New guy so I would like to start off by saying 'thanks' to all those who have posted regarding this issue. You all have been a HUGE help! Without you, I would be completely bald. . .
I had the AVIC-5000NEX installed in a '07 Dodge Ram replacing the OEM nav system. I go to pick it up after the installation and see the green parking brake wire laying on the floorboard. "Just ground it and you are good to go" they tell me. I asked why they didn't. They reply they can not do it for either liability/law reasons? Never heard of this. Whatever. Easy to do in any event, although connecting to the parking brake lead was going to be a PITA. . . .
On the way home I have to listen to 'her' letting me know that I was speeding. That was absolutely annoying. . .!! I tried to set this in the Map Settings and it is greyed out unable to select it. . . What the hell? I spend the next two hours, resetting, powering up/down, researching to no avail and then it dawns on me, the green parking brake wire??? No, it can't be. . . So I call the installer, who says that shouldn't be the issue, but speaks to the actual installer and comes back to me and says you need to ground it. OK, so I do.
I now then am able to adjust the Map Settings turning the speed visual/audible warning off. Success! BUT, upon startup of the vehicle I get the prompt about the parking brake cable not being correctly connected. I dismiss it and determine that when the vehicle is stopped, I am able to access these Settings. When the vehicle is in motion, they are again greyed out. So it appears that in conjunction with the parking brake, the unit senses the vehicle motion in determining what can be accessed or not when in motion.
I certainly do not want to dismiss that prompt every time and a quick DuckDuck Go search brings me here to AVIC411! I immediately find this topic and the software bypass and activate it! Everything in the world is right now! Well, almost right. Where the hell is the CarPlay update already Pioneer. . . ?? Again thanks and if you have any questions, let me know! A great unit by the way!
