Hi
What you got here is very impressive.
I would like to change the MRZ09 to Polish. Can you advise how to do it?
Hi
Hello
I just got my MRZ09 changed to the English version. I am so happy I made it.
There are some small adjustments needed but it looks very good though.
I you let me know how I will make these adjustments and have them available here.
Hello
The translated strings are in my GitHub repo:
The file for mrz09 is translated_110.txt
You can edit them there or add a new file with a different language if you like. All the code to produce a language file is there.
I've also written some code to change the images and I'll make that available soon.
Here's a zip file that should automatically update mrz99, mrz77, mrz09 and mrz07 (and perhaps others).
https://github.com/dzo/mrz99/blob/master/updatemrz99.zip?raw=true
Extract the zip to a usb drive and switch on the AVIC with it plugged in to install.
If you want to use a SD card, edit the script and replace USB\ with SD\ in the copy commands
It also replaces the images so there is almost no Japanese text left.
My mrz99 has a photo of my family as the background but I'm sure you don't want that in your car so I've replaced it with this:
https://github.com/dzo/mrz99/blob/master/updated/b1853.bmp
Make sure you do a backup before running the script just in case.
can anyone helped me change an AVIC MRZ07 to English. or is the AVIC MRZ09 file the same
It should be the same as 09 but this hasn't been tested. Make a backup of \USER\ and try the zip I posted yesterday. If it doesn't work, restore the Image.img file first and check again. The script shows which files are replaced.
Hi,
Dose anyone have an idea if this files will work on and MRZ 66? Could it be possible to change to English from Japanese?
Above was my question but since then i decided to give dzo file a try. IT WORKS ON AVIC MRZ66
My steps:
Enter test mode: HOLD NAVI - press right, left 3 times
In the main menu go down to nr 11(last one). My menu is in Japanese.
1. Go to USER file.
2. Make back up as DZO suggested. Use the buttons on the radio to go left right up down. (volume up down) (next track left right) NAVI ( takes you back to main menu only) Select or mode is under Navi ( For me). It takes a wile to paste the files so be patient.
I used this video to understand how to copy and paste. Also it did not want to paste to my USB but to the memory card it worked.
3. Look in /USER to see if there is a file named PRG.FLG
if there is, then the system uses /USER/PRG1, otherwise it uses /USER/PRG0
I had both and both had the same files and this was what i need it to change PF090JPJPN.LNG
DZO did say! " You can check the file versions by looking at /USER/PRGx/PF090APL.HTM (where x is 0 or 1 depending on PRG.FLG)" but the files where just a bit different in size.
In PRG1 it was 94000 in size or so did the file manager say.
/USER/PRG1/APL/LANGDATA/
Here i wanna mention that there a lot of files and in both APL and LANGDATA you need to scroll to the bottom to find both files.
4. I replaced them both in both folders PRG0 and PRG1 but only after i replaced it in PRG1 it changed the menu. Second time is a charm.
There are more files in this folder and i suspect that there for navigation or other parts of the system since not all my radio is in English. Parts of NAVI are still in Japanese but who cares.
What was most important is that is file worked and managed to turn a useless radio in one that i can use.
One more thing would be good is to manage to change the maps and then this would be even better.
Anyone has some maps for this kind of navigation? Mine are for Japan 2011 and i need Europe any year since will do.
Hello
If I put in the translation of a different language here will you be able to save it as a LNG file?
Can you advise how to change the background, welcome screen or fonts on MRZ09?
Hi,
My steps:
1. Go to USER file.
https://goo.gl/photos/Zis3ZTxzFHpJUnv46
https://goo.gl/photos/a6JJi6NjpoYYAF54A
Hello
I did the same on my MRZ09 and it looks way better. I have a similar issue with maps for Europe. Anyone has them available?
Rgds
Hello
I checked the EN version of the file PF110JPJPN.LNG and it looks ok. Somehow I didnt find elements I thought needed improvement. However translation to English is limited by the google translator same as with my Polish version. How to deal with that I don't know yet.
Here
https://github.com/ak1947K2/mrz99/tree/patch-1
I downloaded the 1st version of Polish translation.
Dzo could you do your magic and change it to LNG file? Or let me know how to do it.
Hello
Here
It's a good start but I'm afraid you will need to do some more work for this to be usable.
Your translation only has the first 700 strings, there are over 4000 needed. Google translate has a limit so you will need to translate them in batches.
You also need to make sure that anywhere there is a % in a line, that it isn't changed by google translate, % followed by a number and/or character is a format string and google translate will mess these up so you need to change them back by hand. There should never be a space after a % and sometimes the character and the % are swapped or the char is capitalised. Look at the original strings if in doubt.
Hi
That is ok. I will sit on it.
But in the meantime could you do the 700 strings as it is so in the English version?
If % sign shows up what should it be changed to?
Rgds
Hello Dzo and all other
It is more time consuming that I thought. I prepared a ver. 2 but found out there are way more strings...
I will come back in a while then ![]()
Rgds
Dear Dzo
Ive tried to install the LNG on my Japanese MRZ 05 but ACCIDENTALLY deleted other files in the LANGDATA option .... As a result not only
I dont get anything in English, I get empty boxes which means even the Japanese characters disappear!!!
Note: I replaced the file with the one zipped here kindly from ypu BOTH in PRG0 and PRG1.
Your help will be highly appreciated
Best F
I have deleted also PF110JPNENG.LGN which i shouldnt and there is no way i canlocate that anywhere....
Hi
Can you not download it from here?
Thanks Dzo
I managed now to get the boxes back to normal having pasted LANGDATA IN PR 0 which is apparently what my device uses.
Now the problem is for MRZ05 is that I got back everything in Japanese again!
Should I download PF090JPJPN.LNG as translated by you here and replace the same file which is now in LANGDATA or shall I RENAME it in PF110JPJPN.LNG so that I will end up having English in the system everywhere? Or have you translated PF110JPJPN.LNG in English?
Thanks Dzo
Post #11 has a zip with a translated PF110JPJPN.LNG
You can also try the zip installer in post #29 to replace the images too
but:
Make sure you do a backup first!
Dear Dzo,
It has worked miracles!!!
I replaced the image and the two files in LANGDATA and now everything is in English, GPS and Stereo!!!
Thanks a lot my friend!!!
Now for the big challenge:
I live in Cyprus and my GPS positions me in Japan ![]()
Is it possible to fiddle around and install European maps on my MRZ 05?
Hello and happy new year! Does anybody know how to change a background on mrz99?
P.S.thanks Dzo for translating . Everything works well.
European maps for MRZ anybody?
Option 2 :
Is it at all possible to install any other navigation such as IGO on MRZ?
but:
Hi Dzo, Thanks heaps for upload these lng file, I have mzr09 device and i believe this equal to z120bt, is there any chance we can use z120bt firmware to update mrz09?
