What platform is MRZ 05 using? I am confused! I need maps for Cyprus and I dont know how to do it... Please help!
AVIC-MRZ99 Custom Firmware / Testmode
I've updated the translations and made the background image blue, here's a new zip.
https://github.com/dzo/mrz99/releases/download/v2.0/updatemrz99.zip
Blue backround looks so much better Dzo, Thank you!
Now is it possible to install Igo on MRZ? What files must be downloaded and how do we get them to work?
I am having a terrible time with Japan maps while I am located in Cyprus.
Can you please help?
Hi Dzo
Thanks for your gr8 work. I wonder whether it's possible to get setup or Install instruction in text/doc format so everyone can follow that. Btw, do i need to follow your previous step to get in setup mode or simply plugging USB is ok to run setup ?
Waiting for your kind reply.
Regards
Karim
If you have a mrz99, all you have to do is extract the zip from post #52 to a usb drive and plug it in.
No other instructions are necessary.
If you have a different model, it's probably best to make a backup first.
Dear Dzo
Thanks for reply. Really appreciate your efforts, it makes our life more comfortable.
Keep it up and continue your good job.
Thanks again for your gr8 job.
Regards
Karim
Since we have dedicated this post to MRZ, is there a way to mirror my android phone on my MRZ 05 screen?
I have installed IGO on the android but the screen is too small and not safe to watch. I do pass the instructions to the HU with AUX but I would be grateful if I can have my phone screen on my HU
hello, i tried this on my mrz77. it changes the background picture but it does not change the language
attached is my language file
I put the wrong installer script in that zip, here's one that should work:
https://github.com/dzo/mrz99/releases/download/v2.1/mrz99_update.zip
thanks the japanese strings changed to english but another problem is created. when you are in the navigation screen and press the menu hardware key to go to settings, the screen is distorted.... please see attached image
Dear DZO
Which one we should try for Drz99? latest or previous one?
Regards
Karim
Say what (file)you need and I'll send to you from my backup mrz77
Dear Krasi do you have maps or navigation backed up?
thanks krasi,
i had a backup of my mrz77 and i changed image.img.
now i am back to stock images but at least they are not distorted. some japanese characters still show up on the images. maybe dzo can help with this?
thanks
thanks krasi,
thanks
If you post a link to your backup Image.img, I'll take a look at it and see what the problem is.
Hello dzo.
I attach a copy of my mrz77 image.img
Hello dzo.
OK,
I made a quick update with your image, let me know if this works.
https://www.dropbox.com/s/7oztdfghmen60il/Image_mrz77.img?dl=0
Don't use this on anything but mrz77
OK,
thanks. it works now. see attached. i dont know if it was supposed to show text instead of dots though![]()
Hi DZO, you can make the background auto. instead of the blue.thank you
I don't have time to make custom backgrounds for people but you can always compile the code yourself and add you own.
The new bitmaps are here:
https://github.com/dzo/mrz99/tree/master/updated
They need to be 16 bit old style windows bmps, Gimp can make these but it produces an incompatible bmp header so you need to run fixbmpheader on them.
Easiest way to compile and run the code is on a Linux box.
That should be the only screen which is wrong, mrz77 has a few extra strings.
Hi Dzo
Today i tried mrz99 one, after installation it has shown done but unfortunately nothing has changed. Could u plz tell what is the reason? i have used #52 file.
Waiting for you update.
Hi Dzo
Use the zip from post 59.
The latest zip will always be here:
thanks DZO but I'm not good with computer programs does not work ![]()
