software error screen
By capikoo · Jun 03, 2014in NEX Series💬 177 posts👁️ 105,151 views
Page 7 of 8
Posted Jul 04, 2020 · 17:07 UTC#151
Does anyone have an updated link to the image file for the AVH-4000NEX. Mine bricked today :angry:
Posted Jul 27, 2020 · 22:34 UTC#152
Hi, I've had the bootloop happen to me last week Avh 4200 , I bought the image on eBay flashed it to a new quality card, and today I got the software error...now I need to do it again but I'm not sure about using the same files that I bought, would anyone here be generous enough to send me a copy of their IMG for a us/can version of the AVH 4200 Nex, thanks
Posted Sep 10, 2020 · 00:10 UTC#153
Hi :) does anyone have a card image for the AVH -X8600BT model. Unfortunately, my card is dead. Please help .
Posted Oct 17, 2020 · 18:58 UTC#154
Can anyone help with an EU SPH-DA120 SD card image please? Got a unit stuck in a boot loop.Thanks.
Posted Nov 03, 2020 · 19:05 UTC#155
On 10.09.2020 at 02:10, Krzysztof31 said:
Cześć, :)czy ktoś ma obraz karty dla modelu AVH -X8600BT. Niestety moja karta jest martwa. Proszę pomóż .
Can anyone help? :)
Posted Jan 14, 2021 · 11:54 UTC#156
El 3/8/2017 a las 9:41, bigben561 dijo:
¡Héroe! ¡Muchas gracias! Trabajó por primera vez!
Alguien me puede pasar la imagen del SPH-DA120
Posted Feb 12, 2021 · 21:09 UTC#157
I would also need the EU SPH-DA 120 SD card image please :mellow: @bonee maybe? Could you help me out?
My radio just broke with that software error message. Thanks in advance for any help.
Edited Feb 12, 2021 by Stevil
Posted Apr 02, 2021 · 01:43 UTC#158
Hallo Jungs, Kann mir jemand helfen, ich habe alles erweitert. Aber ich kann das Bild für das 8600BT Modell nicht finden .. Können Sie es hier herunterladen? Und mit was öffne ich diese Dateien? Ich hoffe, jemand kann mir helfen .. Das Gerät ist brandneu, es war mit mir für 2 Jahre und der erste Start und dieser Fehler bin ich wirklich gepisst und enttäuscht.
Posted Apr 07, 2021 · 21:46 UTC#159
Hello all.
I just created a torrent file including the image. Used it for my SPH-DA120. After writing it, you can update the firmware. AFAIK this is the 1.13 version. To copy the image from MacOS or Ubuntu, use:
dd bs=1048576 if=<path_to>/AVIC.img of=/dev/block/mmcblk0 # adapt to your needs
On windows, it seems you can use win32diskimager.
SPH-DA120.zip.torrent
Edited Apr 07, 2021 by thunderdome2 — Reason: switching from "quote" block to "code" one
Posted Jun 30, 2021 · 14:34 UTC#161
Alguém tem o software de imagem desse aparelho f80tv?
O meu deu tela preta aparecendo erro de software!
Posted Oct 22, 2021 · 22:32 UTC#163
does any one have a Photo ( or good explanation) of SD card location on AVH-4000NEX? is the 4gb unit just inside the faceplate assembly? I swapped that out and still sideways after power up.
But I'm also not sure I loaded the software correctly ( I'm using a MAC )
Thanks in Advance
Posted Oct 23, 2021 · 00:19 UTC#164
using the guidance from this message board, I was able to download the AVIC.img file and via MAC command line I belive I got it not an SD card.
now the unit open up in the Soft/Firm ware is sideways and then the screen goes blank.....
I'm 'hoping' it is rebooting - I'll give it a few hours and see if it comes back.
Posted Oct 23, 2021 · 20:23 UTC#165
Nope, seems pretty dead now, Software error screen, then Blank.
I Think I'll investigate repairs, replacement units in short supply these days.
Posted Jan 21, 2022 · 20:10 UTC#166
On 6/3/2014 at 8:22 PM, capikoo said:
Has anyone experience an issue where when the unit boots it goes directly to a screen that states system error.
i have the same fault , can you please give me the factory sd card firmware for 8600 . i need help with this otherwise my 8600 will stay like this for a long time
Posted Jan 22, 2022 · 14:53 UTC#167
Firmware is on pioneer website...
Posted Jan 23, 2022 · 04:20 UTC#168
Thanks for answer , but
not update, original sd card software required
Posted May 23, 2022 · 21:45 UTC#169
On 10/18/2021 at 3:20 PM, hasena1977 said:
Edited May 23, 2022 by soshan
Posted Jul 19, 2022 · 21:21 UTC#170
Got a new sd card off eBay made it past the software error screen but now it’s stuck on updating version0.00->0.00 then fails any help would be greatly appreciated.
Posted Jul 19, 2022 · 21:32 UTC#171
Any have a fix for being stuck on updating screen with Version saying 0.00_>0.00 already changed sd card
Posted Jul 20, 2022 · 02:49 UTC#172
Talk to the seller
Posted Jan 19, 2023 · 01:16 UTC#173
So I’m sitting in a position where I have a dead AVIC-4000NEX and a working one.
I’m going to factory reset the working one and try to backup its internal SD card and see if I can at least post a checksum here.
Hopefully the checksum will be the same as the existing downloads floating around after its factory reset.
if anyone wants to retweet this:
Maybe we can push some pressure on Pioneer to release official images.
Posted Mar 28, 2023 · 19:57 UTC#174
HI all,
i also discovered the software problem with my sph-da120 and i am looking everywhere for the software image
@bonee could you also be so kind and send me the link, if you still have the software??? :) I know its some time ago
would be really great!
Posted Jun 19, 2023 · 18:22 UTC#175
On 1/20/2019 at 8:40 AM, selah_ said:
I HAVE FOUND THE TRUE 4000NEX IMAGE FILE. I'm going to provide it below in a link and a step by step on how to get this piece of crap radio system back in order.
Install Win32DiskImager (https://sourceforge.net/projects/win32diskimager/) I had difficulty with this version, it kept crashing, so I installed version 0.9.5 and ran it in administrator and it worked like a charm.
Write this image file onto your 4-8gb SDHC SD card using that program.
AVH-4000NEX Image File: https://avichacking.slack.com/files/UE0G0SC84/FEE5UPR46/4000nex.rar
If that one doesn't work for some reason, here is another link with a few other image files. The one for the 4000NEX is "Pioneer avic F_60 v1.15"
https://mega.nz/#F!D6giQCCI!Xd7Q2O34b8eccByv4KlG5g!6vww0YxR
I can't access the AVICHacking site without an account and downloading the the rar file from Mega promps me for a password. I've searched everywhere but cant seem to find it. Can someone point post the password or DM me the password for the file please?
Page 7 of 8
