Check your Messages
software error screen
Bonee, can you also send the SPH-DA120 img my way? I've been looking at a loading screen for days... Would GREATLY appreciate the help!
Hi,
Can I have a link to the SPH-DA120 image please - EU preferred, but to be frank I'll try anything - corrupt SD card
I need a SPH-DA120 image the link is dead on the previous posts.Mine is US
hey bonee would you be kind enough to send me the img for sph-120 been without the radio for months and would greatly appreciate it
Hey, so I had some help fixing my DA120 With Testkey N3 to unlock the SD and the Image that I now have for the US SPH-DA120. You use win32 disk imager to put the image on the sd card drive once it's unlocked.
https://drive.google.com/file/d/0BzObkaTnnIcWSU82N1A2WE9uWDg/view?usp=sharing
https://drive.google.com/file/d/0BzObkaTnnIcWa1Y1UDZvYTlsWTg/view?usp=sharing
Hi just stumbled on this forum asI am having an issue with my DA120 here in the UK. Went out to the car this morning and switched on and got the software error.
Is it just a case of downloading the DA120 file from the above link and extracing / installing it onto the new memory card and then plugging this into the head unit?
Any help grately appreciated as my journies to work are now rather dull.
Mike
Can someone help me with the 7000 image. US version please. Software error on my unit!
Bonee,
Can you please help me with the SPH-DA120 Img ?
Thank you very much
I recently stumbled on this thread looking to find information about the SD firmware on a 4000NEX. I'm trying to fix a 4000NEX with corrupted firmware. I successfully copied over the image from my 4100 to the 4000 using the tools provided on the backups thread, only to find out that bluetooth isn't working, and apparently nobody has been able to get it working either. I've been searching the webs trying to find an img file of the 4000 stock firmware, but have come up empty. As a last resort, I'm hoping maybe someone here knows a link, or maybe has the img file? If it's still needed, I can upload my backup 4100 stock img file.
Thanks in advance for any help!
whats the model number???
AVIC-F80
I replaced the internal SD card on my 4000nex with the 6100 backup since I was unable to find one for the 4000nex but would like to downgrade back to 4000 to get bluetooth functionality restored. I read on an earlier post that this is possible however, when i try to install other firmware versions for 4000, the unit just reports an error message. Is the only way to downgrade via pulling back out the internal SD card, trying to locate a 4000nex image and reinstalling? This forum has been a great source of info, BTW. Thanks!
Hi guys, I've also got a bricked 7000NEX. bonee i see you have the SD internal memory? Can you (or anyone else) be able to send me the link? It's been bricked for 2 years and hasn't been in use. I thank you guys, I thought i was the only one!
Hi bonee i have appradio 4 sph da120 an was wondering if you could tell me how to restore with new memory card or if i can pay you to put it on a memory card for me
@bonee I was trying to see if you could give me the software for sph-da120 appradio4 an tell me how to do it using mac
Hi guys, I've also got a bricked 8600. I see you have the SD internal memory? Can you be able to send me the link? I thank you guys!
@bonee i need image for sph-da120 please
@bonee I downloaded the image and put it on an sd card and it didn't work is there a certain way I have to put it on the sd card and do I have to put anything else on the sd card
use Win32Diskimager
Ok I'll try to figure that out when I get home not that good with this kind of stuff but don't wanna pay 200 to send it to pioneer if I don't have to
When I try in unzipping the file it's telling me it it's corrupted
Hi, I have an avh 8600bt system error. I remove the card but I did not find anywhere to download the backup software. Can you send me the link? I thank you!
backup do other users. we have long been asking to make backup. but nobody helps. we have only made the backup themselves
i have backup da120/x8600bt/4000nex
yesterday helped restore x8600bt (4000nex)
I can help you. but you have to disassemble the unit and remove the SD card. if you are willing. I'll help you. we have experience in the recovery of 20+ devices
Hola, Tengo un error del sistema avh 8600bt. Quito la tarjeta pero no encontré ningún lugar para descargar el software de copia de seguridad. ¿Puedes enviarme el enlace? ¡Te lo agradezco!
