. Please move it!
Posted Jun 03, 2014 · 04:38 UTC#100
That is precisely what I did on my AVIC-8000NEX. It's been a couple of weeks now and a) the bypass is still working just fine, and B) the nag screens I was getting when my parking brake input was tied to ground have not reappeared.
Page 4 of 13
